First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go
K
kidstonkai
Hi all,
I have a customer who have rejected FAIRs because there maybe a dimension, e.g. Ø1.001/1.003", where I have put down a Plug Gauge as a measuring equipment. Obviously the part conforms to the plug gauges that were used.
They have said that they WANT dimensions results written and all future First Articles will be rejected if no dimension results are used.
I have always gone by the whole "Physical over Mechanical". I have never read, in any of the SAE or ISO standards that you have to write down a dimensions for tolerance features, for First Article Inspection Reports.
My question:
If a plug gauge was used for the Inspection, and conforms, can a FAIR be rejected because no dimension was written? If so, where is this written and which standard?
K
kidstonkai
Can't you write the dimension of the plug? So if a 1.002 plug fits, but a 1.003 does not, write 1.002. I think most people want an actual number to "prove" that you actually checked it.
It states that, as long as you write down the plug sizes and the part fits the correct gauges, then the information given is correct.
I just do not know where I stand about telling my customer where to swivel.
I have given the gauge number and the GO/NOGO sizes of the gauge. Fingers crossed.
K
kidstonkai
FYI
I do have a CNC CMM to measure the part but it's the principal of wanting to use a gauge in my FAIR.
try2makeit
Do you have to submit the FAIR each time the part is shipped? Or is this the initial FAIR when the part is produced for the first time ever?
try2makeit
Ahha..
Support your Customer by submitting the dimensional layout. Also submit a gage R&R for the plug gage, add it to the control plan under your first piece inspection, add it in the checking aid section on the PSW. That should cover you for the future FAIR's performed.
Also re-check their requirements in the supplier manual if they issue one. Is it a actual requirement or a SQE "want".
optomist1
A Sea of Statistics
Go/No-Go, provides limited insight as to what the process is doing...where it is headed, is the tool wearing out prematurely, is the fixture worn out, etc. etc. Continuous or variable data trumps Go/No-Go because of the insight it provides...before parts start failing a Go/No-Go gage. Kind of an early warning...
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 16
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Delta or Partial FAI (First Article Inspection) - What are the differences? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K FAI (First Article Inspection) using Digital Design Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L FAI (First Article Inspection) of Prototype Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Selling Products Produced before First Article Inspection (FAI) Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Understanding terminology for FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T FAI (First Article Inspection) - How many parts are measured AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J FAI (First Article Inspection) Do as I say not as I do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Design Characteristics of the FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P First Article Inspection - FAI for every new product launch AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
T First Article Inspection - Is FAI Design Verification? Design and Development of Products and Processes 3
M Measure "TYP" dimensions on a first article inspection (FAI) report? ISO 13485:2016 - Medical Device Quality Management Systems 10
I FAI (First Article Inspection) for Bulletproof Glass normally for Autos? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I FAI (First Article Inspection) for Chemical companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Help needed with brilliantly engineered FAI (First Article Inspection) form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I FAI (First Article Inspection) per AS9102A include gen. notes on form 3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
gard2372 Our Parent company is our supplier? FAI (First Article Inspection) not required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 35
A AS9100 Clause 8.2.4.2 - First Article Inspection (FAI) - How do you comply? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Discus Software for First Article Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Question on First Article Inspection referencing ISO 2768 APQP and PPAP 1
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
