Re: Flex Plugs - Gage R&R (GR&R) - Threaded plugs used to check location of tapped ho
Thanks for your reply and input. The issue we are trying to address is the validity of the flex plugs. I believe that putting them in the same hole ten times will have a detrimental effect on the threads. We are talking aluminum heads versus harden steel flex plugs. We thought of making a hardened steel plate with the desired threaded holes in it. Production has been telling QC that the flex plugs are not accurate enough for inspecting these holes.
Have a great day.
What method would production like done more accurate then flux plugs? Special made to pitch pin sized silicon nitride balls? (which honestly seems worse)
If you just want to make a point, show them repeatability of a few different methods and assuming the flex plugs are best you can show them data.
I'd recommend flex plugs, straight pins, probing a circle inside the tapped hole(worst method possible), helix WITH the pitch, helix across the pitch, and straight lines across the minor diameters.
The Zeiss forum guru on this topic spelled out his results when he did this testing(if my memory if accurate):
Best - Flex Plugs
Almost always fine - Helical With Pitch, Helical across pitch, Straight lines.
I've always used helical across the pitch and I've always repeated well enough with other CMM operators who've used flex plugs and straight pins for me to think it usually won't matter.
