Finding Equivalent Material Information
I've been doing a bunch of PPAP reviews recently in which the material that is used for the PPAP differs from what is on the drawing. When that happens I have to turn on research mode and try to determine if the material used is equivalent to the drawing spec. Usually, I will do a Google search which may or may not help me find what I need. This of course takes time away from reviewing and since I have several new programs coming at me, time is in short supply.
Most of my drawings come from Japan so they use a JIS spec while my US suppliers will use a different spec for the same equivalent material.
Is there a site that I can go to that will easily provide the information I need to determine if a material is an equivalent?
John Predmore
PPAP is a risk-reduction activity. I will talk about machined steel parts because I have more experience with those. There are websites which provide cross-reference tables based on alloy composition in various national steel specifications,. But chemical composition is only a portion of material selection consideration. Many components or features in an assembly are not in a demanding role, but some are, and the level of technical review should correspond to the level of technical risk. If you are less than thorough in your PPAP review, you may be left with a lot of risk, more than you should knowingly accept. I recommend a PPAP review team of subject matter experts who collectively know a lot about material properties and fabrication technology and the particular design application.
I had PPAP review responsibility a few years back, when the final product assembly was out-sourced, and the contract manufacturer wanted to source many parts and raw materials from the other side of the world. I remember a debate over the PPAP for a half-inch hex shaft in a wear application. The original part design called for cold-drawn half-inch hex bar, but inch sizes are impossible to source locally in Asian countries, so the potential supplier submitted PPAP on a hex shaft turned from a round-bar. The machined hex shaft PPAP satisfied all print dimensions, although the print did not include tolerances for hex angles and edge conditions between faces, because those reference dimensions are defined in steel bar standard handbooks. Because the shaft was used in a wear application, and knowing that a machined shaft would not have the work hardening of a cold-drawn bar, the team decided the machined alternative shaft would have to be re-validated for durability in the assembly. There was no appetite for the cost or lead-time to life-test the shaft in the assembly, so the machined alternative shaft was rejected as not-conforming to the part print. The moral of the story is, the part design print defines more than just the material callout and dimensions on the print.
S Finding a substantial Equivalent Medical Device Other US Medical Device Regulations 4
Doninina PSUR and main finding of PMCF EU Medical Device Regulations 2
T FAI Finding Prevention AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D ISO 14001 Finding - Missing Safety Data Sheets ISO 14001:2015 Specific Discussions 2
M How to respond to 483 validation finding we disagree with? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 33
E Audit Finding - Measurement of Process - Continuous Improvement - Trend Analysis Oil and Gas Industry Standards and Regulations 22
G During internal audit - finding poor action plans ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Sidney Vianna Informational Clarification: Finding is NOT synonymous with nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Unable to close a finding raised from BSI last year ISO 13485:2016 - Medical Device Quality Management Systems 12
S Audit Finding - Design History File (DHF) Index: few (3 to 4) reports not identified ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Finding Independent License Holder (Medical devices) in Philippines Other Medical Device Regulations World-Wide 1
somashekar Stage 1 Finding. Request views and comments ISO 13485:2016 - Medical Device Quality Management Systems 3
D Finding Optimum Design Parameters using Taguchi method? Using Minitab Software 2
Mikey324 External calibration - Finding in our 3rd party audit General Measurement Device and Calibration Topics 58
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
Azaarus Help with CAPA for an IATF finding regarding inspection documentation IATF 16949 - Automotive Quality Systems Standard 10
Ed Panek Auditor MDR (Presub audit) finding EU Medical Device Regulations 2
R Using R package to implement Bayesian phase I/II dose-finding design for three outcomes ISO 13485:2016 - Medical Device Quality Management Systems 6
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
F Closing a finding before closing meeting General Auditing Discussions 25
J Audit Finding For Not Retaining Test Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A OHSAS 18001 external auditor finding personal interpretation? Occupational Health & Safety Management Standards 5
E Received a Major finding during IATF Surveillance audit for loss of BIQS Level 3 (more than 6 SPPS in 6 months)...how should we address SYSTEMIC CA? IATF 16949 - Automotive Quality Systems Standard 11
Marco Bernardi Finding a flat or not modeling distribution: how to manage it? Capability, Accuracy and Stability - Processes, Machines, etc. 24
H Looking for Tips on finding an IATF consultant Consultants and Consulting 6
D Customer Audit Finding ISO13485:2016 7.6 ISO 13485:2016 - Medical Device Quality Management Systems 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
XRAY_3121 Design and Development Requirement - MDSAP Audit Finding Other Medical Device Regulations World-Wide 5
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
G Audit finding - Components being transferred inter-plant Internal Auditing 3
S Difficulty Finding A Notified Body for CE Marking - No Capacity Registrars and Notified Bodies 5
D AEA (Aerospace Experience Auditor) Challenges - Finding availability of AEA for witness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B IATF 16949 7.1.5.3.2 FAQ #7 Audit Finding - External Calibration Laboratory IATF 16949 - Automotive Quality Systems Standard 7
P Major Finding Elevation - Do I elevate this minor finding to a major one? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
S GM/VP softgrading internal audit finding - need feedback from an audit guru! General Auditing Discussions 11
Q Customer Requirements - AS9120B Audit Finding AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
J IATF 16949 registration - Major Nonconformance Finding IATF 16949 - Automotive Quality Systems Standard 9
J Hardness inspection Audit Finding Employee error Nonconformance and Corrective Action 6
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
AlienraverX How to appeal a major audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
T Non-addressed Minor Finding elevated to Major Finding Internal Auditing 37
S Definition Would a wrong definition constitute an Audit Finding? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
L Audit Finding Flowchart for Feedback General Auditing Discussions 6
B Finding a Fixture Design Course to meet Customer Requirements General Measurement Device and Calibration Topics 3
A Audit Finding - CAPA, Improvement Initiatives not filed in CAR System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O CFDA (China Food and Drugs Administration) Audit Finding Classifications China Medical Device Regulations 1
B Expired Materials (threadlocker) Audit Finding Classification? Internal Auditing 1
