First Article Inspection - Is FAI Design Verification?
tomnmiami
I am writing out Design Output procedure for ouro medical device firm, and am wondering it First Article Inspection Reports are commonly considered a design verification?
I assume its a form of design output, is that correct?
How are sample sizes usually selected for a FAI?
Thanks in advance,
Jen Kirley
Quality and Auditing Expert
Re: First Article Inspection - is it Design Verification?
Design verification is done with a prototype, which could be subject to testing. If destructive testing is needed, then your design might need to be verified with more than one prototype sample...
The first piece refers to the production setup when commencing a run of product to sell.
First Article Inspection isn't a sample. It's verifying setup to prepare for production run. Inspecting ___ out of a batch/lot of ___ in a production run is a sample.
To summarize:
Design
Produce one or more prototypes
Inspect and test the by-golly out of it; diligently record results - maintain the record.
When ready, set up for production run
Do a 1st Article inspection; record the results - maintain the record
Commence run once the setup is verified satisfactory
Do sampling inspections according to Sampling Plan. Record results, maintain the records and respond as per the Plan.
tomnmiami
Thanks Jennifer,
Great explanation!
Do you think it would be improper to have successful FAI as the conclusion of Design Transfer (evidence that manufacturing can produce the designed product), with ongoing recieveing inspections as means of monitoring process control from suppliers.?
BTW, we procure all finished product via contract manufacturers.
Thanks,
andygr
The submitial of a FAI report with the first shipment is a common practice to ensure that the supplier has the capability of making the part to design requirements. As you mention this does not mean that they will always do so in the future and so based on risk and analysis you will have RI verify future shipments accordingly.
The FAI is a good tool to uncover many oppertunities early on with a supliers ability to meet design.
:2cents:
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Delta or Partial FAI (First Article Inspection) - What are the differences? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K FAI (First Article Inspection) using Digital Design Data AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
C Inexperienced Mechanical Inspectors and FAI's (First Article Inspection) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L FAI (First Article Inspection) of Prototype Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S FAI (First Article Inspection) during Assembly of Sub-Assemblies Only AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
F Can you reference original FAI (First Article Inspection) after Delta? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R FAI (First Article Inspection) Report Number Method AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
H FAI (First Article Inspection) Software Recommendations and Help Quality Tools, Improvement and Analysis 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Selling Products Produced before First Article Inspection (FAI) Approval AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
E Understanding terminology for FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T FAI (First Article Inspection) - How many parts are measured AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J FAI (First Article Inspection) Do as I say not as I do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Design Characteristics of the FAI (First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P First Article Inspection - FAI for every new product launch AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K Incoming Materials First Article Inspection (FAI) Procedure needed Document Control Systems, Procedures, Forms and Templates 2
M Measure "TYP" dimensions on a first article inspection (FAI) report? ISO 13485:2016 - Medical Device Quality Management Systems 10
I FAI (First Article Inspection) for Bulletproof Glass normally for Autos? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I FAI (First Article Inspection) for Chemical companies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M Help needed with brilliantly engineered FAI (First Article Inspection) form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
I FAI (First Article Inspection) per AS9102A include gen. notes on form 3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
gard2372 Our Parent company is our supplier? FAI (First Article Inspection) not required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 35
A AS9100 Clause 8.2.4.2 - First Article Inspection (FAI) - How do you comply? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
C Discus Software for First Article Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Sample of 1st Article Inspection Report wanted APQP and PPAP 3
C AS9100, Clause 8.5.1.3 - First Article Inspection Costs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P Question on First Article Inspection referencing ISO 2768 APQP and PPAP 1
V KPI (Key Performance Indicators) in First Article Inspection Lean in Manufacturing and Service Industries 4
J Inspection Software to Balloon Drawings and Create First Article Reports Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
