Finding Control Limits for a Non-Normal Distribution
anirban
Hi All,
Broad Problem Statement: I have a set of data (prices of electronics goods at different stores). I want to design UCL and LCL from that data set so that if someone comes with a price, I can estimate whether that price might be correct or not.
Explanation: I have prices (20 data points, say) of a handycam with some specification. The distribution is not normal, which means distribution's skewness and kurtosis should be taken care of while formulating UCL and LCL. With a given confidence interval, how can I derive the formula for UCL and LCL.
Please note, we can not assume normal distribution or t-distribution.
Thanks in advance,
Anirban
bobdoering
Stop X-bar/R Madness!!
Re: Finding Control Limits for non-normal distribution
I would run the Distribution Analyzer to determine which distribution most closely matches the data set, then decide on the control limits based on that distribution's characteristics. One question may be are the data points truly independent, and if so, why would they not be normal? If they are not a natural variation, then you need to understand the underlying contributing factors to the distribution - as in preparing the Total Variation Equation.
I hope you weren't looking for a plug and chug....
Steve Prevette
Deming Disciple
If you look at Dr. Shewhart's original work on SPC, you will find that he did consider skewness and kurtosis, but established that average and standard deviation were sufficient for SPC to work. He did invoke the Tchybechev Inequality, which holds for ANY distribution that no more than 11% of the data will be outside 3 standard deviations from the average. Standard UCL and LCL's should work sufficiently regardless of the distrubution.
bobdoering
He did invoke the Tchebysheff's Inequality, which holds for ANY distribution ...
From RANDOM data. Holds limited to no value for correlated or dependent distributions. All of Dr. Shewharts's work was done with many random cause distributions - as in bark thickness. Real life processes do not always exhibit pure random "chance cause" variation, causing conditions where the simplistic application of standard deviations is inadequate.
It is still critical to understand the underlying causes of the variation to assure yourself that the data related to the process is separated from any variation from measurement, etc.- as they will mask the true process distribution with a tidy, yet inconvenient normal distribution.
Also, as you collect data, you will develop one distribution. However, it is a result of many sub-distributions contributed by the factors in the Total Variance Equation. Shewhart states the more of these sub-components there are, the closer to normal the resulting distribution will be. True...masking the size and effect of the original causes and the appropriate control of each - since you can control one cause - not many - with your adjustment. Understanding the distribution of each of the contributors, as will as making the non-process contributors statistically insignificant, will put you in a better position to develop adequate control.
In fact, in some cases the more the resulting distribution appears normal, the less in control the process is!
Again, I hope you weren't looking for a plug and chug....
E Nadcap - Tooling Control - Major Audit Finding (Question) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I ISO 13485 Finding regarding Control of Timer Relays in a Coating Process ISO 13485:2016 - Medical Device Quality Management Systems 4
T TS 16949 Clause 7.5.1.1 - Audit Finding - Control Plan Requirements IATF 16949 - Automotive Quality Systems Standard 11
M Control of Nonconforming product, Clause 8.3 - Audit finding - No Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Ron Rompen Audit Finding or Nonconformance? Gage cited on Control Plan and Inspection Record IATF 16949 - Automotive Quality Systems Standard 13
C Question on Finding - BSI Stage 2 ISO 13485:2016 Certification - PMS ISO 13485:2016 - Medical Device Quality Management Systems 5
G Appeal of Nonconformance Finding Nonconformance and Corrective Action 40
Q Question on finding • Failure to follow Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Doninina PSUR and main finding of PMCF EU Medical Device Regulations 2
T FAI Finding Prevention AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
M How to respond to 483 validation finding we disagree with? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 33
E Audit Finding - Measurement of Process - Continuous Improvement - Trend Analysis Oil and Gas Industry Standards and Regulations 22
R Finding Equivalent Material Information Manufacturing and Related Processes 1
G During internal audit - finding poor action plans ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Sidney Vianna Informational Clarification: Finding is NOT synonymous with nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Unable to close a finding raised from BSI last year ISO 13485:2016 - Medical Device Quality Management Systems 12
S Audit Finding - Design History File (DHF) Index: few (3 to 4) reports not identified ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Finding Independent License Holder (Medical devices) in Philippines Other Medical Device Regulations World-Wide 1
somashekar Stage 1 Finding. Request views and comments ISO 13485:2016 - Medical Device Quality Management Systems 3
D Finding Optimum Design Parameters using Taguchi method? Using Minitab Software 2
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
Ed Panek Auditor MDR (Presub audit) finding EU Medical Device Regulations 2
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
F Closing a finding before closing meeting General Auditing Discussions 25
J Audit Finding For Not Retaining Test Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
Marco Bernardi Finding a flat or not modeling distribution: how to manage it? Capability, Accuracy and Stability - Processes, Machines, etc. 24
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
D Customer Audit Finding ISO13485:2016 7.6 ISO 13485:2016 - Medical Device Quality Management Systems 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
G Audit finding - Components being transferred inter-plant Internal Auditing 3
S Difficulty Finding A Notified Body for CE Marking - No Capacity Registrars and Notified Bodies 5
D AEA (Aerospace Experience Auditor) Challenges - Finding availability of AEA for witness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
Q Customer Requirements - AS9120B Audit Finding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
