FIRST PIECE PASSED WHEN IT SHOULDNT HAVE
Hybrid
This resulted in the production of non-conforming parts with the in-process inspectors passing it each inspection because "first piece report said it was okay"
Where do i even start to address and fix this issue? The part is a screw and print calls for an unthreaded portion of the screw. The entire screw is threaded.
I am a new QC manager who has been on the shop floor doing calibration audit and havent been working with my inspectors closely so i know this is somewhat my fault for not being there to guide them. I could use some tips on what my next steps should be.
I have gathered all the non-conforming parts so that non of it gets to the customer.
Johnny Quality
Hybrid,
I would start by mapping the process as a flow chart, starting from goods in of the screws (assuming they are bought in and not manufactured in house), including all processing and inspection points. It sounds like there are repeat inspection points which in my experience make things worse rather than better - first inspector does a half assed job assuming it will be checked again, latter inspectors do a half assed job assuming it's already been verified.
You will also have to find out why there are two different screws that appear to work in your process, as in both screws fit in the assembly and allow the product to continue down the flow chart. Perhaps this could be designed out - different diameter screws, lengths, etc?
Also you'll have to find out why they were used in the first place; supplier delivered wrong part, ordered wrong part, operators used wrong part, instructions not clear, etc.
Work with the stakeholders and see what the data tells you
GStough
In addition to what @Johnny Quality said, you may want to check the previous lot inspection records and if possible, retain samples. Was this the first time this has happened or is it a repeat of the previous production lot/run? If it's a repeat, you'll need to contain any of that lot, as well, and notify the customer/s.
Randy
Flitter, 1st find the culprit responsible for the 1st piece and ask "Why the "H" did you pass it to begin with?"
Next, gather the "in process" inspectors and ask "Why did you continue to approve when you knew it was wrong?"
Based on the responses chart your next courses of action to correct the problems and then prevent them from happening again. (Including cleaning house a bit).
Clearly a case of monkey see-monkey do compounded with "don't give a "S"-itis". Lemmings are claimed to do the same thing.
Hybrid
Thank you both for the info!
This is the first time we make these parts. The print clearly shows an unthreaded portion of the part. How do i address them missing that important detail? They do visual inspections so why did they not notice the full screw being threaded when the print shows half thread
Johnny Quality
Do you make the screw or are they bought in from a supplier? Why do you have fully threaded screws and half threaded screws?
I would ignore the detection failure for now unless you must beat your team over the head
Johnny Quality
Then I would ask why do you have fully threaded and half threaded screws? Are they different parts that exist or it is a manufacturing issue that you have fully threaded screws?
Are there dimensional verifications involved in addition to visual?
Mikey324
I would say look first out how you ended up with fully threaded screws for the inspectors to look at in the first place. Visual inspection will never be 100% effective, so I would look at the root cause of the "why was it made" part of the problem. If you can prevent the defect from being made before going to inspection, that's one less thing for them to miss.
Without knowing production details, it's tough to go much further. Perhaps you produce two product types. One fully threaded, one with an unthreaded part. Perhaps they are otherwise identical. Maybe having them in different color containers would help to keep them from getting mixed. All hypothetical, but I hope you see where I'm going with it.
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Azaarus Looking for important points regarding First Piece Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 6
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
S If a piece of software receives approval as part of a medical device system Canada Medical Device Regulations 5
I First Piece Inspection classified as a Key Process Input FMEA and Control Plans 2
5 First Piece Inspection (Primarily Standard Machining) Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C One sample piece from standard production? AS9102 FAIR questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
CalRich Retention of First Piece from each Production Run IATF 16949 - Automotive Quality Systems Standard 11
D Distribution of a Kit composed of Piece Parts from several Manufacturers EU Medical Device Regulations 3
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
8 Single Piece Flow Game - Understanding the Principles and Logic of Single Piece Flow Lean in Manufacturing and Service Industries 3
D First Piece Set-Up Inspection question Manufacturing and Related Processes 11
M About First and Last Piece Procedure & Marking, Packing, Traceability IATF 16949 - Automotive Quality Systems Standard 7
M TS 16949 Sampling Plan Information - List the specific dimensions for each piece? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Traceability without Working Order - Batch to One Piece Flow AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Nonconforming Product - 1st Piece Rejection Nonconformance and Corrective Action 3
jkuil Recording of First Piece Inspection to meet 21 CFR 820.80e and ISO 13485 7.5.1.1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
R Control on Setting piece mix-up - Are there any fool proof systems? Quality Tools, Improvement and Analysis 2
R Anyone know how to establish one piece flow in apparel industry? Lean in Manufacturing and Service Industries 9
J Software or template to manage first piece, in process and final inspection reports Software Quality Assurance 2
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Employee home piece work and supplier control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K Chrysler requirements for First Piece Approval IATF 16949 - Automotive Quality Systems Standard 3
K First Piece vs. First Article - QC Inspection Terminology Inspection, Prints (Drawings), Testing, Sampling and Related Topics 24
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
Y Implementing One Piece Flow Lean in Manufacturing and Service Industries 9
C Cost per Piece of Powder Painted Part Manufacturing and Related Processes 3
Q Teeth Sharpness Measurement - Broaching into a flat aluminum piece General Measurement Device and Calibration Topics 7
S Calibration Labels Per Piece or is a Listing Acceptable? General Measurement Device and Calibration Topics 4
K Looking for some Quality Catch Phrases - First Piece and Last Piece Displays Document Control Systems, Procedures, Forms and Templates 34
B Should 1st Piece Process be a Control or a Line Item in the Control Plan FMEA and Control Plans 10
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
P No In-process or first piece inspection - Final Inspection ONLY! Am I wrong? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 37
D What does 1st piece (1st Article) mean to a lay person like myself? IATF 16949 - Automotive Quality Systems Standard 12
A The Numeracy Piece - Word is new to me, does anyone know about it? Statistical Analysis Tools, Techniques and SPC 1
A Customer wants to invoke AS9103 on one time buy of 25 piece order. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Customer wants AS9103 applied to 30 piece order. Quality Tools, Improvement and Analysis 2
P Is the first piece inspection method supposed to be in the Control Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
M Management Review: "Powerful Tool" (ISO 9004 5.6.3) or Redundant Piece of Paper? Management Review Meetings and related Processes 17
S Can a trained person in our lab "certify" a piece of steel gauge General Measurement Device and Calibration Topics 3
