Final inspection process design for a machine shop setting.
sativ
i recently got a job as a quality engineer in a machine shop that fabricates metal parts using CNCs, depending on the customer specs. I am tasked in designing a quality management system from total scratch, for an upcoming ISO 9001certification..
I wonder if you could help me out in the inspection process. since i always go for simplicity, i had chosen FINAL INSPECTION to be the last process prior to shipment. of course there are in-process inspections (done informally by operators, checking dimension after milling,etc.)..
> how can i design an inspection procedure (FINAL) that will not be a hassle to process itself (since some parts have complex forms such that 100% is entirely time-consuming) as well as provide enough confidence in the inspection result...
>> what steps will i take, incase out of sampling i am able to detect a non-conforming product. do i need to inspect all the finish goods?
Thank you.
bobdoering
Stop X-bar/R Madness!!
>> what steps will i take, in case out of sampling i am able to detect a non-conforming product. do i need to inspect all the finish goods?
Sampling is sampling, and you can not eliminate sampling error. But, final inspection can really only be sampling designed to pick out the higher probability problems. 100% inspection is a phenomenal increase in overhead that is difficult to justify - both in labor and equipment costs. The best way to ensure good product is proper control in the process. The information in the process is far more valuable - especially for machining. Predictive decisions come from sequential data - and that is lost in final inspection.
My suggestion is to look through Statistical process control for precision machining to get a good grasp on the process itself.
CarolX
i> how can i design an inspection procedure (FINAL) that will not be a hassle to process itself (since some parts have complex forms such that 100% is entirely time-consuming) as well as provide enough confidence in the inspection result....
100% inspection is often very wasteful. I would look at implementing a sampling inspection program at final. My preference is always a C=O plan.
Thank you.
A C=0 plan requires you to reject the lot and sort out the defects.
Hope this helps a bit.
Boscoeee
Thank you.
I am curious how do you define "final inspection"? I believe that will drive the extent of inspection needed.
Do you have a First Article Process to qualify the process?
Do you have First Piece Inspection program in place?
Do you have a in process inspection program in place?
Answers to this questions may lead other to provide more help!
Good Luck going forward!
With regards to "hassle", I am not sure how you can design an effective inspection system that does not appear to be a hassle (burden) to the work force. IMHO, the goal should be a cost effective program that provides the assurance the customer requirements are met nothing more, noting less.
Project Man
I work in the same environment you do and we have recently revised our QMS as part of our process to become ISO certified. We have three levels of inspection at the Quality Manager level: 1. First Article Inspection 2. In-Process Inspection 3. Final Inspection. After the FA (first artcle) everything is inspected on a lot sample basis. We will sometimes require the operator to document measurements through out the production run. These are reviewed by the QM.
bobdoering
With regards to "hassle", I am not sure how you can design an effective inspection system that does not appear to be a hassle (burden) to the work force. IMHO, the goal should be a cost effective program that provides the assurance the customer requirements are met nothing more, nothing less.
Good point - that is a good difference between inspection and control. Inspection tells you if you made good parts - not very interesting, feels like a hassle. Control gives feedback that the process needs adjustment (when done correctly, before any bad parts are made.) To a good operator, that should be valuable information of ongoing interest.
Wes Bucey
Some good answers so far.
From the description given in the first post, we are dealing with a contract machining environment. Almost by definition, the use of CNC machining and turning centers describes a precision machining environment.
In a precision machining environment, it is not a good practice for in-process inspection to be informal, rather, it should be part of a well-thought out Control Plan for each different product, taking into consideration such things as critical characteristic dictated by the customer and machining "checkpoints" before a final dimension.
Following are links to posts about some practices I deployed in a precision machining environment - perhaps something similar will work for your organization.
Wes Bucey on an efficient shop - empowerment (This is a single post (#18) in a longer thread - the url leads directly to the post - it is associated with a follow-up in post #20)
http://elsmar.com/Forums/showpost.php?p=105469&postcount=18
Wes Bucey on quoting and empowerment (This is a single post (#20) in a longer thread - the url leads directly to the post)
http://elsmar.com/Forums/showpost.php?p=105566&postcount=20
In process and final inspection:
Re: Inspection Dimensional Check Sheets - Over 500 part numbers
Who inspects?
I, too, ran a shop where primary responsibility...
Control Charts
In my high tech machining business (1990 -2000),...
What makes sense?
In point of fact, I have seen several operations...
Jen Kirley
Quality and Auditing Expert
When I worked in a machine shop, our CNC machinists checked the tight tolerance features of their parts frequently based on tool wear, and variation introduced by the environment: temperature and humidity. We could never say we achieved process control, so sampling per ANSI would not work, and if too many parts went by without a check he was apt to lose some.
So, as Wes said a customized inspectionplan could be needed to address the likelihood of certain characteristics going out of tolerance and why.
bobdoering
That is often the case with traditional attempts at CNC controls, but process control in CNC is very possible when done correctly. The real problem in machining is the sorts after a broken tool. Often final inspection sampling will pick up the results of ineffective sorts for that condition - because the sorts are just that bad.
As was mentioned in one of the threads, sampling is god for finding very bad conditions. For very good conditions, sampling will not pick up the rare problem. And, it falls into "inspecting in quality" approach. That is why control and capability are the goal.
T Primary & Secondary Inspection Definitions - Incoming, In-process & Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
C Are these Final Inspection Process Checklists required? Document Control Systems, Procedures, Forms and Templates 10
M Incoming, In-Process, Final and Outgoing Quality Inspection Procedure examples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T In-Process vs. Final Inspection Manufacturing and Related Processes 15
V Sampling Plan for Final Inspection and Process Verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
L In-Process and Final Inspection for a job shop (Machine) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Software or template to manage first piece, in process and final inspection reports Software Quality Assurance 2
V Final inspection as process step in PFMEA FMEA and Control Plans 11
S Kaizen event for the final QA inspection process - Kaizen help Lean in Manufacturing and Service Industries 7
P No In-process or first piece inspection - Final Inspection ONLY! Am I wrong? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 37
K Process Control Plan and Inspection Plans - Receiving and final inspection required? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S 100% Final Inspection Requirements of Active Medical Devices (MDD or IEC Standards?) EU Medical Device Regulations 4
QMMike Software to Record Detailed Final Audit / Inspection Data Software Quality Assurance 2
S Required PFMEA Content - Final QC Inspection FMEA and Control Plans 7
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Goods Inwards And Final Inspection Stamps Document Control Systems, Procedures, Forms and Templates 1
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
N Final Inspection Retesting for Failed Batches Nonconformance and Corrective Action 6
P MDD position on Final Inspection/Release Employee Experience/Training EU Medical Device Regulations 1
P AS9100 and Final Inspection of Machined Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
B "Detection, NOT Prevention!" - Relying on Final Inspection Quality Manager and Management Related Issues 48
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
E Our Lean Initiative Manager is trying to eliminate Final Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Q SMT Final Inspection Sampling Plan for boards off an SMT line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
T CP: Is it feasible to define the inspection equipment as final function tester? APQP and PPAP 12
L Do all gages need calibration or only those used for final inspection? General Measurement Device and Calibration Topics 49
M Control Plan: How to include Final Inspection FMEA and Control Plans 3
T Final inspection and testing of product from validated processes Misc. Quality Assurance and Business Systems Related Topics 1
Z MSA (Measurement Systems Analysis) for gages used in final inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Pre-Inspection & Final Inspection Procedures and ISO 9001 Document Control Systems, Procedures, Forms and Templates 9
R Basic training needs for Final Inspection people Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
V Can give me the sampling plan for Receiving and Final inspection - AS9100? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Final Inspection for Software Product - Functional Test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Final Inspection - 1st Article Dimensions before Anodize and Passivation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H No Final Inspection - Can this kind of a policy meet ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
O Final Inspection - QTY (Quantity) Check - Offset Printing Service Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Determine if your final inspection practices are 'waste' or not Lean in Manufacturing and Service Industries 35
S First Article Inspection in an AS9100 service industry (Final product non tangable) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
X Is final inspection necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S NonConforming product NCR during Manufacturing vs. NCR only at final inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 21
A Final Inspection - Calibrated M&TE (Measurement and Test Equipment)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Final Inspection lot failures - AQL based final acceptance AQL - Acceptable Quality Level 3
J 'Final Inspection' and 'Layout & Functional Testing' - Part of Control Plan? FMEA and Control Plans 9
H Hoeyster QM - Goal: Eliminate "Final Inspection" - Aerospace precision machining AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
Z 4.10.4 Final Inspection and Testing - Wondering what kind of methods you guys use Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Final Inspections - Does 100% inspection really work Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Define Final Inspection Requirements on the Control Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
