First Piece vs. First Article - QC Inspection Terminology
K
Karen Whitehead
Our company is in the process of developing a quality management system, and we have contracted with a registrar for certification to ISO 9001:2000. I am new to manufacturing and have the job of developing procedures and forms for the system. I have used the term "first article" in some inspection procedures and forms meaning "the first off the production run or process." I was told that this was not the proper terminology - that "First Article" meant the "first parts ran when the product is first produced, not every time there is a production run." However, this weekend I talked to a production worker at another plant who operates a robot, and he is required to inspect the first pieces off a production run which they call "First Piece Inspection." Is there a difference in First Piece and First Article - or is it six of one and a half-dozen of another? Thanks for the help.
D.Scott
Welcome to the Cove.
The term "First Article" has a special meaning to the AS9100 people. It is, as you were told, the qualifying format for new product/processes and changes. This is very similar to the automotive PPAP approval.
First piece inspection is used throughout the quality system, also as described, as the first (set) off the process at start up. If you are going for ISO9001:2000, I assume you want to look at the "first piece" inspection description.
I hope this helps. If you have other questions, please let us know.
Dave
Jen Kirley
Quality and Auditing Expert
Welcome to The Cove Karen! :bigwave:
I did a search on your question and came up with this thread. I hope this helps! Please let us know if you have further questions.
Karen:
Glad you're here, good advice so far!
I'd suggest that the first piece is just that - the first item made to prove the process (which is normally made at the beginning of a shift, run etc.). The 'first article', on the other hand, might be a number of components which result from a number of processes. Often, this is submitted to a customer.
Still, who cares?:mg::lol:
You may have been told 'the truth' by that person, but perhaps what's most important is what you're trying to achieve and whether the people who are responsible for this are in agreement on what it is and what it's called. What you choose to call it is up to you. If it's new terminology to the company, so much the better to ensure a consistent story.......
I second Andy's advice. Outside of the aerospace usage Dave pointed out, the two terms are generally interchangeable, and what you'll find is that most companies use either one or the other to describe a setup exemplar for existing jobs, and might use customer terminology for the part(s) submitted to the customer for production approval.
John Nabors - 2009
My understanding has always been that a first article is a piece or sample of pieces produced by a new process for the first time and submitted in order to validate the process. A first piece is a piece or sample of pieces produced by a process that has been previously validated, but has been torn down and later set up again, or in some more rigorous cases a piece submitted by a previously validated process at an event such as a shift change or a tooling change.
Make any sense?
Regards -John
Make any sense?
Regards -John
This is also our view on the two terms.
Dean Frederickson
A first article inspection is the first part(s) of a new part you check every dimension (you also number the dimensions on the print to corelate to the 1st article report). Every thing on the print is verified. A first piece inspection is the first part off of a new set-up of a part that has already been run (and had a first article done on it). They are different inspections, a first piece insp. you don't check every dim. you check only critical dimensions and verify that all features are present. A first piece insp., in process insp., coil change insp., and final insp. are used during a production run of parts that already have had a 1st Article Inspection.
F
Frank T.
AS 9100 defines First Article Inspection as a process for the inspection, verification and documentation of a representative item from the first production run of a new part, or following any subsequent change that invalidates the previous first article inspection result.
ISO 9001 has no specific term it just states the organization shall determine the following, as appropriate:
c) required verification, validation, monitoring, inspection and test activities specific to the product and the criteria for product acceptance.
IMO, any term is acceptable as there is no specific name, term, phrase, nomenclature, etc. to describe inspection of 1st off/piece.
On that note, Welcome to the cove Karen.:bigwave:
P
Pazuzu - 2009
We have a system that uses both as seperate entities because really, they are. Here's how we use them...and I think I'm safe saying it's generally accepted this way.
First piece inspections are performed at the outset of every seperate process to ensure that the press, machine, jig, whatever is setup to provide consistant and repeatable output. i.e.: "now that I'm set up to run the job, am I comfortable enough to sign my name to it knowing the set up will not degrade over time?" The inspections you perform to validate this are the First Piece Inspections.
First Article Inspection is derived from the automotive industry (at least to the extent of my knowledge) and used in, but not limited to, PPAP. Also known as a FAIR form, the First Article Inspection Report is used once the first production run is complete to verify that what you have made is indeed what you planned on. It usually also includes basic dimensional analysis to verify the tooling is not degrading or shifting.
I personally find FAIRs to be pointless since your verifying if its right after its made as opposed to during. :2cents: If you want a Ford mass assembly line then use FAIRs...if you want a Lean, preventive-based system, you shouldn't need them unless mandated by a customer.
D What does 1st piece (1st Article) mean to a lay person like myself? IATF 16949 - Automotive Quality Systems Standard 12
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
S "X-MR charts do not separate piece-to-piece repeatability of the process" Statistical Analysis Tools, Techniques and SPC 2
J AS9100D Sections related to 1st Piece and In-Process Inspection Manufacturing and Related Processes 15
S Setting up the process - First piece inspections Statistical Analysis Tools, Techniques and SPC 3
S If a piece of software receives approval as part of a medical device system Canada Medical Device Regulations 5
I First Piece Inspection classified as a Key Process Input FMEA and Control Plans 2
5 First Piece Inspection (Primarily Standard Machining) Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
K Gage R on a 10 Piece Sample with a CMM using Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Q Effective 1st Piece Inspection Sign Off Procedure Quality Manager and Management Related Issues 8
A Simple 125 piece part Capabilty Excel .xls sheet to calculate Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 3
M Example of a typical First Piece Inspection Procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C One sample piece from standard production? AS9102 FAIR questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Designing an attribute MSA for a new piece of metrology equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
CalRich Retention of First Piece from each Production Run IATF 16949 - Automotive Quality Systems Standard 11
D Distribution of a Kit composed of Piece Parts from several Manufacturers EU Medical Device Regulations 3
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
8 Single Piece Flow Game - Understanding the Principles and Logic of Single Piece Flow Lean in Manufacturing and Service Industries 3
D First Piece Set-Up Inspection question Manufacturing and Related Processes 11
M About First and Last Piece Procedure & Marking, Packing, Traceability IATF 16949 - Automotive Quality Systems Standard 7
M TS 16949 Sampling Plan Information - List the specific dimensions for each piece? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Traceability without Working Order - Batch to One Piece Flow AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Nonconforming Product - 1st Piece Rejection Nonconformance and Corrective Action 3
jkuil Recording of First Piece Inspection to meet 21 CFR 820.80e and ISO 13485 7.5.1.1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
R Control on Setting piece mix-up - Are there any fool proof systems? Quality Tools, Improvement and Analysis 2
R Anyone know how to establish one piece flow in apparel industry? Lean in Manufacturing and Service Industries 9
J Software or template to manage first piece, in process and final inspection reports Software Quality Assurance 2
ScottK Inspecting surface finish on SS on a piece that can't be measured with current equip. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T Employee home piece work and supplier control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K Chrysler requirements for First Piece Approval IATF 16949 - Automotive Quality Systems Standard 3
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
Y Implementing One Piece Flow Lean in Manufacturing and Service Industries 9
C Cost per Piece of Powder Painted Part Manufacturing and Related Processes 3
Q Teeth Sharpness Measurement - Broaching into a flat aluminum piece General Measurement Device and Calibration Topics 7
S Calibration Labels Per Piece or is a Listing Acceptable? General Measurement Device and Calibration Topics 4
K Looking for some Quality Catch Phrases - First Piece and Last Piece Displays Document Control Systems, Procedures, Forms and Templates 34
B Should 1st Piece Process be a Control or a Line Item in the Control Plan FMEA and Control Plans 10
B ISO10012:2003 Question - Choosing or assessing the capability of a piece of equipment Other ISO and International Standards and European Regulations 1
P No In-process or first piece inspection - Final Inspection ONLY! Am I wrong? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 37
A The Numeracy Piece - Word is new to me, does anyone know about it? Statistical Analysis Tools, Techniques and SPC 1
A Customer wants to invoke AS9103 on one time buy of 25 piece order. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Customer wants AS9103 applied to 30 piece order. Quality Tools, Improvement and Analysis 2
P Is the first piece inspection method supposed to be in the Control Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
M Management Review: "Powerful Tool" (ISO 9004 5.6.3) or Redundant Piece of Paper? Management Review Meetings and related Processes 17
S Can a trained person in our lab "certify" a piece of steel gauge General Measurement Device and Calibration Topics 3
M Single piece APQP APQP and PPAP 1
M Document Evidence for One Piece Flow Processes Misc. Quality Assurance and Business Systems Related Topics 8
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
