Flatness VS parallelism
John Predmore
Both terms measure the characteristic that all points in a surface lie in a geometric plane, with no points outside the specified tolerance. With parallelism, the geometric plane is referenced to a GD&T defined datum. Flatness is a surface in reference to itself as the plane. Flatness takes no datum reference. One example might explain better. If you place a wedge-shaped part on a surface plate, the top surface will not be parallel to the surface plate, but the top surface could very well be in spec for flatness.
dsanabria
Surface A can be 0.5 out of flatness but at the same location the thickness (parallelism) can not be out more than .02
John Predmore
I am referring to fisa's second drawing where datum A is shown on the bottom, not the first, where A is shown on top.
Surface A is identified as Datum A in this drawing, and that is an important distinction. Parallelism is defined as all points on the other surface must fall within a tolerance band relative to datum A. In geometric tolerance terms, Datum A is perfectly flat. In practical terms, for gaging purposes, Datum A is located by the 3 highest points on surface A. Therefore the plane defined by the flatness of surface A (a best fit plane) is not the same plane as the virtual plane of Datum A (a plane touching the three highest points). GD&T can be confusing because a single drawing represents both geometrically-ideal virtual aspects (such as datums) and instructions how those ideal geometries are accessed on the physical part.
If the top surface, not datum A, is held within 0.02 parallelism, it will out of necessity be flat relative to itself within 0.5. Also, there is an implied flatness due to the +0.1/-0 tolerance on the thickness dimension which controls flatness tighter than the flatness callout of 0.5 on the top surface. So the flatness callout on the top surface is unnecessary IMO. The flatness callout on surface A is appropriate, because parallelism only applies to the top surface relative to the 3 highest points on surface A.
John Predmore
In your second drawing, fisa asks what does it mean when he took several thickness measurements around the perimeter with calipers. My answer is that parallelism cannot be properly measured with calipers or a micrometer, because these devices take only "spot" measurements. The parallelism callout applies to the entire surface. Also, there will be variation in the flatness of surface A, as much as 0.5 out of flat is allowed by the drawing. A spot measurement in a low spot on surface A will give an artificially low thickness reading. Parallelism applies to all points on the surface of interest relative to a planar datum, and datum A is understood to be located on the 3 highest points of surface A. One proper method to measure parallelism is to place surface A on a surface plate and move a dial indicator on a gauge stand around the top surface.
C Micrometer Parallelism and Flatness Calibration Requirements and Specs General Measurement Device and Calibration Topics 10
G Determining flatness and parallelism rapidly Manufacturing and Related Processes 2
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
hogheavenfarm GDT Flatness measurement question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
G From an ISO 17025 auditor perspective must micrometer calibration check anvil flatness? General Measurement Device and Calibration Topics 4
I Flatness - Rectangular part using the three jack method Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
N Do I need to approach galvanized steel sheet flatness issue with DOE? Problem Solving, Root Cause Fault and Failure Analysis 9
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
W Standard for Micrometer Anvil Flatness Oil and Gas Industry Standards and Regulations 5
G Caliper or Micrometer's Dimensional Flatness General Measurement Device and Calibration Topics 5
C Flatness Measurement Errors from a Datum - Test Method General Measurement Device and Calibration Topics 3
P Checking flatness with Go and No Go Jig Manufacturing and Related Processes 2
J Flatness measured to locations of a plane Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B Result of a Flatness MSA on a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
C Measuring Flatness of a Pump Cover General Measurement Device and Calibration Topics 14
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Reason a plane would have a runout applied and not a flatness callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
E Flatness Measurement of Plastic Molded Parts - Clamping / Holding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
optomist1 GD&T Flatness Automatic Indirect Control Rule #1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
B Flatness Call Out confusing me - What they are wanting and how to check it? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 42
C Surface Plate Calibration - How to verify the flatness of a granite surface plate General Measurement Device and Calibration Topics 1
A Ovality and Flatness generated after Heat Treatment of Rolled Rings Manufacturing and Related Processes 3
B Inspection Tools for Flatness and Channel Depth of Bipolar Fuel Cell Plates Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Techniques for Measuring Flatness General Measurement Device and Calibration Topics 37
Z Inspection of Flatness of a part using an electronic device Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
W Warping / Flatness SPC - X bar-R chart - Control is Max 0.15 Statistical Analysis Tools, Techniques and SPC 5
D Flatness tolerances for tempered cold rolled stainless steel coils Manufacturing and Related Processes 3
Proud Liberal Flatness / Straightness / Bow specification Various Other Specifications, Standards, and related Requirements 12
D Optical flats - "FLATNESS INTERPRETATION CHART, Light Wave Band Pattern Guide" General Measurement Device and Calibration Topics 4
S What is the best method for checking the flatness of a flexible part? General Measurement Device and Calibration Topics 4
M Cp and Cpk for straightness and parallelism Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Outside micrometer anvils parallelism General Measurement Device and Calibration Topics 3
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
B How to check the parallelism error of v axis w.r.t to lateral surfaces General Measurement Device and Calibration Topics 1
P Parallelism call out of .005" to Datum A - A GD&T question Capability, Accuracy and Stability - Processes, Machines, etc. 12
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
B How to measure parallelism btw top surface and bottom surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
S SPC on parallelism to the runout of a counterbore feature Statistical Analysis Tools, Techniques and SPC 3
F GD&T Parallelism Interpretation - Print which has a note: //|0.5 | A. Quality Tools, Improvement and Analysis 30
C How to assess Process Capability for parallelism Statistical Analysis Tools, Techniques and SPC 8
