Feature Control Frame - Interpretation - Two Tolerances?
Manix
Get Involved!!!
Hi All,
I am trying to interpret the attached control frame to define a measurement requirement using a gauge that has been specifically built for this purpose.
What do I know, well, I know it is the profile of the line (actually it's a surface, I think they got the symbol wrong!) that is important. I don't however know why there seems to be two tolerance bands. 0.3 and 0.6? They both relate to the same datum contstraints and material conditions!!
It's a gap condition, so the variation of the surface will create differing gaps (between that surface and another surface on application and indeed the gauge).
Can anyone help as to how to interpret this tolerance?
David DeLong
You are probably correct stating that this symbol should be profile of a surface rather than profile of a line. I will now assume that it is profile of a surface.
You have a composite feature control frame with the top section relative and dimensioned from the datums shown. In other words, it reflects the location of the surface relative of datums A, B and C.
Although the datums must be holes (features of size) since they are shown at MMC and, apparently, it is legal (ASME Y14.5M-94) but it is not practical application. That probably would be another question and not relative to the question asked.
The bottom section of a composite feature control frame controls the surface itself. It will control this surface for flatness, perpendicular to datum A and oriented (angularity relationship) to datums B & C.
That is the difference.
An example of a composite feature control frame with profile of a surface is shown on pages 176 & 177 of the ASME Y14.5M-94 standard. Please note that the example does not reflect datums at MMC.
Hope this helps.
Manix
Get Involved!!!
Hope this helps.
Thanks David, that has helped in understanding what they mean, but now I don't know how to measure them. We have a gauge that this parts is inserted into and the gap between this surface and the surface of the gauge is measured. How do you devise the acceptable variation in the measured values (the tolerance)? Both variation in the location and the profile of the surface will effect the gap!!??
The gap nominal is 0.
David DeLong
One would require 2 gauges.
1st gauge - The top section of this feature control frame is 0.6 or +/- 0.3 from the theoretic surface. One would have a checking fixture with two (2) pins of MMC size for datums B & C. The part would be placed onto the two (2) pins in datum holes B & C and resting on datum A. Now I would have a broad rectangular stepped pin of +0.3 and - 0.3 the width of the surface oriented and dimensioned from B & C. Place the part on the fixture and then try to get both sections of the rectangular pin on the surface. This gauge is a floating fixture since one will accrue tolerances from holes datum B & C. Please note that this gauge does not and cannot measure flatness of the surface but its highest point on that surface.
2nd gauge - same as the first except the stepped gauge is only 0.3 and the part is allowed to move relative to datums B and C but must be oriented. This is a bad gauge since, again, it does not relate the flatness of the surface. I really don't like it but, it you want a gauge, here it is.
If you want to discuss this further, you can send me directly questions on this gauge.
Stijloor
Hope this helps.
David,
Thank you very much for your post.
The OP is from the UK. I believe that he should refer to the appropriate ISO standard (ISO 1660:1987). Without seeing the entire drawing, including the datum features (of size), it will be very difficult to interpret the drawing with "100%" confidence.
What do you think?
Stijloor.
David DeLong
David,
What do you think?
Stijloor.
Stijloor:
I did make some assumptions for sure but I do know that if datums B & C are at MMC, they must be features of size rather than surfaces. Datum A is assumed the mounting surface.
ISO has some strange methods for sure and I was reflecting the ASME standard rather than ISO so my confidence level certainly is not 100%.
Good point!
CMMMonster
I recently encountered a composite positional tolerance applied to two hole locations that should be concentric. I was puzzled by this because the top line of the control frame was true position of .010" ADC. and the bottom line was true position of .005" ADC. wouldn't the bottom line override the top line? I have only worked in Aerospace for a Year and this is the first time i have encountered this. Normally i would see the second line referenced to one, two ,or no datum reference at all. Is it even possible for to reference the same three datums in both lines of the composite tolerance? Any help or opinion is greatly appreciated. Please let me know if this should be posted elsewhere this is the only thread I could find relating to this topic.I also could not figure out how to start a new thread before i had to leave for work. Thanks!
Q
QC Rick
My very late 2 cents. (Same for CMMMonster's post)
This is not a true composite FCF, it is the same structure with two tolerances and the lesser tolerance negates the greater. (Based on ASME Y14.5)
It should be: (See attached image)
CMMMonster
Thanks alot Rick. That is what I though. When referenced to the same datum structure the tighter tolerance will prevail.
M 4 Datums Referenced in a Print (Drawing) Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Feature Control Frame is applied to the end of a Cylinder - Datum Dilemma Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
optomist1 Digging Datums - Feature control frame (FCF) applied to a pipe I.D. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
optomist1 Multiple Single Segment Feature Control Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T Q&A session - Interpreting FCF (Feature Control Frame) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 43
G Clarification on Position with Bonus Tolerance - Feature Control Frame Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
optomist1 GD&T - Indirect Straightness Control - The Size Dimension on a Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
L SC in a circle next to feature box - Is this "Statistical Control" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
V Control Feature - Definition as per API Q1 Oil and Gas Industry Standards and Regulations 17
T What Do 'They' Want in a Gage R&R? Every gage on every feature on my control plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
Ron Rompen Location of features identified on Print - Feature out of location Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Marc Definition RFS - Regardless of Feature Size (GD&T) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
A Inform NB of change to Indications of Use, but change is not a medical feature CE Marking (Conformité Européene) / CB Scheme 1
B Counterbore - Hole or feature? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Using Minitab 17's Stepwise Regression to Predict Feature Using Minitab Software 2
R Rejecting a Part when Dimension Feature is Basic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
P Measuring Feature Location from a Theoretical Centerline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L ASME Y14.5 Coaxial Feature Toleranced with Position w/o Reference Datum Design and Development of Products and Processes 2
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
B REACH & ROHS Declaration for Concrete Casting Water Feature RoHS, REACH, ELV, IMDS and Restricted Substances 3
C GR&R of a gauge to check a new feature of a new product Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Machine Feature: Is it possible to consider it Error Proofing? FMEA and Control Plans 6
F CMM Scanning Feature Delays - Brown and Sharpe automatic CMM using PC-DMIS CAD 4.3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
optomist1 GD&T - Bounded Feature or Bounded Feature of Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Reporting Profile of a Surface Results on an Internal Cylindrical Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
B Capability Analysis of a Repeated Feature Quality Tools, Improvement and Analysis 9
optomist1 Coplanar Widths As Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Tolerance of Position - Pattern of Holes at MMC - Datum Feature Reference Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
optomist1 Size Dimension and Feature of Size - FOS as subset of a Size Dimension Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
H TC 176 Website - Request for an Interpretation Feature ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Can Training feature in a Process FMEA FMEA and Control Plans 12
Z MSA (Measurement System Analysis) for a .0003" tolerance feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K What features (feature list) for free calibration software? Calibration and Metrology Software and Hardware 11
B Pointless GD&T Position Callout? Feature is labeled as a Key Characteristic Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
S Feature perpendicularity dimension should be good up to how many decimal points? Manufacturing and Related Processes 8
Ajit Basrur Has anyone used the "Certification Totals" feature on ANAB Website ? Registrars and Notified Bodies 9
N Using the narration feature in powerpoint as a training tool Training - Internal, External, Online and Distance Learning 12
L What Standard Applies to This? Feature (or defects) not depicted on the print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Q Use of OD Indicator Micrometers - Round Feature vs. Flat Surfaces Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Jim Wynne GOOG-411 - Yet another Google feature After Work and Weekend Discussion Topics 2
H Definition of feature "R" as regards a radius on a print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
G What is meant when a datum (feature) is called a "6 way"? GD&T help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
Marc Another Windows Vista Feature Bites the Dust - PC-to-PC synchronization After Work and Weekend Discussion Topics 1
