FDA Medical Device Reprocessing Guidance - Validation
acro14
FDA has issued a guidance for the reprocessing of medical devices. There a validation of the cleaning process is required. How you can handle that in a time efficient-manner?
we have a fabric whose cleaning and disinfectiion process has to be validated. Can you rely on data from the detergent manufacturer or rely on formulations specific to the fabric or a manual?
As the cleaning process has to be performed by a home user (in the laundry) a validation could not be able to reproduce real conditions, i.e. we cannot put hundreds of detergents under test. Has anybody an idea?
planB
It's still a draft if you refer to this - and actually applies to health care settings, not home use:
http://www.fda.gov/MedicalDevices/DeviceRegulationandGuidance/GuidanceDocuments/ucm252999.htm
No, you (usually) cannot - except your detergent manufacturer can provide you with evidence that allows you to adopt your fabric into the detergent manufacturer's reprocessing validation.
You may want to employ a common detergent and find out its active ingredient(s). You could then refer in your IFU to the active ingredient(s) instead of a specific detergent trade mark.
Generally, you will have to label instructions that a home user will be able to follow, so you will have to think of validating real-world /usable conditions.
HTH,
Gerhard
Agochar
Ok - a little removed from the above but - I have a non-sterile (does not need to be sterilized), non-implantable, transient use device which can be used in healthcare facilities or in the home use environment. This device should be wiped down with alcohol wipes between multiple users and wiped down intermittently(as needed) with one user. I have a hard time saying this is reprocessed per the FDA usage of the word "reprocessed medical device". Your comment is appreciated.
Ronen E
Problem Solver
Moderator
Why would you say it's not "reprocessed"?
Reprocessing: Validated processes used to render a medical device, which has been previously used or contaminated, fit for a subsequent single use. These processes are designed to remove soil and contaminants by cleaning and to inactivate microorganisms by disinfection or sterilization.
KMac
I have a question that relates to the title of the thread if appropriate.
We are looking to conduct cleaning and sterilization validation for our reusable medical devices. I am having some issues finding any reference to the requirements of the certification of the test house providing the validation. The FDA guidance referred to in the title of this thread gives no mention of the certification requirements of the test house conducting the validation.
I am wondering if anyone can help me understand what the test requirements for doing cleaning and sterility assurance validations are? Whether a GLP or equivalent test house is necessary to complete this testing, or would a non-certified test facility be sufficient?
I anyone knows of any guidance or regulations specific to this, I would be grateful.
Thanks,
samarth
NikhilT
hi in this scenario (use of thread) you can define on the label the methods of reuse, "to obtain the best result for reuse using " (* manufactured preferred way of / tested method).
Also, define a method to identify its discard (eg. cuts in the thread) and for best results reusability life of XXXX times under defined conditions.
Another way is to sell add alcohol wipe to your packaging and earn extra.
Ronen E
Problem Solver
Moderator
Thanks,
The key to the answer to your question is in the ISO standard(s) that covers the relevant sterilisation method (e.g. Gamma) and its validation. Cross that with the scope of the relevant FDA standard recognition.
That should get you started in the right direction.
B FDA Requirements for medical device to be used for training purposes only US Food and Drug Administration (FDA) 9
B FDA regulations medical device prescription fulfillment DME question US Medical Device Regulations 0
M Can you import medical device not FDA approved into the USA under an IND application? US Food and Drug Administration (FDA) 2
M FDA Medical device reporting (Manufacturer in US; contract manufacturer OuS) US Food and Drug Administration (FDA) 0
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 2
B A.I. diagnostic software is considered as medical device in FDA? US Food and Drug Administration (FDA) 6
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
I How to classify a medical device based on FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S The US FDA requirements on Disposal of a medical device US Food and Drug Administration (FDA) 1
S FDA Requirements for Medical Device Label Reconciliation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 4
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 11
D FDA Approved Class II Medical Device? Other US Medical Device Regulations 11
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
T Clinical trial - Medical device product not cleared (without FDA approval) in a drug trial Other US Medical Device Regulations 9
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Medical Device User Fee Rates for Fiscal Year 2020 Medical Device and FDA Regulations and Standards News 0
M Informational How the FDA Uses Science to Speed Medical Device Innovation Medical Device and FDA Regulations and Standards News 0
L A Taiwan company want to sell Class I medical device (510(k) exempt) on Amazon, should we register with FDA? US Food and Drug Administration (FDA) 4
M Informational US FDA – Statement on agency’s efforts to increase transparency in medical device reporting Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Patient-Reported Outcomes (PROs) in Medical Device Decision Making Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
M How to Select FDA Medical Device Product Code? Other US Medical Device Regulations 10
J FDA Class 1 Medical Device UDI requirements Other US Medical Device Regulations 20
M Informational US FDA – Patient Preference Information (PPI) in Medical Device Decision-Making Medical Device and FDA Regulations and Standards News 0
R US FDA Mandatory Labelling contents for an OTC medical device US Food and Drug Administration (FDA) 0
M Informational FDA Qualifies First Biomarker Test as Part of Medical Device Development Tools (MDDT) Program Medical Device and FDA Regulations and Standards News 0
C FDA Medical Device Label Requirements - serial numbers Other US Medical Device Regulations 9
Ed Panek Website to ask FDA for guidance in Medical Device Industry? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Referencing Medical Device in FDA records - Package contains several other components Other Medical Device Regulations World-Wide 1
N Per the FDA regulations can a medical device be class I despite that it is sterile? Other Medical Device Related Standards 4
S FDA approval process for medical device US Food and Drug Administration (FDA) 2
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M FDA Considers Shift on Medical Device Quality System Regulations - 2018 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
N Does FDA allow comparing with the competitors Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
shimonv Summary of FDA Guidance on “Medical Device Accessories” (Dec 2016) Other US Medical Device Regulations 1
I The likelihood of approval by the FDA for a Class II Medical Device US Food and Drug Administration (FDA) 8
B Will FDA Inspect a New Coating Supplier for a Class III Combination Medical Device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
F CE and FDA Mark on same IVD/Medical Device Label EU Medical Device Regulations 12
S FDA Class I Medical Device Safety and Efficacy Data Requirements Other US Medical Device Regulations 5
I FDA Class II Medical Device Clinical Trials and and FDA IDE Requirements US Food and Drug Administration (FDA) 3
B FDA Listing of a Class I Medical Device in USA (Manufactured in China) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
Ronen E FDA encourages industry to participate in Medical Device Single Audit Program (MDSAP) Other US Medical Device Regulations 10
M IEC 62304, ISO 14971 and FDA Medical Device SW Guidance 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
