Flammability: Testing Burn Rate with Improper Sample Size fmvss 302
julia.artos
Hello everyone,
I hope i can find an answer to my question.
Im working at a testlab and we test the burn rate of plastics according to fmvss 302 and other norms.
Can i give our customers a burn rate, if the sample has dimensions like 20mm x 60 mm? If you subtract the first 38 mm, that are not measured, then the remaining 22 mm are used for burn rate calculation. Is this statistically firm?
Standart would be 100 mm x 356 mm.
Im concerned mostly about the lenght.
What happens, if we determine a burn rate like this and something happens? Our customers could send us trial records to determine flammability, but we would have to give them reasons.
Hershal
Metrologist-Auditor
Typically flammability standards specify the sample size, for example a mini-calorimeter may use a 25mm by 25mm sample. If the applicable standards specify the size then trim the sample to that size.
For fmvss, Federal DOT should specify the size.
Hope this helps.
R FMVSS 302 Flammability Testing Certification Quality Manager and Management Related Issues 2
R GMW 15571 - Flammability IATF 16949 - Automotive Quality Systems Standard 0
O Flammability Requirement for Gaskets and Seals - UL 61010-1 CE Marking (Conformité Européene) / CB Scheme 4
S MSA (measurement system analysis) on Flammability tester? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E IEC & UL 60601-1 Plastics Flammability - Guidance on flame-rated plastics usage IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
B Flammability Ratings for Internal Battery & Hand-Held ME Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
K ISO 3795 FMVSS 302 Flammability - Automotive Quality Manager and Management Related Issues 5
L Flammability Rating - is FT4 a better rating than FT1? Other US Medical Device Regulations 2
D Should all materials used for ME Equipment have flammability of class V-0 or higher? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
P Medical Device Insulated Wire Flammability Classifications FV-1, VW-1 and FT-1 (CSA) EU Medical Device Regulations 3
T Enclosure Flammability Rating of Molded-In Custom Color Liquid Concentrates IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Flammability EN 1021 - Polyurethane Foam that meets EN 1021-1 & 2 Other ISO and International Standards and European Regulations 3
M Cal 133 flammability standard - Medical Devices - Stupid Customer Tricks 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C Flammability of medical textile - any relevant standards? ISO 13485:2016 - Medical Device Quality Management Systems 2
S What's difference between fmvss302 and GM6090M? Flammability of interior materials Various Other Specifications, Standards, and related Requirements 5
M Honda Requirement HES C 206 - Flammability specification Customer and Company Specific Requirements 10
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
JoCam Mobile Patient Hoists and Electrical Testing Other Medical Device Related Standards 0
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 2
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
U Medical Device Design finalization testing ISO 13485:2016 - Medical Device Quality Management Systems 2
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 3
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
M Inter-operator Variability Testing - Requirements for EU Medical Device Regulations 5
S High voltage testing - ISO 17025 - 7.2.2 Validation of methods and 7.3 Sampling ISO 17025 related Discussions 3
M Production approval testing - Alternative ideas for Validation Reliability Analysis - Predictions, Testing and Standards 4
JoCam MDL in Canada without Canadian Electrical Testing Canada Medical Device Regulations 0
T HF testing / Summative evaluation for MDDS class I necessary? Human Factors and Ergonomics in Engineering 2
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 5
M Workplace Drug Testing in 2020 Misc. Quality Assurance and Business Systems Related Topics 9
W ASTM F1929 dye penetration test - validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 2
J FDA wants electrical safety testing on battery powered medical device US Food and Drug Administration (FDA) 7
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 3
T Qualification testing of Lead acid batteries Reliability Analysis - Predictions, Testing and Standards 0
D Sterility and BioBurden Testing for Plastics ISO 13485:2016 - Medical Device Quality Management Systems 5
DitchDigger IEC 60601-1 subclause 5.1 - Adequate evaluation in lieu of testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
MrTetris Are GLP required for testing cytotoxicity and soil remaining after sterilization of MD? Other Medical Device Related Standards 8
D Design Verification - Is testing required? Design and Development of Products and Processes 5
M Specific Absorption Rate (SAR) Testing - What Standard to Use? Other ISO and International Standards and European Regulations 1
N IATF 16949:2016 7.1.5.3.2 External Laboratory - How to approve the Testing Laboratory without accreditation scope IATF 16949 - Automotive Quality Systems Standard 1
T Spirometer - Pulmonary Function Testing - ATS/ERS:2005 EU Medical Device Regulations 5
M 510(k) 10993 Biocompability Testing Other US Medical Device Regulations 15
C Sterility and Bioburden Testing - LAL passed under 0.5EU/mL Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
A ISO 17025 Requirement 6.2 - Department Manager Testing Qualifications ISO 17025 related Discussions 1
P IEC 62304 - evaluation of integration and system testing IEC 62304 - Medical Device Software Life Cycle Processes 4
H EO Sterilization Validation - Sterility Testing and Load Configuration Other Medical Device Related Standards 1
