First Pass Yield (FPY) of a Manufacturing Site?
tariq18
Quality Engineer | Lead Auditor ISO9001
Hello experts,
May be its a stupid question but I was wondering what's the best approach to calculate first pass yield of a manufacturing site if you have more than one production line producing different range of products?
Option-1: Calculate no. of batches produced at all the lines and check total failures to calculate FPY.
Option-2: Calculate FPY of each line then take average? .......wait a sec........ should we take average here or multiply FPY of each line to get total FPY(as what we do to calculate Rolled Throughput Yield RTY) , its really confusing isn't it?
Would love to hear feedback fromeveryone!
Thanks,
When you aggregate data, you lose actionable information. You are better off analyzing yield at the detail level, whether that is by line, by product, or both, so you can identify and target the areas with the lowest yield for improvement.
Zero_yield
"You can observe a lot by just watching."
Depends heavily on what you're trying to do with the information. We calculate several different metrics that are used for several different purposes.
One metric is "right the first time", which is essentially number batches not attached to a nonconformance divided by the total number of batches, as a percentage. It's calculated for each production line at a very high level, and is usually 99%+. It's mostly there as an early-warning system for spikes in nonconformances.
We have other metrics that get deep in the weeds of the exact breakdown of rejects by every product family and production line.
Ultimately, I think it's best to have a mix of high level and detailed breakdowns - it's easy to have too high an overview and miss details, and it's easy to miss the forest for the trees. Just keep in mind what the goal of each item tracked is.
tariq18
As far as I understand FPY and Right first time(RFT) is same thing. we also do RFT and its always 99%+ but the problem with this high level RFT is missing details as you mentioned, and management is not aware of real issues on the floor. another problem with RFT/FPY is it does not count reworks/scraps.
But anyways thanks for the reply, my second question was if I record RFT for each line, should we then calculate mean/avg. RFT of all lines combined or we should just multiply them all with each other as what we do in case of rolled throughput yield.?
Mike S.
Happy to be Alive
What if Line 1 has a first pass yield (however you measure that) of 90% and Line 2 has a yield of 99%. You'd wanna focus on Line 1, right? Well....maybe not. Maybe actual losses to the company are higher on the 1% from Line 2.
So why are you measuring FPY? Clearly state the goal of measuring FPY. Then collect the data in a way to help you achieve that goal. There is no reason to collect data unless you plan to take action as a result. So many times I see data collected and no one pays any attention to it.
I really enjoyed watching a Plant Manager go on and on for 15 minutes telling a customer about all the data (many dozens of pages posted on carpeted wall panels) they are collecting for each line and how the andon lights tell anyone walking by if things are going well for that line or not, etc. etc. ad nauseum. The customer patiently waited until the guy was done and asked why the light was green for Line 1 when the data showed they had a lot of defects for the last 2 weeks with no apparent change and no actions being taken.
After the PM got the stunned look off of his face he babbled about manpower shortages and how people from Line 1 had to be moved to another line to help out there, etc. It was not a good look.
Zero_yield
I actually had not heard of a Rolled Throughput Yield before. It does sound like a useful tool to meet your situation (i.e., trying to explain to management how much rework and waste is going on).
…management is not aware of real issues on the floor. another problem with RFT/FPY is it does not count reworks/scraps.
First and most importantly is that FTY (and RFT) is SUPPOSED to include reworks and scraps. Period. The only reason to exclude them is to fool yourself that things are better than they are. The ENTIRE POINT of FTY is to include rework as well as scrap. (I hope this was a misstatement but it doesn’t feel that way)
Second FTY by itself is pretty meaningless and shouldn’t be ‘averaged’. It was intended that the FTYs of each step are MULTIPLIED together. (This is based in the rules of conditional probability. What is the probability that any given unit of product passes they the entire process without a single defect…). This metric is Rolled Throughput Yield or RTY. The individual step FTY is valuable in telling you which steps are the most troubling but averaging them hides this information.
Third: RTY is intended to be calculated for each unique product manufacturing line. Aggregating RTY (or the meaningless FTYs) into some large overall metric is not informative or actionable. It may be mathematically interesting but it does nothing to improve the quality of your processes and products.
A great simple article on RTY is: “Yield the Right Way” by Thomas Pyzdek. It is free…
If you want to geek out on math try “Statistical Quality Control of a Multistep Production Process Using Total Process Yield” by Spencer Graves (Quality Engineering, 1998). This is not a free article, has limited utility for real life quality engineering (just too complicated) but is interesting and informative.
tariq18
Well, we have 4 to 5 single step production lines and one multistep (for which I am planning to use RTY as exactly what you mentioned), & for single step production lines, FTY is enough. My only question to you is how do we include reworks and scraps in FTY?
My question why I start the thread was, how do I calculate then overall FTY of this manufacturing site? What's the best approach?
Anyways, thanks for the links, its quite useful.
I’m not sure wha tyou are including in your FTY calculation besides rework and scrap…but here is what you do for a single step process
Say you start 100 units. 4 units are rejected. 1 is used as is, 2 are reworked and pass and 1 is scrapped. FTY = 100-4/100 = 96%.
As for a manufacturing site FTY, I still say don’t do it. Every metric needs a purpose. Every metric should be actionable (even if it means you have to break down the elements of the metric which is typical). What is the purpose of a site wide FTY? I think there is something critical that you are missing here so really think about it…If we know what you are trying to understand with a site wide FTY we can help you get to a useful metric that satisfies that need. I don’t see any useful purpose for a site wide FTY. At all. Ever.
tariq18
This is exactly how I calculate FTY for single step process. 2 units reworked here are not included in your FTY. This is what I meant before.
So those units needed rework, have to go though process of internal NCRs etc.
Here I have another question, when you rework those 4 units, do you again consider them into your FTY stats?
For site FTY, we have more than 3 sites across the country and senior management has set some targets for each site, that's why we need site wide FTYs.
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
B Calculation of First Pass Yield (FPY) Six Sigma 9
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
P FPY (First Pass Yield) calculation acceptable? Quality Tools, Improvement and Analysis 2
L Is there any relationship between Cpk & Right First Time? First Pass Yield (FPY)? Capability, Accuracy and Stability - Processes, Machines, etc. 4
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
F First Pass Yield Helped Requested Lean in Manufacturing and Service Industries 1
R First Pass Yield Base Line Measurement Lean in Manufacturing and Service Industries 2
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
J Metrics to be put in place in our Test department - First Pass Yield and Paretos Quality Tools, Improvement and Analysis 6
H Is it a requirement for run charts to have inspection data or can it have just a pass/fail check mark Records and Data - Quality, Legal and Other Evidence 4
M Customer PPm (CPPM) on Pass-Thru Items Statistical Analysis Tools, Techniques and SPC 0
H Pin Gauges - tight fit = pass or fail? Reliability Analysis - Predictions, Testing and Standards 9
C Pass through characteristics on PFMEA FMEA and Control Plans 3
E Calibration-Conditional Pass Measurement Uncertainty (MU) 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
A IATF certification for pass through supplier IATF 16949 - Automotive Quality Systems Standard 1
S How can a R&D center pass IATF 16949 certification? IATF 16949 - Automotive Quality Systems Standard 9
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
K UL 6601 - Would an off-the-shelf Android tablet, powered by USB, pass UL 6601? Other Medical Device Related Standards 3
Q Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B What is the implication for someone who does not meet the 70% pass mark for QMS-Lead. Professional Certifications and Degrees 2
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
N VDA 6.x - Requirements Pass Down to Suppliers ....Obliged?? VDA Standards - Germany's Automotive Standards 5
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Contractor Pass required for Contract Cleaners? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
K False Pass/Fail Information from GR&R (Gage R&R) Minitab Using Minitab Software 6
I Service Supplier Rating where Objective Pass/Fail Data is not Available Service Industry Specific Topics 7
R ASQ CQE Practice Exam - Do I need to score very well to pass? Professional Certifications and Degrees 17
