G
For inspection of drilled holes in a lot of metal parts after machining we use GO/NO-GO calibrated pins. As a result of inspection, we fill out an inspection report, consisting of “Measured” and “Required” columns, where we print the dimension of measured diameter of holes via required value.
What should be written in “Measured” column of report? Is it “OK” or a numerical value (for example, diameter of GO pin)?
