FDA Premarket Submissions for Embedded Software - Level of Concern
kreid
I have been looking into the level of concern for a piece of embedded software under development.
Question 4 of Table 1 of the FDA Premarket Submissions for Software guide, asks:
Prior to mitigation of hazards, could a failure of the Software Device result in death or serious injury, either to a patient or to a user of the device?
As part of the design of the device a Preliminary Hazard Analysis was carried out which showed that a software failure might lead to a serious injury. As a result of the PHA the device is being designed so that there are hardware safe-guards to prevent any software failiures leading to serious injury.
My question is, does the "Prior to mitigation" part of Q4 mean that if the design is created (based on the PHA) that prevents software failures causing serious hazards, does this constitute a risk mitigation, and hence still qualify it as software of a major concern or can we say that the design is such that software failures cannot contribute to serious harm.
In effect, at what point in the design and development lifecycle should Q4 be asked?
yodon
While this may seem to be skirting the question a bit, IEC 62304 does make this rather clear:
If the RISK of death or SERIOUS INJURY arising from a software failure is subsequently reduced to an acceptable level (as defined by ISO 14971) by a hardware RISK CONTROL measure, either by reducing the consequences of the failure or by reducing the probability of death or SERIOUS INJURY arising from that failure, the software safety classification may be reduced from C to B; and if the RISK of non-SERIOUS INJURY arising from a software failure is similarly reduced to an acceptable level by a hardware RISK CONTROL measure, the software safety classification may be reduced from B to A.
Given that and the fact that 62304 is a recognized consensus standard by the FDA, I think you'd be in a pretty defensible position if you did so.
kreid
Hi Yodon,
Thanks for your response.
My problem is that for the FDA if the software failure could cause a seriuos injury pre-mitigation then it is classsed as a major level of concern and this has an impact on registration and other activities.
The excerpt you quote from 62304 is a common approach in safety critcal software systems but the FDA approach would seem to penalise someone following the good engineering practice of changing a design to limit the effects of software failure.
Kreid
kreid
As an aside the passage you quote from 62304 was removed in the last update.
It was replaced by a flow chart that I think is very confusing, and makes it difficult to conclude your software is anything but Class A!
yodon
I think it's generally the same; they just replaced hardware control with control external to the software system.
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
Ronen E FDA News FDA issues guidance on bench testing in premarket submissions Other US Medical Device Regulations 0
S Is Software code documentation required for FDA premarket submissions? IEC 62304 - Medical Device Software Life Cycle Processes 2
M Medical Device News FDA Releases Draft Recommendations on Premarket Submissions for Management of Cybersecurity in Medical Devices Other US Medical Device Regulations 0
M Medical Device News FDA news 14-09-18 - Use of Voluntary Consensus Standards in Premarket Submissions Other US Medical Device Regulations 3
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
M Medical Device News FDA news -11-09-18 - Review of Cybersecurity into Premarket Review Other US Medical Device Regulations 0
P FDA - Evaluating Substantial Equivalence in Premarket Notifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S FDA CDRH Premarket Review Submission Cover Sheet - adding more products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
bio_subbu US FDA issues Draft Guidance on Premarket Approval (PMA) Acceptability Other US Medical Device Regulations 0
R FDA CDRH Premarket Review Requirements - Submission Cover Sheet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Michael Malis FDA issued modifications to the list of standards used in Premarket Review Process US Food and Drug Administration (FDA) 0
Y Convenience pack FDA US Food and Drug Administration (FDA) 1
B FDA regulations medical device prescription fulfillment DME question US Medical Device Regulations 0
N FDA medical devices US Food and Drug Administration (FDA) 1
R US FDA 510k Australia TGA US Food and Drug Administration (FDA) 0
B How FDA define a new variant/generation or a new device US Medical Device Regulations 11
G FDA Annual Registration and Listing US Food and Drug Administration (FDA) 7
T Book Excerpt: Drugs and the FDA: Safety, Efficacy, and the Public’s Trust Book, Video, Blog and Web Site Reviews and Recommendations 0
E The FDA regulations (21 CFR 312.3): Is it allowable that IND sponsor involves more than one individual or organization? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
P Looking for Korean FDA Drug Master File requirements for packaging systems. Other Medical Device and Orthopedic Related Topics 1
M IEC 62366 Hazard-related Use Scenario vs FDA Critical Task EU Medical Device Regulations 3
N Free sale and FDA US Food and Drug Administration (FDA) 1
N FDA class 1 US Food and Drug Administration (FDA) 6
G UDI in EU vs FDA EU Medical Device Regulations 1
S Initial Audit FDA US Medical Device Regulations 3
T FDA PMA review process - advisory panel timing? Other Medical Device and Orthopedic Related Topics 0
E FDA & Internal Audits US Medical Device Regulations 3
N Importing into US without 510K/FDA Clearance US Medical Device Regulations 1
N FDA class 2 Device QS Requirements US Food and Drug Administration (FDA) 2
T FDA labeling requirements US Food and Drug Administration (FDA) 2
S FDA Contract Manufacturer and Applicant US Food and Drug Administration (FDA) 0
R IVD Software FDA/CLIA doubts Medical Device and FDA Regulations and Standards News 1
R IVD software FDA and CLIA US Food and Drug Administration (FDA) 2
T FDA level of concern vs IEC 62304 safety classification - 510(k) exempt device Other US Medical Device Regulations 13
K Change in address on ERLM US FDA: Implications to import US Medical Device Regulations 0
V FDA 510K - Pre Submission Query US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
C FDA 510k documentation requirements US Food and Drug Administration (FDA) 1
T Link GMDN code and FDA product code US Medical Device Regulations 5
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
M How does FDA determine OAI and VAI after inspection? ISO 13485:2016 - Medical Device Quality Management Systems 0
K Non-Device MDDS Clarifications (FDA) US Food and Drug Administration (FDA) 7
Ed Panek Consultant Request SaMD AI "Expert" FDA US Food and Drug Administration (FDA) 2
Sam Lazzara Record signature requirements in proposed FDA 21 CFR 820 QMS Regulation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
shimonv FDA-recognized Standards US Food and Drug Administration (FDA) 0
R FDA ECG Data Requirements Medical Information Technology, Medical Software and Health Informatics 3
