Finding a flat or not modeling distribution: how to manage it?
#21
Every process is multi-modal, based on the Total Variance Equation. Tool wear - the predominate variation in precision machining - is a continuous uniform distribution, but most other errors, such as sampling error, gage error, etc. are normal or otherwise tailed. Add them all up and you get a predominately uniform distribution with small tails contributed by the other factors in the equation.
So this issue should be the reason to stay on 75% spec. values? Then the combination of distributions, getting uniform behavior with tails on the extreme sides?
bobdoering
Stop X-bar/R Madness!!
#22
Exactly. For you, as you know, those variations will be sampling, material thickness, physical properties and temperature, as examples. Most of those variations will be normal. Temperature may be a skewed distribution, if it reaches a steady state at some point in the run.
#23
I don't know (I didn't found till today a clear case like that, about a continuous drift due to wearing) if it's a wearing situation too on stamping, but looking at a control chart, if set on 75% of spec. dimensions, if for a batch the mean shift on, e.g., 5% to upper limit control (that is set to 75% spec.), the chart tells that the process is going however ok (not considering the Western rules), but who tells me that the distribution has no tails going out of spec.? It's not a uniform distribution, you don't find it, it could be normal or not, largest extreme values, etc., the capability in that situation could easily be less than 1.33.
I didn't compared machining process to stamping process, you did it, describing stamping a long-wearing process like the machining one!
So, I could understand and theoretically agree with your assumption on precision machining (uniform distribution+tails of other error noises), but if you get a different distribution, the situation is not like that! So, thinking of it, the uniform distribution could be easier to manage than normal or worse non-normal, with tails to manage!
#24
Tails and 1.33/75%.
All real processes have some amount of tails. NO process fits any theoretical distribution. The problem with the theoretical distribution is that we don't know how large the tails really are. That is why they are almost always 'larger' in the theoretical distribution than in the real process distribution.
The 'goal' of a 1.33 Cpk/Ppk was originally simple: to have reduced variation about the target. Somewhere along the line this got conflated with theoretical defect rates based on a theoretical distribution. Bob correctly recommends 75% of the tolerance so that the process has reduced variation and it allows for some of the tail of a real world '~ uniformly distributed' process.
Sullivan, L. P., “Reducing Variability: A New Approach to Quality”, Quality Progress, July 1984 and “Letters” Quality Progress, April, 1985
Leonard, James, “I Ain’t Gonna Teach It”, Process Improvement Blog, 2013 "I ain't gonna teach it!" - Jim Leonard - Process Improvement
Wheeler, Donald, “Probability Models do not Generate Your Data”, Quality Digest, March, 2009 Probability Models Don’t Generate Your Data | Quality Digest
Pyzdek, Thomas, “Why Normal Distributions Aren’t (All That Normal)”, Quality Engineering 1995, 7(4), pp. 769-777 Available for free as “Non-Normal Distributions in the Real World” at Non-Normal Distributions in the Real World | Quality Digest
Gunter, Berton H., “The Use and Abuse of Cpk”, Statistics Corner, Quality Progress, Part 1 January 1989, Part 2 March 1989, Part 3 May 1989, Part 4 July 1989
J Audit Finding For Not Retaining Test Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
D Customer Audit Finding ISO13485:2016 7.6 ISO 13485:2016 - Medical Device Quality Management Systems 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
G Audit finding - Components being transferred inter-plant Internal Auditing 3
S Difficulty Finding A Notified Body for CE Marking - No Capacity Registrars and Notified Bodies 5
D AEA (Aerospace Experience Auditor) Challenges - Finding availability of AEA for witness AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 14
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
Q Customer Requirements - AS9120B Audit Finding AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 24
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
S Definition Would a wrong definition constitute an Audit Finding? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
L Audit Finding Flowchart for Feedback General Auditing Discussions 6
B Finding a Fixture Design Course to meet Customer Requirements General Measurement Device and Calibration Topics 3
A Audit Finding - CAPA, Improvement Initiatives not filed in CAR System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O CFDA (China Food and Drugs Administration) Audit Finding Classifications China Medical Device Regulations 1
B Expired Materials (threadlocker) Audit Finding Classification? Internal Auditing 1
S Is not training to ISO 9001 procedures a finding? General Auditing Discussions 16
S Could I issue major finding for Inadequate Procedures Supplier Quality Assurance and other Supplier Issues 17
S Finding a substantial Equivalent Medical Device Other US Medical Device Regulations 4
H Cause analysis for an Audit Finding - Purchasing Procedure Content ISO 13485:2016 - Medical Device Quality Management Systems 9
R Finding specific 510k guidance for Keratoprosthesis (MLP) Other US Medical Device Regulations 1
S Is it a Finding if all Internal Auditors are from the Quality Department? Internal Auditing 18
A Writing an Internal Audit Report Finding for Employee Awareness of QMS Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I Finding optimum transformation equation for two sets of data Using Minitab Software 15
S Audit finding for JPAL ISO 13485:2016 - Medical Device Quality Management Systems 1
R Can a external auditor raise a finding that is already identified in Internal Audit ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Validating a stopped test due to never finding any defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Supplier Significant Environmental Aspects - Audit Finding ISO 14001:2015 Specific Discussions 21
C Notification to Customers regarding Major Audit Finding IATF 16949 - Automotive Quality Systems Standard 25
L CB finding on Management Review Meeting Management Review Meetings and related Processes 32
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J 8.3.2.1 Monitoring/Measurement Audit Finding IATF 16949 - Automotive Quality Systems Standard 6
M Finding parts to meet ISO 15001 (Anaesthetic and respiratory equipment) EU Medical Device Regulations 8
J Follow up on Major Audit Finding General Auditing Discussions 15
C ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Finding the best QMS Software Quality Assurance and Compliance Software Tools and Solutions 4
M Internal Audit finding versus External Audit finding General Auditing Discussions 2
cscalise Legal Obligation to report ISO 13485 Finding to FDA? Registrars and Notified Bodies 1
M Finding a hardware supplier/distributor compliant with RoHS RoHS, REACH, ELV, IMDS and Restricted Substances 1
K Need help finding a book on Documentation Book, Video, Blog and Web Site Reviews and Recommendations 8
