First time being audited (ISO 9001), asking for advice
Hello Cove :bigwave:
I've posted a few questions on the forum before, but I'm still a relative newbie in quality management.
As in I've never held a job in nor studied Quality prior to being hired as a Quality Manager a few months ago.
We have a remote ISO 9001 re-certification audit and would like some last minute advice of what to expect, what I should have on hand, or maybe some stories you may have.
I've never been audited before, and while I have performed some internal audits this year, I'm not sure I'm doing it right.
I am good at organizing and looking up things so I at least know what's in our system.
Also, I did take a lead auditor course back in January so I'm not completely clueless, just definitely don't know what I'm facing.
Thank you all!
Marc
Fully vaccinated are you?
I made that around 1996. I used to print them out with the company quality policy on the other side, laminate them and give one to every employee.
Simple and gave employees some confidence.
Tagin
If you look at 9.2.2 on audits, it says at the end "NOTE See ISO 19011 for guidance"
ISO 19011 has a section A.16 Auditing virtual activities and locations. This discusses risks and recommended preparations for a virtual (remote) audit. I would suggest that you review this, and have some kind of document, risk register entry, etc. to show that you've considered these risks. Doesn't need to be elaborate - just a simple one-page doc that it shows you've thought this through.
How will you give a 'tour' of the facility to the auditor? Are you going to use a cellphone camera that is logged in as a meeting attendee? Have you tested this? Is background noise in your facility going to make it impossible to communicate with the auditor while in some locations? Do you have a charger handy due to battery drain?
Are you able to easily email/file transfer requested QMS docs to the auditor? Do you need to scan in paper docs during the audit that the auditor requests? How prepared are you for this?
John Broomfield
Remember it is not you that is being audited. But you are expected to know how your organization works as a system to determine and fulfill customer requirements.
...and how your organization improves continually. Any lack of confidence (backed by evidence) may cause the auditor to investigate further.
Make sure you have a copy of the audit plan and let your colleagues know when they’ll be expected explain (or show off) their particular part of the system.
Lastly, remember that the system is only partially documented to the extent necessary for effectiveness.
You are hoping the auditor reports examples of excellence and exposes any hidden weaknesses in your system.
Randy
After over 100 days of doing remote auditing last year and a couple weeks of it this year already the best advice I can give is maintain an even strain and your sense of humor. Honestly
• Make sure you have a good working internet connection. It is recommended that a minimum download speed of 2MB per second. If desired, you can check the speed of your internet connection in advance via Speedtest by Ookla - The Global Broadband Speed Test.
• Preferably use a headset. Using a laptop’s built-in microphone often results in a poor audio connection.
• Limit the background noise by setting the microphone to ‘mute’ when you’re not speaking. This is particularly important in a meeting or conversations with larger groups.
• Preferably, use a webcam to enable face-to-face engagement. However, if the audio quality is insufficient or faltering, it’s advisable to disable the webcam or video connection in order to improve your connection.
• Collect relevant documents and information prior to the interview. Based on the knowledge of your management system and previous experience with audits, you’ll be aware of the documents and information the auditor would like to review, as per the remote audit plan.
• Ensure clear communication during the interview. For example, clearly indicate what you are doing or going to do, for instance: ‘I’m going to log on to the application now, I’m trying to find the document on our network, I’m going to read your procedure now’.
Remote work can be more tiring and stressful than face-to-face and clarity of language is important both directions.
Good luck
Thanks! I was able to check off most of your points, so that's definitely a confidence booster.
G IT being audited during ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
lyobovnik Matters being audited, independence, participation and direct responsibility 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
D No evidence of certain processes on our scope being audited at our remote location IATF 16949 - Automotive Quality Systems Standard 4
L Being audited on AS9100 30th July - need example flow chart AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
J Being Audited Right Now... Not every department Internal Audited ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Does the Head of the Department being audited have the right to amend audit report? General Auditing Discussions 15
M Help! Im am being audited and have CS1 against me IATF 16949 - Automotive Quality Systems Standard 7
B Registrar being audited during our recertification - Can we we refuse? Registrars and Notified Bodies 6
Raffy Internal Auditing - Showing independence of process being audited Internal Auditing 4
Sidney Vianna Informational Being developed ISO 30201 Human Resource Management System — Requirements Other ISO and International Standards and European Regulations 6
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
R How to keep old versions of work instructions from being used at point of use? ISO 13485:2016 - Medical Device Quality Management Systems 20
H Is testing according to IEC 60601-1 & IEC 60601-1-2 mandatory for a device being registered under MDR? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S How to deal with customers requesting documents as being in the role of distributor? EU Medical Device Regulations 5
F So my quality management position is being marginalized by my job. Quality Manager and Management Related Issues 16
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
P Requirements for being an European Representative EU Medical Device Regulations 3
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
T Commission proposal being drawn up for postponement for date of application of MDR (2017/745) EU Medical Device Regulations 7
Nicole Desouza The Difference of being AS 9100D Compliant vs.Certified AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D IATF 16949 FAQ 24 (8.4.2.2 Countries of Destination) - How is this actually being interpreted? IATF 16949 - Automotive Quality Systems Standard 3
M Search for predicates to see what claims are being made for those predicates 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M CBE (Change Being Effected) 510(k) Submission Other US Medical Device Regulations 8
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
R DCMA QAS is holding up shipments of product due to them being late AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S EQMS solution (Greenlight Guru and Q-Pulse currently being explored) Medical Information Technology, Medical Software and Health Informatics 8
G Audit finding - Components being transferred inter-plant Internal Auditing 3
A MedAccred being flowed down to Suppliers (2018) MedAccred Industry Group Program 0
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
chris1price Calibration of Instrument before being Discarded General Measurement Device and Calibration Topics 9
M Which Certificate should I have being a Dentist? Hospitals, Clinics & other Health Care Providers 4
I AS9100C Lead Auditor Training Courses being Cancelled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Gman2 Identification of Raw Material being used In-Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Is MHLW Std No.169 - 2004 being Revised in Nov 2014? Other ISO and International Standards and European Regulations 5
S Advanced Surveillance and Recertification Procedures - being discontinued by the IAF December 2019 update ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
somashekar Is OBL CE Marking route for Medical Devices being Reconsidered? EU Medical Device Regulations 4
K Difference between being a Management Representative and being a Lead Quality ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Does being a subsidiary fully absolve company B from complying with 21 CFR 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Ways to check to see if the gage is being used General Measurement Device and Calibration Topics 11
J SC and the linkage between CP and PFMEA ? When it?s being produced or controlled? IATF 16949 - Automotive Quality Systems Standard 4
D Plan & Procedure to handle a Product that's being Withdrawn from the Market 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Ethical Aspects while being Consultant and Certifier within same Organization. Consultants and Consulting 6
B Is the ISO 13485 auditor being too picky concerning CMDCAS? ISO 13485:2016 - Medical Device Quality Management Systems 5
Q Reduced Device License Fee was rejected for being sent in too early Canada Medical Device Regulations 2
somashekar About Technical File being available at Manufacturing Site ISO 13485:2016 - Medical Device Quality Management Systems 3
AnaMariaVR2 Why Being the Last Interview of the Day Could Crush Your Chances Career and Occupation Discussions 8
K Records Control - Auditor Objection to Data being Recorded and Stored in PC Records and Data - Quality, Legal and Other Evidence 21
