Final quality control corrective actions
andrei iuganu
Hello group,
A little help. In the final quality control area, where products from the production line are controlled, what corrective actions can be taken?
Tagin
Is there a specific problem you are trying to resolve? A corrective action typically applies to a specific issue/problem occurrence or pattern.
andrei iuganu
Usually, aesthetic defects are identified - scratches, stains - the parts being made of plastic, or excess material. for example, at 10,000 controlled parts, there are - we assume -1500 stained parts. What is the corrective action for the final quality control?
Sidney Vianna
Post Responsibly
Apparently, you do not understand what a corrective action is. You want to PREVENT such cosmetic defects from happening in the first place. Once the parts are produced with the defects, there is NOTHING a final QC check can do other than sorting good from bad. A true corrective action happens at the production processes which allowed the defect to be introduced.
andrei iuganu
Sidney Vianna
Thank you very much for the answer. I said almost the same thing to my manager, but he wants me to open corrective actions at the level of the final quality control. This is also the reason why I opened this topic. Maybe I misunderstood the concept of corrective action and maybe with your help I clarify.
Big Jim
Tell your boss (if you dare) that the forum suggested the boss needs to be educated.
Corrective actions are incident control. Once an incident has taken place you need to take action to correct it, contain it, and if necessary determine why it happened and what can be done about why it happened.
In your case, if he wants to pursue why there are so many rejects, that goes back much further, likely into design of product or determination of how to make it. It's too late after the parts are made to do anything but sort the good from the bad then determine how far back they are willing to go with design or production planning.
This kind of goes back to you can't inspect quality into a product. Inspection doesn't improve the product, it only tries to catch the bad stuff.
Big Jim
This quote may help:
"Quality is never an accident, it is always the result of high intention, sincere effort, intelligent direction and skillful execution. It represents the wise choice of many alternatives." — Willa Foster
Danisa
Defect rate is 15% => It is big NG rate, that's why your boss asked you the corrective action. In order to improve it, of course you have to investigate the root cause. After finding the root cause you will find out the way of improving and controlling. Plastic part is also 1 of our products. The defect you mentioned here is scratch and stain. How about your 5S status especially the working tables, the gloves, carton box.. products overlapped can cause scratch... If your manufacturer is injection molding, how about the status of mold, the defect was happened on each cavity or not...
Hopefully can help.
Cari Spears
Go ahead and start the corrective action. There is no way that the root cause investigation will not take you back to the manufacturing or handling operation that is causing the defects.
Problem description: Part #123, Batch #456, rejected at final inspection, approximately 1,500 out of 10,000 parts have unacceptable scratches.
Is the scratching happening in the final quality control area? If the answer is no, then follow the process and find which operation is causing it.
L Need an example of an "FQCR" - A final quality control report. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Serialization at Final Quality Check ISO 13485:2016 - Medical Device Quality Management Systems 3
M Incoming, In-Process, Final and Outgoing Quality Inspection Procedure examples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Are all In-Process Quality Records required in final QA Batch Record Review. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
H AS9100C - Do Quality personnel have to perform the In-Process and Final Inspections? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Production duties vs. Final Acceptance Testing - New Quality Manager needs HELP!!! Inspection, Prints (Drawings), Testing, Sampling and Related Topics 36
P Measuring Injection Molding Quality using Weight of final assembly Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
L QMSR Final Rule On Track For December 2023 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Transport of components off site for final assembly. Medical Device Related Regulations 2
Watchcat DE NOVO FINAL RULE IS PUBLISHED Other US Medical Device Regulations 0
Watchcat De novo Final Rule Pending - Inspections 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
W Final Report re: Market withdrawal of radiation-emitting product Other US Medical Device Regulations 0
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
I Mother bobbin final inspection criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Coronary, Peripheral, and Neurovascular Guidewires – Performance Tests and Recommended Labeling Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Intravascular Catheters, Wires, and Delivery Systems with Lubricious Coatings – Labeling Considerations Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final and update guidances – Software Medical Device and FDA Regulations and Standards News 2
M Informational USFDA final guidance – Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Special Premarket Notification [510(k)] Pathway Medical Device and FDA Regulations and Standards News 0
M Informational Final guidance – GUIDELINES on the benefit-risk assessment of the presence of phthalates in certain medical devices covering phthalates which are carc Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Acceptance Review for De Novo Classification Requests Medical Device and FDA Regulations and Standards News 1
M Informational US FDA Final Guidance – Humanitarian Device Exemption (HDE) Program Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final Guidance – Consideration of Uncertainty in Making Benefit-Risk Determinations in Medical Device Premarket Approvals, De Novo Classificati Medical Device and FDA Regulations and Standards News 0
V Removing final inspector for medical device manufacturing Lean in Manufacturing and Service Industries 4
M Informational US FDA Final guidance – Postmarketing Safety Reporting for Combination Products Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Final guidance – Metal Expandable Biliary Stents – Premarket Notification (510(k)) Submissions Medical Device and FDA Regulations and Standards News 0
M Informational US FDA – Requests for Supervisory Review of Certain Decisions Made by the Center for Devices and Radiological Health – Final Rule Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance – Marketing Clearance of Diagnostic Ultrasound Systems and Transducers Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
M Informational US FDA final guidance Characterization of Ultrahigh Molecular Weight Polyethylene (UHMWPE) Used in Orthopedic Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA final guidance – Unique Device Identification: Convenience Kits Medical Device and FDA Regulations and Standards News 0
M Informational USFDA final guidance – Recommended Content and Format of Non-Clinical Bench Performance Testing Information in Premarket Submissions Medical Device and FDA Regulations and Standards News 0
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
M Informational IMDRF final document – Assembly and Technical Guide for IMDRF Table of Contents Submissions Medical Device and FDA Regulations and Standards News 4
M Informational USFDA Final Guidance – Medical Devices Containing Materials Derived from Animal Sources (Except for In Vitro Diagnostic Devices) Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Rule – Human Subject Protection; Acceptance of Data From Clinical Investigations for Medical Devices Medical Device and FDA Regulations and Standards News 0
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M FDA News USFDA Final Guidance – Intent to Exempt Certain Unclassified Medical Devices from Premarket Notification Requirements Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Guidance – Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 2
M Informational USFDA Final Guidance – Coordinated Development of Antimicrobial Drugs and Antimicrobial Susceptibility Test Devices Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Final Guidance – The Least Burdensome Provisions: Concept and Principles Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Report – MDUFA IV Independent Assessment of FDA’s Device Review Process Management Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA – Breakthrough Devices Program final guidance Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA Final Guidance – Manufacturing Site Change Supplements: Content and Submission Medical Device and FDA Regulations and Standards News 1
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
M Medical Device News FDA News - 03-10-18 - CDRH FY 2019 Proposed Guidance Development and Focused Retrospective Review of Final Guidance Other US Medical Device Regulations 0
M CE / FCC Compliance for components + final product CE Marking (Conformité Européene) / CB Scheme 2
