First Pass Yield Base Line Measurement
ricoamn72
Hi everyone. I have a question over the calculation of FPY. I know that when applying the calculation you simply multiply the yield value of each consecutive process. So, as the unit travels from A to B to C, the FPY value of A, B & C is multiplied together to determine an overall process yield. However, what happens when two sub-assembly components are essentially made in parallel, & then come together to form part of the final assembly?
so,
Process A = sub assembly # 1
Process B = sub assembly # 2
Both Process A & B are independant & have their own FPY value.
Process C = Sub assemblies 1 & 2 assembled to main unit & tested along with other components.
Would FPY% in this case be, the lower value of A or B, multiplied by C to essentially give you the lowest or worst case? Maybe someone can shed some light on this for me. thanks.:)
1
12stones
First, I assume you're talking about Rolled Throughput Yield (RTY) which is the multiplication of each FPY. The FPY is the end result of each process. In this case, you're measuring the whole process, so you would calculate RTY in the standard way.
FPY^A * FPY^B * FPY^C
Don't try to overthink it. Just because A & B happen simultaneously doesn't mean the measurement changes. Each one has their own FPY which is used for the RTY calculation, regardless of when they happen.
ricoamn72
Thanks 12stones. I'm not 100% on the terminology. I know in a previous position with another company we calculated the 'RTY' by multiplying all the individual FPY values together. It was referred to as 'overall FPY', but all the process steps were consecutive. I'm in a new job with a new company & currently they only look at the final step of the process so I want to expand it but wasn't sure how to handle the parallel steps. Thankyou for your response.
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
B Calculation of First Pass Yield (FPY) Six Sigma 9
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
F First Pass Yield Helped Requested Lean in Manufacturing and Service Industries 1
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
P FPY (First Pass Yield) calculation acceptable? Quality Tools, Improvement and Analysis 2
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
J Metrics to be put in place in our Test department - First Pass Yield and Paretos Quality Tools, Improvement and Analysis 6
L Is there any relationship between Cpk & Right First Time? First Pass Yield (FPY)? Capability, Accuracy and Stability - Processes, Machines, etc. 4
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
A IATF certification for pass through supplier IATF 16949 - Automotive Quality Systems Standard 1
S How can a R&D center pass IATF 16949 certification? IATF 16949 - Automotive Quality Systems Standard 9
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
K UL 6601 - Would an off-the-shelf Android tablet, powered by USB, pass UL 6601? Other Medical Device Related Standards 3
Q Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B What is the implication for someone who does not meet the 70% pass mark for QMS-Lead. Professional Certifications and Degrees 2
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
N VDA 6.x - Requirements Pass Down to Suppliers ....Obliged?? VDA Standards - Germany's Automotive Standards 5
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Contractor Pass required for Contract Cleaners? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
K False Pass/Fail Information from GR&R (Gage R&R) Minitab Using Minitab Software 6
I Service Supplier Rating where Objective Pass/Fail Data is not Available Service Industry Specific Topics 7
R ASQ CQE Practice Exam - Do I need to score very well to pass? Professional Certifications and Degrees 17
R Pass Thru Gage for Straightness for a Floor Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Is the up-dated ISO 9004:2009 needed to pass audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
QMMike Repercussions of letting your ISO/TS16949 RR date pass.... IATF 16949 - Automotive Quality Systems Standard 3
K Pass Thru Calibration Certificates? Out-Sourcing Calibration to 3rd Party General Measurement Device and Calibration Topics 6
D Cytotoxicity testing to ISO 10993-5 results - Is 1/ mild a pass or fail? Other Medical Device Related Standards 7
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Marc Verified Identity Pass closes its doors - More Airport Fun Travel - Hotels, Motels, Planes and Trains 2
A Ford Material Specifications - Must pass WSB-M4D638-B vs. WSS-M4D-638-B Customer and Company Specific Requirements 3
