FDA Submission Question
Ed Panek
QA RA Small Med Dev Company
Assuming a company has an approved wearable device that presents its measurements to a consumer phone or web interface via 510(k). If a third party had an FDA cleared device and wanted to present their output via our GUI (As is with no adjustments), would an FDA submission be required?
shimonv
I believe so, because you are now presenting information that you didn’t show before, and perhaps your intended use is extended. Furthermore, there is a potential usability issue because the user now sees additional information from the second device, which might affect his overall interpretation of the results from your device. And you are dependent on the results coming in from the other device, which are subject to changes.
-Shimin
mihzago
I think you've got a similar answer in another forum, but it depends on what do you intend this information to present and how you present it. If it just displays the data from the device without any modification or analysis then it could fall under MDDS.
Orca1
If a third party with an FDA-cleared device wants to present their output via your GUI without any adjustments, an FDA submission may be required. This is because integrating a new device into your existing system could be considered a significant change or modification that could affect the safety or effectiveness of the device or its intended use (21 CFR 807.81(a)(3)(i) and (ii)).
In such cases, you may need to submit a new 510(k) or a supplement to support the new use or integration (21 CFR 99.3(k)(3)). The submission should include appropriate supporting data to show that the manufacturer has considered the consequences and effects the change or modification or new use might have on the safety and effectiveness of the device (21 CFR 807.87(g)).
S FDA 510(K) submission question US Food and Drug Administration (FDA) 4
D FDA Question: Contents of an FDA 510(k) Submission ISO 13485:2016 - Medical Device Quality Management Systems 1
P Biocompatibility testing ISO-10993 for FDA submission Other Medical Device Related Standards 7
V FDA 510K - Pre Submission Query US Food and Drug Administration (FDA) 6
B How to submit Pre-submission to FDA? US Food and Drug Administration (FDA) 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P Writing a presubmission to the FDA prior to the De novo submission US Food and Drug Administration (FDA) 4
M PMS template for FDA submission (De novo submission for a Class II IVD) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
T Change to the FDA cleared device (ours) - Submission or Letter to file? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
D FDA Pre-Submission Meeting Advice US Food and Drug Administration (FDA) 0
T FDA Q-Submission Informational Meeting 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S New clean room change submission - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S FDA electronic submission gateway (ESG): FAILED eMDR Submission Other US Medical Device Regulations 3
V Writing a Pre-Submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 62
Pmarszal FDA Global UDI Database: Record Submission Retention Other US Medical Device Regulations 1
Q FDA - Annual Report Submission Format and QMS updates Other US Medical Device Regulations 2
I Small Business Qualification Certification Submission - FDA Form 3602 US Food and Drug Administration (FDA) 5
A FDA 510(k) Submission Timelines US Food and Drug Administration (FDA) 1
R New Draft Guidance Document for FDA's current thinking on De Novo submission Other US Medical Device Regulations 1
H FDA/PMA/Medical Device/Before submission/Manufacturing facility change US Food and Drug Administration (FDA) 1
M Demonstrating battery safety in 510(K) submission for the FDA Other US Medical Device Regulations 9
S FDA CDRH Premarket Review Submission Cover Sheet - adding more products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T Support of our customer?s PMA submission to the FDA 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P New FDA 510k Submission Guidance Other US Medical Device Regulations 2
S FDA Draft Guidance on HLA Kits 510(k) Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
Y New Draft FDA Guidance for Applicability of GLP in Medical Device Submission Other US Medical Device Regulations 2
D FDA 510(k) Submission Tests - Posterior Cervical Spinestem 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Reference a MAF outside the context of a US FDA submission? US Food and Drug Administration (FDA) 1
T FDA 510k Submission - Section 012 SE (Substantial Equivalence) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M FDA Submission Consultancy - Registering and marketing our products in the US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M FDA Submission Printing Format - Is double sided printing allowed? Other US Medical Device Regulations 5
E Contacting FDA via phone to let them know a Submission is Imminent Other US Medical Device Regulations 6
Ronen E FDA publishes Draft Guidance on Med Dev Pre-Submission Program and Meetings with FDA Other US Medical Device Regulations 0
D New FDA guidance: Pre-Submission Program to replace the pre-IDE Program 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Will you use the FDA's ISO 13485 Voluntary Report Submission Program? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
G FDA Voluntary Audit Report Submission Pilot Program now a final guidance document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
O US FDA Consultants in Mumbai - Orthopaedic Devices 510K Submission help US Food and Drug Administration (FDA) 9
R FDA CDRH Premarket Review Requirements - Submission Cover Sheet 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
glork98 What cGMPs are needed for an FDA IDE submission? US Food and Drug Administration (FDA) 1
T IEC 62304:2006: Medical device software SDLC- CE Vs. Fda 510(k) submission IEC 62304 - Medical Device Software Life Cycle Processes 16
J FDA Response to PMA Submission: Help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
T Submission of 510(k) - Does the FDA require a predefined structure of the content? ISO 13485:2016 - Medical Device Quality Management Systems 2
R EC11 - Guidance Document - FDA 510 (k) Submission - ECG Monitors 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
M CAD files in a submission to FDA ISO 13485:2016 - Medical Device Quality Management Systems 1
G FDA requirements for risk analysis US Food and Drug Administration (FDA) 2
V Anyone have templates for FDA GMP Guidelines for supplement manufacturers? US Food and Drug Administration (FDA) 0
N FDA mechanical bench testing Manufacturing and Related Processes 5
V Regulatory consultants for US FDA ANDA - pharma / drug products Consultants and Consulting 0
M Clinical evaluation process of FDA and MDR Medical Device and FDA Regulations and Standards News 2
