Feedback from reading Jennifer Kirley's suggested 'motivation' reading links
selena15
Hi all
thanks to Jennifer for the proposal of the following reading. very interesting articles from another thread:
Lack of Will & Empowerment of Employees
.....But I can say that human behavior is generally based on motivation that one can loosely ascertain via the theories of:
Maslow
McGregor
Deming
Drucker
here is my feedback:
Drucker article:
page3: the third comment: " learn to say no" --- there is no question about the incidence to success to do so for one individual whatever his function. the question is what is the incidence of it within an organisation? and more is there any framework to say no in order to avoid a discrimination? no stop a way for people who will use it to scape?
would this be usefull to check it as part of improvement system audit ?
Deming
page 3 the last chap talk about the check an individual long term virtue as key word of his implication within a system and to see a performance issues as special or common causes.
100% agreed.
if i try to see this within our present king or org° and not in just my area, as i remember, the annual evaluation don't have this idea in its phylosophie if i can say it like this.
Of course, it is checking how the individual is acting within team, or along, sense of initiative..bla bla, but does this would give a clear and real picture of this person. more, if one person is let's say special or don't fit in any common personal profil. as instance: how it is seen one individual which has an effective adding value within value, but with one negative nature: he isn't able to work within a team. he get better result acting alone.
No one i assume would say that all the employees within an org are team workers. so how this Deming assumptions is established. what i use to see, if yes we do this check but if we discover one adding value person with this lack in team work, we would see it as area to convince this person to improve, with training or any others stuff. what if no solution work and this person keep acting alone. it can for several reason, one that i've notify one day is the difference of acting itself. believe me, i've never seen a person as this, he's just a faster thinker than others. and complain that others do not have the same rate than him!!!!!
Just off topic, i would be curious to audit one certified system against the western system :) .
Maslow article:
page 4: as critic of this model, it say that move from one need to the sup one can remove the priority of the first need: " the need of esteem can prior to the security need. i would say it can because, once one need become granted, it start to be seen as normal one, permanent one and of course the needs priority would change and established new one where the acquired one do not have the same priority.
i will encurage you to read and feedback :)
waiting your feedback
Selena
Jen Kirley
Quality and Auditing Expert
Hi all
Lack of Will & Empowerment of Employees here is my feedback:
Drucker article:
would this be usefull to check it as part of improvement system audit?
These are very interesting and worthwhile questions. :applause:
Drucker's reference to "Learn to say no" regarded policy because we too often act like weathervanes unless we pursue what is really important. The reference to favoritism was dealt with via the reference to President Truman:
If Truman said no, it was no, and if he said yes, it was yes. And he didn't say no to one person and yes to the next one on the same issue.
In auditing we should be especially aware of this point. As with parenthood, it must surely be easy to believe the auditor is more strict with one person or group than another. And as with parenting, we auditors might indeed over time decide this person is easier to work with than that one. Thinking otherwise, or not acting on the belief, requires discipline.
Deming
100% agreed.
We as employees of organizations are members of the team. It is the leadership's responsibility to make that clear and meaningful.
Registrars supposedly do not hold organizations to different requirements based on geography, but global registrars tend to employ local auditors and some of us in the West have considered the possibility that some auditors have applied less stringent criteria for registration than others. It is a question of variation and its cause, and I expect it is a controversial issue.
Maslow article:
Selena
A person that works toward self actualization will still need security. I do. The needs are not in conflict and they are not exclusive. I think (and I invite anyone to rebut this) that Maslow's higher motivations are meant to describe the greatest source of human inspiration to succeed versus the lesser ones. In a challenging economy such as the present one, I can suppose the security level to gain rather more weight than the self-actualization level. Does that make sense?
selena15
Hi Jennifer
thanks for this interesting post
....Drucker's reference to "Learn to say no" regarded policy because we too often act like weathervanes unless we pursue what is really important. The reference to favoritism was dealt with via the reference to President Truman:
Yes Jennifer, in IMO, it would be one of the clue that this reference is established within an org or that one individual has success to impose his decision.
....In auditing we should be especially aware of this point. As with parenthood, it must surely be easy to believe the auditor is more strict with one person or group than another….
-- I’m not expecting any someone’s side since the auditors are independent and diplomat by definition. The point is if such questions are the scope of the audit. Surely, report of an audit can raise the fact that there is lack in doing task because of no time management. The point is as root cause, need on time management training can be considered.
Would the fact that x person “don’t know or do not have possibility to say no” be considered as root cause and seek of corrective action to it ?
....We as employees of organizations are members of the team. It is the leadership's responsibility to make that clear and meaningful.
Maybe I’ve say it in wrong way, but work within team, while respecting the character of one person if it has an effective adding value to the work is good too. I mean, within work, all the employees are team, acting in different tasks to achieve the first requirement. The question is to ensure to persons achieve the work with an optimum adding value.
....but global registrars tend to employ local auditors and some of us in the West have considered the possibility that some auditors have applied less stringent criteria for registration than others..
--- Whatever the localization from where the auditors would be selected, finally they answer the client requirements and in case of Certification, they answer to the certification requirements. Most of org within worldwide are now multinational and take a least part of decision in one org. they send their auditors from the West or whenever they want and probably take into consideration this point. Believe me, from my modest experience within orgs international and I’ve almost met a big part of nationalities, most of problem that I’m launching here is just human being.
Off of topic, I was hearing complains from to friends of me, one USA, and one from UK. Both were complaining about their family’s husbands and that a cultural difference has big part of this. When they gave me reason, I’ve success to convince them that their problem is human being and even they got a husband from their native country, they would have the same problem. For sure, nobody would ignore the cultural difference or barrier or whatever, the hint is to not consider all the issue or situation from this framework, but to consider in its context and check the root cause before to pour it in difference causes packages.
To come back to the auditors comment, sure some auditors can be less stringent as you said, but finally they answer to one requirement, in one established framework and they can be considered as mirror to the maturity of the system. And this would bring me back to my first question: does this “to learn to say no” or any kind of question part of an audit requirements?
.... In a challenging economy such as the present one, I can suppose the security level to gain rather more weight than the self-actualization level. Does that make sense?
For sure, gaining a weight can be the mirror that the self-actualization is achieved. As you had said, they are not in conflict or exclusive but human consideration change and fit to their present, I’m remembering one good article send here in cove about motivation of employees, and one reward would never compensate another one.
BTW, sorry for the late, i was a sick :(
Sel
H Does anyone has feedback on a notified body for small companies? EU Medical Device Regulations 3
dgrainger Informational EC - Medical devices – online manuals replacing paper instructions - Feedback period: 27 April 2021 - 25 May 2021 EU Medical Device Regulations 0
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
C Production and Post Production feedback - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
D Social Media Feedback process for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
Ed Panek User Feedback both negative and positive and acting upon those metrics 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Informational USFDA draft guidance – Nonbinding Feedback After Certain FDA Inspections of Device Establishments Medical Device and FDA Regulations and Standards News 0
A Have sites like Ebay and Amazon killed customer satisfaction/feedback? Customer Complaints 7
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ed Panek Requirement to track and trend positive feedback from customers ISO 13485:2016 - Medical Device Quality Management Systems 12
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
K Need feedback: FMEA Web Application FMEA and Control Plans 5
S ISO 13485:2016 ¶ 8.2.1 - How can we obtain feedback for production activities? ISO 13485:2016 - Medical Device Quality Management Systems 5
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
L Audit Finding Flowchart for Feedback General Auditing Discussions 6
D Alternatives to Customer Feedback Survey in ISO 9001 Quality Manager and Management Related Issues 4
C 510(k) STED Format - Feedback from users US Food and Drug Administration (FDA) 1
somashekar MDSAP (Medical Device Single Audit Program) Pilot: Please share your feedback ISO 13485:2016 - Medical Device Quality Management Systems 35
C PFMEA RPN - Feedback regarding adjusted RPN FMEA and Control Plans 3
S Seeking Feedback on ASQ Guide to Failure Mode and Effect Analysis FMEA and Control Plans 2
J Looking for feedback from current/former Intelex users Quality Assurance and Compliance Software Tools and Solutions 4
S ASQ CSSBB March 1, 2014 Exam Feedback Professional Certifications and Degrees 7
0 Feedback on proposed restructure of Quality Management System (QMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
E Feedback on Negative Experiences with a CB's Service Level Registrars and Notified Bodies 6
E Feedback on the ASQ CSSBB On Oct 5th 2013 Professional Certifications and Degrees 6
smryan Quality Manual - feedback requested ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Customer Survey Assessment Feedback Customer Complaints 11
J Adverse Event Reporting Flowchart (US) - feedback appreciated! Other US Medical Device Regulations 4
J Adverse Event Reporting Flowchart (EU) - feedback appreciated! EU Medical Device Regulations 4
J Flowchart for Canadian Adverse Event Reporting - feedback appreciated! Canada Medical Device Regulations 3
I Feedback on an Environmental Aspects and Impacts Register Miscellaneous Environmental Standards and EMS Related Discussions 5
Crusader Training / Competency Assessment Record for review and feedback Training - Internal, External, Online and Distance Learning 12
T Review of OASIS Feedback - Note on Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Customer Feedback - ISO 13485 Section 8.2.1 - Small Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A Feedback on Approach to Flowcharts ISO 9001 Process Maps, Process Mapping and Turtle Diagrams 5
C Customer Feedback, Satisfaction, Complaint Procedure and Measurement Customer Complaints 8
B Online User Feedback Customer Complaints 11
V Can we take a Green Belt project to improve the Internal Customer Feedback Six Sigma 6
R Customer Feedback and ISO 13485 Management Review ISO 13485:2016 - Medical Device Quality Management Systems 2
R Is there an ISO 13485 requirement to solicit Customer Feedback? Customer Complaints 5
V Any experience/feedback on statistical software tools...minitab -design expert -JMP Using Minitab Software 4
S Registrar Ranking - Looking for feedback on SAI Global Registrars and Notified Bodies 8
H Process Audit Checklist Example - Feedback Please Internal Auditing 16
