FDA on changing acceptance criteria re: analytical method validation
ChemistAnalytical
Hi all. I'm curious how the FDA would view the loosening of acceptance criteria for analytical method validation.
For example, unnecessarily tight specifications were approved for a analytical method validation protocol. The validation failed some of these specifications and it was documented in the report. The FDA typically accepts acceptance criteria of 80% to 120% for this parameter, accuracy of impurities. The acceptance criteria which were not being met was 95% to 105%.
Are there any issues with loosening the specification based on the assumption that the original specifications were not appropriate?
v9991
the reason/trigger of assumption that original specification were inappropriate, on its own could not be complete justification for relaxing the acceptance criteria.
even if its true, it leads to question the basis for approving the protocol, or even SOP , if the tighter values are traceable to it.
hence, add the details of
1. how/why this particular method does not fit the acceptance criteria,
1.1 burden would increase if the same ( analytical ) technique and material type are similar to the previous validations where the criteria is met
2. add references to the other pharmacopoeia, regulatory expectations criteria
add the product or molecule specific criteria for same.
https://www.fda.gov/media/71846/download
http://pqri.org/wp-content/uploads/2015/08/pdf/White Paper.pdf
G Changing Non-Critical Component Suppliers - Convenience kits (FDA) Procedure packs Other Medical Device and Orthopedic Related Topics 2
R Ownership of FDA registered establishment changing - what to do? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
E FDA & Internal Audits US Medical Device Regulations 3
N Importing into US without 510K/FDA Clearance US Medical Device Regulations 1
N FDA class 2 Device QS Requirements US Food and Drug Administration (FDA) 2
T FDA labeling requirements US Food and Drug Administration (FDA) 2
S FDA Contract Manufacturer and Applicant US Food and Drug Administration (FDA) 0
R IVD Software FDA/CLIA doubts Medical Device and FDA Regulations and Standards News 1
R IVD software FDA and CLIA US Food and Drug Administration (FDA) 2
T FDA level of concern vs IEC 62304 safety classification - 510(k) exempt device Other US Medical Device Regulations 12
K Change in address on ERLM US FDA: Implications to import US Medical Device Regulations 0
V FDA 510K - Pre Submission Query US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
C FDA 510k documentation requirements US Food and Drug Administration (FDA) 1
T Link GMDN code and FDA product code US Medical Device Regulations 5
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
K Non-Device MDDS Clarifications (FDA) US Food and Drug Administration (FDA) 7
Ed Panek Consultant Request SaMD AI "Expert" FDA US Food and Drug Administration (FDA) 2
Sam Lazzara Record signature requirements in proposed FDA 21 CFR 820 QMS Regulation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
shimonv FDA-recognized Standards US Food and Drug Administration (FDA) 0
R FDA ECG Data Requirements Medical Information Technology, Medical Software and Health Informatics 3
L Language of quality system in case of FDA inspection US Food and Drug Administration (FDA) 1
M Can you import medical device not FDA approved into the USA under an IND application? US Food and Drug Administration (FDA) 2
Ed Panek FDA Submits to White House Plan to Harmonize with ISO 13485 US Medical Device Regulations 2
Melissa Contract Mfg--to Manufacturer with the FDA ISO 13485:2016 - Medical Device Quality Management Systems 4
Ed Panek ANNUAL FDA Registration - What 510(k) number to use? US Food and Drug Administration (FDA) 1
Y FDA vs (EU) 2021/2226 Electronic Instructions for Use (eIFUs) US Medical Device Regulations 1
M FDA Medical device reporting (Manufacturer in US; contract manufacturer OuS) US Food and Drug Administration (FDA) 0
JesseE Electronic signatures FDA CFR 820 ISO 13485:2016 - Medical Device Quality Management Systems 3
C FDA logo for marketing US Food and Drug Administration (FDA) 3
G FDA clearance for a device that can't be used clinically (at present) Other US Medical Device Regulations 5
M FDA Syringe Marking requirements US Food and Drug Administration (FDA) 4
K Guidance on X-Ray Medical Devices for Animal Use - FDA US Food and Drug Administration (FDA) 0
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
T FDA UDI Question - Class II Medical Device Other US Medical Device Regulations 2
P Does FDA require certification for quality system internal audit for auditor? Qualification and Validation (including 21 CFR Part 11) 1
I If i do not want to be an initial importer should i register with FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B When FDA Decision Summary opens? US Food and Drug Administration (FDA) 4
Ed Panek FDA Remote Regulatory Assessment (RRA) Overview 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
B What is the difference btw RUO vs IUO for IVD in FDA guidance ? US Food and Drug Administration (FDA) 12
B How to submit Pre-submission to FDA? US Food and Drug Administration (FDA) 4
L FDA & 21 CFR Part 11 Medical Device and FDA Regulations and Standards News 19
B A.I. diagnostic software is considered as medical device in FDA? US Food and Drug Administration (FDA) 6
Ed Panek 2020 FDA Top Ten Observations 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M FDA Requirements for Investigational Devices - Clinical Investigation & Shipping Medical Device and FDA Regulations and Standards News 0
Ed Panek Does this FDA Requirement Apply to international (not USA) distributors for USA based manufacturing companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B FDA Breakthrough Device can be overlapped with a designated device? US Food and Drug Administration (FDA) 6
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 5
S Examples of FDA acceptable Software Design Specification (SDS) Medical Device and FDA Regulations and Standards News 6
