Filtering ECR/ECO by quality management? Managing Engineering Changes
Q
QAMTY
Hi everybody
I have the need to start a procedure for managing the change to the engineering documents.
Taking some samples I found on the net, in most of them, first the request
is received by the quality Responsible, then passed to responsible
to perform the change, then continues the flow, ending with the change of the document, obviously the responsible fills out forms and save them.
This way the quality responsible, keeps track of the request received
also notifies to originator about the status. having I think more elements
to have the control
For those of you that have experience on this, Is good practice, to apply the filtering, or let the responsible to receive the request directly? dont´you think the request has to knock a lot of doors? making some kind of bureaucracy.?
I´ll appreciate your responses.
JaneB
If you just look at samples you can find 'on the net' they're not necessarily outstanding samples and they are always based around the particular structure, roles and responsibilities that operate in that particular organisation. Plus, many of them are also based on the writer's understanding and experience with previous models of such procedures, which can also be pretty ordinary and often downright old-fashioned (eg, lots of filling in of forms, some of which can be replaced by good - repeat good - electronic control/permissions. Sometimes I think everyone just keeps copying the same old, same old models ad infinitum...
And yes, many of those I've seen have one great heap of controls and apparent bureaucracy. But what will work well in, say a 50-person shop wouldn't work well in a 500-person organisation.
I'd focus instead on what will work best for you and write your procedure around that.
Try it out, see if it's efficient, and see if it's reasonably well controlled. If it is, go with it. If it isn't, adjust it until it is.
(You know, PDSA... ;)
Marc Filtering Basics - Elsmar's Xenforo software - 19 Novembeer 2018 Elsmar Xenforo Forum Software Instructions and Help 0
Q PPM - Filtering Defects out of calculation Quality Tools, Improvement and Analysis 5
P Specific requirements for filtering in Medical Device Standards IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
M Filtering Help with Excel Excel .xls Spreadsheet Templates and Tools 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H Drowning in ECR/ECO/ECN Document Changes Document Control Systems, Procedures, Forms and Templates 7
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
S ECR - meaning of "Control Item Affected: Yes or no" IATF 16949 - Automotive Quality Systems Standard 1
N Engineering Changes (ECR, ECO, ECN) and how they should be Structured Document Control Systems, Procedures, Forms and Templates 6
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
E Help with ECR/DCR Document Change Control Software Validation Qualification and Validation (including 21 CFR Part 11) 6
A ECR & ECN - Looking for advice and Spreadsheet Example Document Control Systems, Procedures, Forms and Templates 1
V ECR/DCR Process Flow - What changes require an ECR vs. a DCR Document Control Systems, Procedures, Forms and Templates 2
Q ECR (Engineering Change Request) or NCR (Nonconformance Report) in Fabrication? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
Q ECR?s (Engineering Change Requests) in Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M CAR vs ECO/ECN - How do I merge CAR with ECO or ECR/ECN procedure seemlessly Document Control Systems, Procedures, Forms and Templates 5
T From ECR (Engineering Change Request) to ECN (Engineering Change Note) - double work! Document Control Systems, Procedures, Forms and Templates 2
9 ECR (Engineering Change Request) process - Please critique / review Document Control Systems, Procedures, Forms and Templates 10
M Engineering Change Request/Order (ECR/ECO) or Document Change Request/Order (DCR/DCO) Document Control Systems, Procedures, Forms and Templates 30
W Engineering ECR (Engineering Change Request) and ECN (Eng Change Notice) Procedures Document Control Systems, Procedures, Forms and Templates 3
K When to use an Engineering Change Request (ECR) Document Control Systems, Procedures, Forms and Templates 8
O ECN (Engineering Change Notice) to ECR (Change Request) Database with Email Report Document Control Systems, Procedures, Forms and Templates 8
U Advice on Engineering Change Request (ECR) software Software Quality Assurance 4
S ECR (Engineering Change Request) Flowchart - Is this a work instruction Document Control Systems, Procedures, Forms and Templates 9
C Acronym ECR - Acronym Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
G Engineering Change Request (ECR) / Notice (ECN) - Seeking Example Forms Document Control Systems, Procedures, Forms and Templates 21
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
P ECO Disposition - Deviation Needed for Use As Is? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Parts included/not included in ECO/ECN Document Control Systems, Procedures, Forms and Templates 1
M ECO (Engineering Change Order) Record Filing Question Records and Data - Quality, Legal and Other Evidence 1
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
C Documents not controlled by the ECO (Engineering Change Order) process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Introducing a new Product Variant - ECO Process? Document Control Systems, Procedures, Forms and Templates 3
D How to process Customer ECO's (Engineering Change Orders) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ECO (Engineering Change Order) Control for Unreleased Products Document Control Systems, Procedures, Forms and Templates 3
Q How to close the circle QMS and ECO (Engineering Change Order)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Document Control ECO (Engineering Change Order) or QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
Q Are ECO's closed after they are shown to be Effective? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q How raise en ECO starting from a NC - ECO after NCR? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L Developing an Access ECO Tracking Database - Need help Document Control Systems, Procedures, Forms and Templates 8
D Official Clarification of ECO, PDR, PCR Acronym Definitions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D ECO (Engineering Change Order) Risk Management Criteria and QA Document Control Systems, Procedures, Forms and Templates 19
M ECO (Engineering Change Order) Tracking and Status Report Document Control Systems, Procedures, Forms and Templates 1
M How NCR CAR and ECO Interact - Customer Rejection Document Control Systems, Procedures, Forms and Templates 5
T ECO (Engineering Change Order) Implementation checklist/work instruction Document Control Systems, Procedures, Forms and Templates 6
V How to measure ECO (Engineering Change Order) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
