First Pass Yield - Welding Process Improvement
Tratori
hi all, this is my first discussion in this great forum and I hope to learn much from you all.
I'm working on implementing FPY project in one of our cells. we had FPY of 54% in Welding process which is ver very low and affecting our CoQ.
any Idea how to improve the welding process? My manager think of doing Training plan for the welders, I'm not familiar with planning much.
anyone help please ?
Thanks in advance :bigwave:
Jen Kirley
Quality and Auditing Expert
Re: FPY - welding process improvement !!
Welcome to the Cove! :bigwave:
Welding is a big subject. Let us think it terms of man-material-machine-environment. In order to know whether training would help, first there should be a review of materials, machine and environment. Diagnosis of welding problems requires symptoms, but we also need to know what welding process you are using. Arc? Mig? Tig? Something else? What material is being welded? What rod/wire and/or gas is being used?
So please tell us what welding process is involved, and the types of weld flaws. There can be many factors, and sometimes more than one combined.
kgott
I think your manager is right. You will need to train and let welding operators practice for the standard they need to meet.
Part of your plan will need to address reducing variation in the variables which means you will need to calibrate your welding machines so that amp and voltage are accurate. I assume you are using a welding specification for each type of process used and for each type of joint weld.
You may even need to calibrate the hot box's if you use the manual metal arc process.
Its been a long time but Im sure there is an ASME standard where all this is set out. You might like to get customer input or approval for the design and specification and standard for welds.
This is applicable processes used a Jennifer said, materials used and any NDT requirements. Once you've got all this sused then you can train your welding operators to meet the standard.
You will also need to establish an in process inspection plan to test completed welds on a random or specified basis
DRAMMAN
When ever I work on a project to improve very low yields I start with the basics.
-is the process documented.
-is the process mapped.
-Operator training
-equipment calibration and maintenance
-fixturing
-quality of equipment, consummables, fixturing
-Are you tracking your defects with a basic Pareto chart. Attck the #1 issue and then move to #2.
-Do an PFMEA.
-5S the work area.
-Set-up procedures and verification.
B How to begin tracking FPY (First Pass Yield) and "Downtime" tracking Manufacturing and Related Processes 3
B Calculation of First Pass Yield (FPY) Six Sigma 9
L Definition Throughput Yield (TPY) or First Pass Yield Calculation - Help Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
S How to Calculate Overall FPY (First Pass Yield) Quality Tools, Improvement and Analysis 2
F First Pass Yield Helped Requested Lean in Manufacturing and Service Industries 1
R First Pass Yield Base Line Measurement Lean in Manufacturing and Service Industries 2
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
M Developing a CPI for First Pass Yield Final Inspection - Need help Quality Tools, Improvement and Analysis 7
P FPY (First Pass Yield) calculation acceptable? Quality Tools, Improvement and Analysis 2
E Normalized vs. Rolled Throughput Yield - First Pass Yield metrics for our processes Manufacturing and Related Processes 16
J Metrics to be put in place in our Test department - First Pass Yield and Paretos Quality Tools, Improvement and Analysis 6
L Is there any relationship between Cpk & Right First Time? First Pass Yield (FPY)? Capability, Accuracy and Stability - Processes, Machines, etc. 4
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
A IATF certification for pass through supplier IATF 16949 - Automotive Quality Systems Standard 1
S How can a R&D center pass IATF 16949 certification? IATF 16949 - Automotive Quality Systems Standard 9
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
K UL 6601 - Would an off-the-shelf Android tablet, powered by USB, pass UL 6601? Other Medical Device Related Standards 3
Q Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M What CQA Preparation Material helped you to pass the exam? Career and Occupation Discussions 6
I Device Can't Pass IEC 60601-2 ESD Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
B What is the implication for someone who does not meet the 70% pass mark for QMS-Lead. Professional Certifications and Degrees 2
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
G How much time must pass after the first Certification Audit for us to appear in OASIS AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
N VDA 6.x - Requirements Pass Down to Suppliers ....Obliged?? VDA Standards - Germany's Automotive Standards 5
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Contractor Pass required for Contract Cleaners? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
R Should the fault tests pass if temperature goes high in short time? IEC 60601 - Medical Electrical Equipment Safety Standards Series 15
K False Pass/Fail Information from GR&R (Gage R&R) Minitab Using Minitab Software 6
I Service Supplier Rating where Objective Pass/Fail Data is not Available Service Industry Specific Topics 7
R ASQ CQE Practice Exam - Do I need to score very well to pass? Professional Certifications and Degrees 17
R Pass Thru Gage for Straightness for a Floor Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Is the up-dated ISO 9004:2009 needed to pass audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
QMMike Repercussions of letting your ISO/TS16949 RR date pass.... IATF 16949 - Automotive Quality Systems Standard 3
K Pass Thru Calibration Certificates? Out-Sourcing Calibration to 3rd Party General Measurement Device and Calibration Topics 6
D Cytotoxicity testing to ISO 10993-5 results - Is 1/ mild a pass or fail? Other Medical Device Related Standards 7
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Marc Verified Identity Pass closes its doors - More Airport Fun Travel - Hotels, Motels, Planes and Trains 2
A Ford Material Specifications - Must pass WSB-M4D638-B vs. WSS-M4D-638-B Customer and Company Specific Requirements 3
