File Notes: planned deviations or acknowledged mistakes?
E
esalsan
Dear Covers,
My current employer has a process to document file notes and another process to execute failure investigations. Their interpretation of a file note is a document to acknowledge you have made a mistake and what you did to correct it. Their failure investigations also acknowledge that there was a non-conformance and goes a bit deeper, documenting what was the (root) cause of the failure and links to any possible corrective action.
I am happy with the notion of failure investigations, although I would recognise mistakes as non-conformances and consolidate the two under the same process but my interpretations of a file note is that they document planned deviations to process, rather than mistakes that have been made already.
Which of the two interpretations (if any) is correct? What would be the definition of a file note?
Thanks in advance!
maaquilino
In my experience, failure investigations (FE) took place when a problem was found; many times it was done due to a number of customer complaints coming in for the same/similar thing. Corrective action would be taken to determine the root cause of why this happened and what the resolution was. All failure investigations and resolutions would be documented on appropriate FE forms. A failure investigation could find that the root cause of the problem was not following procedure(s), or it could find it was something completely different.
We used a form titled Deviations when something was found to not have been done according to a documented procedure. A Deviation was defined as something that was done after the fact. The form described why the procedure was not followed, what if anything was done to ensure quality was not adversely affected, and it had to be approved by appropriate management.
We used a form titled Variances when it was planned in advance to not follow a documented procedure, so this Variance form was done and approved prior to the fact of not following procedure, and included a description of, and justification for, why the procedure wasn’t being followed.
We used Deviation and Variance forms outside of FEs as well as part of them, so they were separate procedures and forms from those used in FEs. For example, if certain documentation wasn’t done according to procedure (e.g. we decided to combine two documents into one for a particular project, yet the procedure for these documents names the two of them as separate entities) we would write a Variance to state that we were combining these two procedures and why. If it was discovered the documents were done this way after they were already done, we wrote a Deviation and stated why it was done, that all required info was covered in the one document, and verbiage to show that it didn’t adversely affect anything. Neither instance would have anything to do with a failure investigation.
The non-conformance for not following procedure(s) could have been noticed in an internal/external audit; but the Deviations/Variance forms can, and did, keep an auditor from writing a non-conformance during the audit (unless maybe they didn’t agree with the justifications ;>)
Your file notes sound as though they fit the definition above of how I used Deviations, as they sound as though they’re done after the fact. Some places use the same term Deviation whether something was planned or unplanned, with a place of the form to check if the Deviation was planned or unplanned.
http://www.mddionline.com/article/documenting-failure-investigation
http://apps.who.int/prequal/trainin...ations/Day_2/Good_Documentation_Practices.pdf
K Technical file for mhra CE Marking (Conformité Européene) / CB Scheme 2
J Incoming Inspection Records using Excel File ISO 13485:2016 - Medical Device Quality Management Systems 2
P Letter to file or special 510k or traditional 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A CE-IVD Technical File with Multiple IFUs EU Medical Device Regulations 4
M Office and manufacturing site relocation effect on Device Technical File CE Marking (Conformité Européene) / CB Scheme 2
J Saudi Arabia Technical File Requirements Other Medical Device Regulations World-Wide 1
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
T Letter to file for Product Certification CE Marking (Conformité Européene) / CB Scheme 0
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
K Submission of MDR File - Partner Companies - Computed Tomography (CT) CE Marking (Conformité Européene) / CB Scheme 10
F Software as a Medical Device (SaMD) Technical File Requirements Manufacturing and Related Processes 3
S Technical File for Surgical Mask in Class 1 MDD Elsmar Cove Forum ToS and Forum Policies 1
J Design file for pre-existing products - Inputs and Outputs ISO 13485:2016 - Medical Device Quality Management Systems 5
A Technical File - Updating Applied Standards EU Medical Device Regulations 4
K Identification of hazards and Risk file IEC 62366 - Medical Device Usability Engineering 7
M What to be careful about/focus on when doing a Technical File review EU Medical Device Regulations 4
Watchcat Anyone had an MDR technical file review/audit yet? EU Medical Device Regulations 13
G Same intended use devices - Technical file EU Medical Device Regulations 5
K ISO 13485:2016, Clause 4.2.3 Medical Device File ISO 13485:2016 - Medical Device Quality Management Systems 4
K 510(K) File eCopy Submission 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 16
F Management of Software version while NB reviews Technical file CE Marking (Conformité Européene) / CB Scheme 7
D Risk Analysis & Technical File - What detail goes in the Risk Management Report ISO 14971 - Medical Device Risk Management 5
A Bookmarking my security protected IEC 60601-1 .pdf file IEC 60601 - Medical Electrical Equipment Safety Standards Series 16
R No design history file or device master record ISO 13485:2016 - Medical Device Quality Management Systems 5
R Suggestions for putting together a DHF (Design History File) ISO 13485:2016 - Medical Device Quality Management Systems 3
B We need a QMS: file-based templates or software Other Medical Device Related Standards 23
N Technical file requirements class 1 device MDR Other Medical Device Regulations World-Wide 6
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
pashah Looking for Usability File Template acc. IEC 62366-1 and IEC 60601-1-6 IEC 62366 - Medical Device Usability Engineering 4
D Questions about the contents of a Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
O Medical Device Technical File Confidentiality - On site reviews EU Medical Device Regulations 14
N How to Write and Compile a Technical File for CE Marking CE Marking (Conformité Européene) / CB Scheme 4
M Medical Device Master File - We are a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 7
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
A Defining Expected Service Life in Risk Management File Reliability Analysis - Predictions, Testing and Standards 5
M Technical File (STED) labelling - When you compile tech files do we have to include all the product labels? EU Medical Device Regulations 2
S MDR Technical File Structure Requirements EU Medical Device Regulations 12
D MDD to MDR - Technical File conversion EU Medical Device Regulations 4
T Change to the FDA cleared device (ours) - Submission or Letter to file? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
J Connection between Technical File and Declaration of Conformity CE Marking (Conformité Européene) / CB Scheme 2
M Medical Device News Olympus Medical pleads guilty to failing to file events notice: Justice Department Medical Device and FDA Regulations and Standards News 0
S Medical Device Cybersecurity Risk Management File ISO 14971 - Medical Device Risk Management 2
A The FILE recommended by AIAG MSA 4ed for LINEARITY Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
T Technical File Review - Transfer to a new NB EU Medical Device Regulations 3
K Letter to file vs Special 510 for additional accessory in orthopaedic kit Other US Medical Device Regulations 1
J One Medical Device, two indications, two classes, one technical file? EU Medical Device Regulations 4
A DHF File - Shall the document cover all the variants? Design and Development of Products and Processes 2
C Medical device file for components such as adhesives, gaskets, films, etc. ISO 13485:2016 - Medical Device Quality Management Systems 13
S When should a note-to-file be used in a QMS vs Deviation Report ISO 13485:2016 - Medical Device Quality Management Systems 1
TheMightyWife Virtual Manufacturer v Medical Device File (NB audit) EU Medical Device Regulations 12
