Fixing of tolerance limit - Electronic weighing balance with the capacity of 150 Kgs
raghu_1968
We have the electronic weighing balance with the capacity of 150 Kgs.
Its least count is 0.02 kg.
We need to do the performance check of the balance on daily basis before weighing activity is carried out. The query is How to fix the tolerance /error limit for this balance?
Literature reference if any will also help.
raghu_1968
Re: Fixing of tolerance limit - Electronic weighing balance with the capacity of 150
Can we give the Least count as the tolerance? In this case ±0.02
Marc
"Bump" - Can anyone help with this question? My Thanks in advance!
Anbu8894
Hi
Fixing of tolerance depends upon the what product your going to weighing.
If it is more accurate product tolerance will be very less.
As a user, you only decide that.
raghu_1968
Mostly chemicals which are used for the manufacture of drug substance and its intermediates are measured.
dwperron
Raghu,
We need more information here.
First, the tolerance for the scale most always includes more than the least count. There should also be linearity and repeatability tolerances. Sometimes a manufacturer will combine them into a single accuracy tolerance. Do you have the manual? The tolerances should be there. If not, please give us the manufacturer and model and we will see what we can find out.
As for the daily check, how much are you typically weighing on this scale? What kind of accuracy does your process require for your measurements? With this kind of information you can come up with a reasonable daily check method.
N Ways to avoid injected bugs while Bug fixing (software) Problem Solving, Root Cause Fault and Failure Analysis 5
K Quality Control on Braided Metal Hose covering Stainless Steel Pipe - Fixing Dents Benchmarking 7
Stijloor Fixing things.. Funny Stuff - Jokes and Humour 7
Sidney Vianna Fixing a Cut in a Leather Seat Coffee Break and Water Cooler Discussions 7
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 14
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
C Acceptable NDC for %GR&R part inspection to Tolerance (%Tolerance) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 9
S Doubts about SPC taken in Machining - Part has +-0.01 Tolerance Statistical Analysis Tools, Techniques and SPC 5
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
N Straightness Gage Tolerance General Measurement Device and Calibration Topics 0
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
kedarg6500 Excel spreadsheet for Unilateral Tolerance Study wanted Excel .xls Spreadsheet Templates and Tools 2
U Control Charting a Feature with Bonus Tolerance Quality Tools, Improvement and Analysis 10
