FDA Routine Inspection Pre-Anouncement - What will be checked?
jayquality
We are a european manufacturer of a medical device, class I for FDA, class I for europe.
Exemt from premarket approval, not exemt from GMP.
We received the pre-announcement for a 4 day routine inspection.
We have only 12 employees.
How much of the 21CFR820 will be audited?
Am i correct assuming its a level II inspection?
Is it similar (scope and depth) to a ISO 13485 audit?
Under the MDD, only a few sections are mandatory to class I devices, the scope of the iso 13845 can be reduced.
What about the FDA?
I cant find a list that tells me what sections are not applicable for class I except design control which is applicable since the device contains software.
tx
MIREGMGR
Re: FDA routine inspection pre-anouncement, what will be checked?
We received the pre-announcement for a 4 day routine inspection. (...) How much of the 21CFR820 will be audited? Am i correct assuming its a level II inspection?
The process and inspection-scope for a "routine" inspection (i.e. not a For Cause inspection, and usually Level 1 rather than Level 2) is explained in the QSIT Manual, http://www.fda.gov/ICECI/Inspections/InspectionGuides/ucm074883.htm.
jayquality
I was hoping for it to be a level i but according to the fda website:
"All foreign inspections should be conducted using the QSIT Guide under the Level 2 strategy"
http :// www .fda .gov/MedicalDevices/DeviceRegulationandGuidance/GuidanceDocuments/ucm244267.htm - OBSOLETE BROKEN 404 LINK(s) UNLINKED
MIREGMGR
Not being subject to foreign inspection, I hadn't picked up on that. Thanks for pointing it out.
pkost
My last FDA audit was about 2 years ago; it involved a single inspector turning up for 4 days to essentially turn a 4 employee company inside out.
All applicable areas of 21CFR820 were looked at (how could they not be in that time). The scope was obviously similar to ISO13485 but considering that an ISO audit would be 1-2 days, it was more thorough; more records were examined, it was not cursory. Even with the time avaliable it was clear the FDA has areas where it is more diligent, I think every complaint and CAPA was examined.
If they find anything that concerns them they delve much deeper and keep going when a notified body would otherwise stop, I asked the inspector about this and he pointed out that the NB issues a non conformance what's done is done, the evidence has been found, you have your non conformance. From his perspective he had identified a breach in the law and was gathering evidence to present in a court case; the more evidence he could find the better his chances of a successful prosecution.
From a scheduling perspective, everyday was started at 9 and stopped at 5; he only finished early on the last day (around lunch time). Lunch was limited to sandwiches in the audit room and none of the audit snacks consumed except by me. He refused our our offer to take him out for an evening meal every night. I appreciate the need not to accept lavish lunches/meals, also appreciate that some auditees will use lunch as a method to reduce audit time, but I found the rules to border on rude.
Overall he was fair and reasonable, he was approachable and gave some pointers and advise. Despite my comments above we faired quite well and only received a couple of 483's on issues that were relatively minor, we had I think 30days to respond to these to the FDA office, we did this and from recollection didn't hear anything more.
chris1price
That's a good summary, my last FDA inspection in UK was 3 years ago and followed much the same process, 1 inspector, 4 days. Take a good look through the QSIT guidance, it will give a good indication of what will be reviewed. They will be much more thorough than an ISO auditor, requesting at every record (every complaint, Non-conformance, CAPA, DHR, etc). They may not look at them all, but they are good at finding the errors.
If you get any 483s, answer them as completely as possible, make sure your CAPA looks at every associated event, not just the one referenced. Have a look at FDA warning letters, you will see what they don't like!
M Medical Device News FDA - Eliminating Routine FDA news 14-09-18 - Re-Review of Third Party 510(k) Reviews Other US Medical Device Regulations 0
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P MSDS for MVQ FDA White, Vinyl Methyl Silicone Rubber EU Medical Device Regulations 4
C RA (Regulatory Assurance) Training (FDA) looking for resources Training - Internal, External, Online and Distance Learning 5
E FDA 513(g) Cover Letter US Food and Drug Administration (FDA) 5
S Records - Do's and don't' of record entries (FDA - 21 CFR 820) Records and Data - Quality, Legal and Other Evidence 13
B New Facility register with FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
J FDA regulation on decorative contact lenses Medical Device and FDA Regulations and Standards News 5
P Anyone have an Idea on UAE Medical device registeration- Class B with FDA only Other Medical Device Regulations World-Wide 0
F FDA classification for a mobile app Medical Information Technology, Medical Software and Health Informatics 3
Ed Panek IFU Contact Requirements - FDA and MDD/MDR US Food and Drug Administration (FDA) 1
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
K FDA - Can we have more than 1 Initial Importer Medical Device and FDA Regulations and Standards News 4
K Two FDA questions regarding UDI (and potentially 803.52 MDR) Other US Medical Device Regulations 0
R Importers - For the FDA Registration/ Listing, is the CMO the importer? Medical Device and FDA Regulations and Standards News 6
Z Iterative development and FDA change requests IEC 62304 - Medical Device Software Life Cycle Processes 12
P FDA Approved Product Contact Parts ISO 13485:2016 - Medical Device Quality Management Systems 6
O Clarifying FDA definition of "finished device" and “capable of functioning” 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 7
JoCam FDA Registration for Sub-contract manufacturers Medical Device and FDA Regulations and Standards News 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
P Choice of FDA reviewer US Food and Drug Administration (FDA) 6
J Is Device Tracking Card an actual requirement under FDA regulation? Other US Medical Device Regulations 0
T Definition Human Use (FDA) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
K FDA 510k electrosurgery 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
J Leveraging FDA 510k Clearance for International Registrations Other Medical Device Regulations World-Wide 2
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
J FDA notification of address change US Food and Drug Administration (FDA) 2
N Usability testing required for FDA IDE (investigational device exemption)? Human Factors and Ergonomics in Engineering 8
A FDA Class Classification for a cabinet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
Edward Reesor FDA DM and /or Class I Life Saving US Food and Drug Administration (FDA) 0
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 8
K FDA Premarket Cybersecurity Guidance - 4 questions Other US Medical Device Regulations 5
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Watchcat FDA Webinar Series - N95 Respirators Other US Medical Device Regulations 0
