Feedback on proposed restructure of Quality Management System (QMS)
JaneB
#11
Hello 01mercy
Typically organizations have the 4 tier quality management structure with Level 1 as the Quality Manual, Level 2 as procedures supporting the requirements of the Standard, Level 3 as work instructions supporting the operations and Level 4 as Records....
While this may be 'typical' in your average manufacturing company, perhaps, I'm going to take issue with your statement that appears to infer it is 'typical' in general, Ajit. It isn't.
Almost none of the companies I've worked with have that kind of structure, and it certainly neither works for, nor supports, most service companies or IT/software companies, etc. Might have been true once, but I disagree that it is these days.
01mercy
#12
Dear Jane B,
Thank you for your opinion on the statements given by Ajit.
However, to add value to the discussion.
Can you tell me your experience with the companies you worked with and also tell me why this tier structure in you opinion does not work or support a system?
Thank you very much.
JaneB
#13
Mercy,
If you're happy with Ajit's advice, take it. If you seek more more information, try doing some searches - there's been a huge amount already written (not only by me) in previous threads that should address your questions.
t.PoN
#14
I have to agree with Jane.
What am i getting used to see is Process Procedure, Department Procedure, Product Procedure ....etc.
Some name it procedures, other instructions but actually its up to the organisation definition.
others may refer to the Hierarchy of Documents to actually the authority to issue a policy or procedure (when its not centralized).
Ajit Basrur
#15
You are right :)
Mike_H
#16
I am interested in some examples of a Quality Manual that doesn't mirror the standard as some of the aging manuals tended to do. Nevertheless, ISO does require a manual with; scope statement, any exclusions, reference to documented procedures (only those required by the std?) , some description of the interaction between processes (is this meant to represent only processes necessary for your business or all support processes etc..it could be read either way). I never did understand the pure benefit of this , is it to specifically demonstrate you have analysed your business processes and "put it on display"? :confused: Thoughts very much appreciated...
t.PoN
#17
Ok, forget the ISO standard for a second.
What does your organisation have as a governance?
What do you have for anyone (new employee, customer ...etc) to make them understand your system, your processes ....etc.
that is the Quality Manual in my opinion. that what is required by the ISO standard.
For your remark
The documented procedure is not what some called the 6 standard procedure. its all the necessary documentation required by your system to operate effectively.
JaneB
#18
tPon - that is absolutely excellent advice you give, :applause:
Mercy, you say you are
...committed to set up a QMS that works for the work floor and that gives structure and clearity to the different departments, in short to make it work
Which sounds great.
But you also say
I'm now thinking of the structure to put this hierarchy in and what I know from my previous work is that the structure of the clauses in ISO9001 are followed as a structure in the Qmanual and I want to use it also for the folder structure of the documents. Than the structure in the manual is one on one the same as the storing structure of the documents.
My strongest advice is: DO NOT use the structure of the standard!!
It's not compatible with your stated intent for a start (practical, works for shop floor etc) and that way lies madness (again, search previous threads for more about why).
If that's the only model you've ever seen I can understand your believing that's the Best or the Right Way to do it.
It Just Isn't So.
The.'best' way is what works well for your organisation, in a nutshell.
Don't over-complicate things. Keep it simple. (Do you really need all those codes and numbers?)
Work with the shop floor etc to find a model that is simple, practical and that works for them.
Then - and only then! Cross check back against the standard to see you've covered off all essentials. never start from the Standard and never, never, ever! use it as a structure.
Mike_H
#19
I follow what you're saying ...we have nothing at all. That's why I'm interested in talking about the approach others have taken, or failing that I'll take my best shot.:cfingers:
t.PoN
#20
I am afraid that its really difficult to help.
the organisation is a very complex thing. you'll find the one designed as task oriented, the functional oriented ....etc.
you'll have organisations with the tough guy culture, or process culture....etc.
as it differs, the consultation process differs. you could be have an advisory style or an intervention style ...etc.
you can give the process owner a full control in how to manage his process. other times you need to tell him how to do it and enforce it.
We can tell you to use the flow chart, turtle diagram, ....and all the tools but how to use them best..... it is really a tough one.
Examples of Quality Manuals and Tools are all over this forum are available on this forum. if you want a specific industry then we can give you examples, but how did we come up with this final product is the know how that you need.
N Feedback on Proposed plan for Management Review Management Review Meetings and related Processes 17
D Question regarding customer feedback process ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 8.2.1 and 8.2.2 - Customer Feedback and Customer Complaints ISO 13485:2016 - Medical Device Quality Management Systems 5
C Production and Post Production feedback - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 4
BeaBea ISO 9001 Customer Feedback Methods - What has worked for your company? Service Industry Specific Topics 17
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
D Social Media Feedback process for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 6
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
F ISO 17025 8.6.2 Customer Feedback Analysis ISO 17025 related Discussions 5
M Informational US FDA Guidance update – Requests for Feedback and Meetings for Medical Device Submissions: The Q-Submission Program Medical Device and FDA Regulations and Standards News 0
Ed Panek User Feedback both negative and positive and acting upon those metrics 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Informational USFDA draft guidance – Nonbinding Feedback After Certain FDA Inspections of Device Establishments Medical Device and FDA Regulations and Standards News 0
A Have sites like Ebay and Amazon killed customer satisfaction/feedback? Customer Complaints 7
I ISO9001:2015 9.1.2 - Customer Satisfaction Feedback ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ed Panek Requirement to track and trend positive feedback from customers ISO 13485:2016 - Medical Device Quality Management Systems 12
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
K Need feedback: FMEA Web Application FMEA and Control Plans 5
S ISO 13485:2016 ¶ 8.2.1 - How can we obtain feedback for production activities? ISO 13485:2016 - Medical Device Quality Management Systems 5
J AS9100 Rev D Quality Manual Rewritten - Feedback Appreciated Quality Management System (QMS) Manuals 13
L Audit Finding Flowchart for Feedback General Auditing Discussions 6
D Alternatives to Customer Feedback Survey in ISO 9001 Quality Manager and Management Related Issues 4
C 510(k) STED Format - Feedback from users US Food and Drug Administration (FDA) 1
somashekar MDSAP (Medical Device Single Audit Program) Pilot: Please share your feedback ISO 13485:2016 - Medical Device Quality Management Systems 35
C PFMEA RPN - Feedback regarding adjusted RPN FMEA and Control Plans 3
S Seeking Feedback on ASQ Guide to Failure Mode and Effect Analysis FMEA and Control Plans 2
J Looking for feedback from current/former Intelex users Quality Assurance and Compliance Software Tools and Solutions 4
S ASQ CSSBB March 1, 2014 Exam Feedback Professional Certifications and Degrees 7
E Feedback on Negative Experiences with a CB's Service Level Registrars and Notified Bodies 6
E Feedback on the ASQ CSSBB On Oct 5th 2013 Professional Certifications and Degrees 6
smryan Quality Manual - feedback requested ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Customer Survey Assessment Feedback Customer Complaints 11
J Adverse Event Reporting Flowchart (US) - feedback appreciated! Other US Medical Device Regulations 4
J Adverse Event Reporting Flowchart (EU) - feedback appreciated! EU Medical Device Regulations 4
J Flowchart for Canadian Adverse Event Reporting - feedback appreciated! Canada Medical Device Regulations 3
I Feedback on an Environmental Aspects and Impacts Register Miscellaneous Environmental Standards and EMS Related Discussions 5
Crusader Training / Competency Assessment Record for review and feedback Training - Internal, External, Online and Distance Learning 12
T Review of OASIS Feedback - Note on Management Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R Customer Feedback - ISO 13485 Section 8.2.1 - Small Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
A Feedback on Approach to Flowcharts ISO 9001 Process Maps, Process Mapping and Turtle Diagrams 5
C Customer Feedback, Satisfaction, Complaint Procedure and Measurement Customer Complaints 8
B Online User Feedback Customer Complaints 11
V Can we take a Green Belt project to improve the Internal Customer Feedback Six Sigma 6
R Customer Feedback and ISO 13485 Management Review ISO 13485:2016 - Medical Device Quality Management Systems 2
R Is there an ISO 13485 requirement to solicit Customer Feedback? Customer Complaints 5
V Any experience/feedback on statistical software tools...minitab -design expert -JMP Using Minitab Software 4
S Registrar Ranking - Looking for feedback on SAI Global Registrars and Notified Bodies 8
H Process Audit Checklist Example - Feedback Please Internal Auditing 16
J ISO 13485 - Procedure for a Feedback System (Post Market Surveillance) ISO 13485:2016 - Medical Device Quality Management Systems 10
C Feedback Charts for Raw Material QC Laboratory Misc. Quality Assurance and Business Systems Related Topics 1
