Flatness Call Out confusing me - What they are wanting and how to check it?
biker6977
I am confused by the flatness call out on this drawing.:confused:
Would someone better than I please explain what they are wanting and how to check it?
Thanks, Caroline
David DeLong
Re: Flatness call out confusing me
Caroline:
Sorry but your file did not work out. Could not see it.
True Position
I agree with the previous posters, the tolerance is 0.005 overall and 0.001 in any square inch. If you will be scanning that on a CMM one question you might want to ask your customer is what amount of overlapping of the squares are they expecting.
silentrunning
So how would you check it? On a granite surface plate with a 10ths indicator? No - I don't have a CMM with a probe. :eek:
True Position
You would need the indicator sticking through the surface plate, simply indicating the opposite side of the part to the surface plate would be measuring parallelism. The traditional method for flatness used 3 adjustable jacks but that is VERY slow.
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
F Flatness VS parallelism Design and Development of Products and Processes 6
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
P Checking flatness with Go and No Go Jig Manufacturing and Related Processes 2
J Flatness measured to locations of a plane Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Result of a Flatness MSA on a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Measuring Flatness of a Pump Cover General Measurement Device and Calibration Topics 14
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Flatness Measurement of Plastic Molded Parts - Clamping / Holding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
G Determining flatness and parallelism rapidly Manufacturing and Related Processes 2
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
optomist1 GD&T Flatness Automatic Indirect Control Rule #1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
C Surface Plate Calibration - How to verify the flatness of a granite surface plate General Measurement Device and Calibration Topics 1
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
B Inspection Tools for Flatness and Channel Depth of Bipolar Fuel Cell Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Techniques for Measuring Flatness General Measurement Device and Calibration Topics 37
Z Inspection of Flatness of a part using an electronic device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
Proud Liberal Flatness / Straightness / Bow specification Various Other Specifications, Standards, and related Requirements 12
D Optical flats - "FLATNESS INTERPRETATION CHART, Light Wave Band Pattern Guide" General Measurement Device and Calibration Topics 4
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
S What is the best method for checking the flatness of a flexible part? General Measurement Device and Calibration Topics 4
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
A Call Center troubleshooting guides Medical Device and FDA Regulations and Standards News 5
E BCP (Business Continuity Plan) Call Tree Business Continuity & Resiliency Planning (BCRP) 13
S Call it refurbish or not? Medical Devices Manufacturing and Related Processes 2
T GDT Callout - How to call out a note that requires some clamp load Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
MDD_QNA Accessory or I-don't-know-what-to-call-it-at-this-point EU Medical Device Regulations 3
M Informational EU – Flyer – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices (2019/C 323/05) Medical Device and FDA Regulations and Standards News 0
M Informational EU – Some documents related to Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 0
M Informational EU – Call for expression of interest for expert panels on medical devices and in vitro diagnostic medical devices Medical Device and FDA Regulations and Standards News 1
qualprod Evidence of a talk or phone call in approvals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Sidney Vianna ISO 18295 - Requirements for Call Centers (Customer Contact Centres) - 2017 Other ISO and International Standards and European Regulations 0
Q Preventive Action - How to call the prevention when there is not a clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Variation Study on Mined Material - What do you call it (not a control chart) Statistical Analysis Tools, Techniques and SPC 7
G Does ISO 9001:2015 call for a Policy or a Statement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Marc When did you first use what we call E-Mail (aka email) today? Coffee Break and Water Cooler Discussions 17
D A desperate call for help - IEC 62304 software IEC 62304 - Medical Device Software Life Cycle Processes 5
M Update or Replace Nurse Call system? Hospitals, Clinics & other Health Care Providers 3
