First Article Inspection Criteria for Medical Device Manufacturers
L
Lbrager
From a regulatory standpoint, is a medical device manufacturer required to verify every dimension/specification on a drawing as part of first article inspection for a new part? Can the manufacturer take a risk based approach if it is not feasible to verify every dimension? The alternative would be to verify every critical to quality specification and to rely on the supplier's FAI results for the remaining verifications.
For the aerospace industry AS9102 requires that anything noted on the drawing be verified, however I am uncertain if a similar requirement exists for the medical device industry.
-Laurie
Ronen E
Problem Solver
Moderator
-Laurie
Hello and welcome to the cove :bigwave:
I'm not aware of a similar requirement to verify everything on the drawing, in a medical device regulation or international standard.
Risk-based approach is common with medical devices, and if you have reasonable justifications documented (and readily accessible) you should be all right in most cases.
I'm not 100% sure I understand what stage you refer to by "as part of first article inspection for a new part", though. Do you refer to the beginning of every batch / lot production run, or to the first lot ever produced? If you refer to the first case, then I would say yes, it makes a lot of sense to verify critical requirements and handle all the rest with less rigour (it is up to you to decide how - e.g. rely on your supplier FAI - and document your justifications); If the latter then I would recommend everything is verified and documented at least once as part of a proper design and development process.
Please also note that requirements validated as part of process validation do not formally require verification on a regular basis, though you might like to monitor the process performance at some level, as a safety measure.
Cheers,
Ronen.
Q
Quality Practitioner
I would agree with Ronen.
There is no regulatory standpoint that I am aware of that requires every dimension to be inspected?
I work for a subcontract medical device manufacturer.
The first time we manufacture a new device we perform a FAI on all dimension/features on the drawing. We will identify with our customers the CTQ's and run validations to prove capability depending on the feature and validation outcome we may continue to 100% inspect routinely or go to a sampling plan. Generally for CTQ's we 100% inspect and on other features use an appropriate sampling plan. Our Customer may also dictate that we 100% inspect all features/dimensions, but this is rare and most are satisfied with a acceptable process capability
Cheers
Chris
Q
Cheers
Chris
shethprati
If I am getting First Article Inspection performed by external Lab, does that lab need to be ISO 17025 certified?
I know a company who got a finding from notified body for not performing calibration from ISO 17025 lab?
What about First Article Inspection since ISO 17025 includes test and calibration?
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Question on First Article Inspection referencing ISO 2768 APQP and PPAP 1
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Delta or Partial FAI (First Article Inspection) - What are the differences? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K FAI (First Article Inspection) using Digital Design Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G First Article Inspection Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
R How to draft a good First Article Inspection Procedure (when AS9100 is overkill) APQP and PPAP 6
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L FAI (First Article Inspection) of Prototype Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K First Article Inspection - What are the Documents that need to be submitted with it? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
O AS9102 (rev.a) First Article Inspection Requirement Quality Manager and Management Related Issues 1
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
S First Article Inspection - General Practices for Medical Device Manufacturers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q AS9100 and FAIR (First Article Inspection Report) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Selling Products Produced before First Article Inspection (FAI) Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q How to move from Supplier First Article to Sampling Inspection Supplier Quality Assurance and other Supplier Issues 4
E Understanding terminology for FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
AnaMariaVR2 Rapid Deployment Tips to Prepare for an Inspection Quickly (Article) US Food and Drug Administration (FDA) 0
T FAI (First Article Inspection) - How many parts are measured AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J FAI (First Article Inspection) Do as I say not as I do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A When to do First Article Inspection - AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L 8.2.4.2 First Article Inspection - Does every new part that is run require a FAIR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
P Design Characteristics of the FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P First Article Inspection - FAI for every new product launch AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
T First Article Inspection - Is FAI Design Verification? Design and Development of Products and Processes 3
