FLUKE 1653B Adjustment - Instructions or Service Manual wanted
rogerio.p
I need to adjust a FLUKE 1653B. Does anyone have the service manual for this equipment?
Thank you
rogerio.p
Re: FLUKE 1653B adjustment
Thank you Umang,
I already have the users manual for this equipment. The adjustment procedures usually are in the service manual.
The link you send me, is for FlukeView Forms software (I have this software).
Thanks,
Rogério
Jerry Eldred
The best I see on the Fluke site if the CALIBRATION MANUAL (not sure if that was what was offered). If you have found the section on the Fluke website with manuals for the 1650B series, and the 1650B series (UK), that is probably all that they make available to the public. Depending on what you need to do to it, if it is software adjusted on a newer instrument, there may not be a full adjustment available.
I would recommend contacting your sales representative for your area, or contacting Fluke.
rogerio.p
Hello Jerry, thank you
I have the 1650B series calibration manual, but contrary to what is usual, it doesn´t have the adjustment procedures.
I have contacted FLUKE already and they said that it's not comercialy available.
Usually, FLUKE provides adjustment procedures of their equipments.
Someone has to know how to do it! (I think):rolleyes:
Best regards,
Rogério.
F Learning Uncertainty Budget for Novice - Fluke 5520A Measurement Uncertainty (MU) 1
P How to Calibrate a HP 3458A Digital Multimeter with Fluke 5080A calibrator General Measurement Device and Calibration Topics 1
W Banana jack for Fluke meters...? Calibration and Metrology Software and Hardware 11
N Thermcouple Wire Calibration with a Fluke 753 General Measurement Device and Calibration Topics 0
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
W Connecting IndySoft MET/CAL Import Module to a Fluke MET/TEAM Calibration and Metrology Software and Hardware 1
I Verification or calibration Fluke 8508a with 5720a? TUR not 4:1? Measurement Uncertainty (MU) 1
N Understanding the absolute uncertainty specification for a Fluke 5500A Measurement Uncertainty (MU) 3
R Looking for calibration specification for Fluke 7250 pressure controller General Measurement Device and Calibration Topics 5
J Could Fluke thermometer be used in SAT test in accordance to AMS 2750 ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
N Fluke 724 Calibration help needed General Measurement Device and Calibration Topics 8
B Calculating BMC (best measurement capability) for Fluke 8508A and HP 3458A Measurement Uncertainty (MU) 5
T Failure Modes on Fluke products? General Measurement Device and Calibration Topics 10
G Calculate a BMC for Thermocouple and RTD function with a Fluke 5500A Measurement Uncertainty (MU) 4
H METCAL Software (from Fluke) used only to get the Electrical Calibration Data? General Measurement Device and Calibration Topics 8
B Gage R&R on Oscilloscopes, Fluke voltmeters, Voltage probes, etc. & the like Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
J Calibration Procedure for a Wavetek 9100 using Fluke Met/Calibration software Coffee Break and Water Cooler Discussions 7
M Electrical calibration using Fluke 550 SC300 General Measurement Device and Calibration Topics 2
M Less expensive way to calibrate multimeters such as a "Fluke"? General Measurement Device and Calibration Topics 2
A Depth micrometer rod adjustment? General Measurement Device and Calibration Topics 8
A Adjustment of Calibration Intervals (Shortening or Lengthen) Calibration Frequency (Interval) 6
K Proto 6106 and 6106A Adjustment procedures General Measurement Device and Calibration Topics 0
T Calibration Certificate Readings After Adjustment General Measurement Device and Calibration Topics 5
A Product Impact When Thread Rings Require Adjustment General Measurement Device and Calibration Topics 9
K Vision System Camera Adjustment - Change Verification? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
WEAVER Calibration of Measuring Instrument by Adjustment of its Scales IATF 16949 - Automotive Quality Systems Standard 2
B In-Process Sampling Plan for a Secondary Package Adjustment Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Temperature Adjustment when ME EQUIPMENT is rated for used at Higher Altitudes IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
R Definition Safeguarded from Adjustment - Definition - Calibration - 7.6 d) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Minitab Pareto Chart Text Adjustment Using Minitab Software 10
D TS 16949 - 8.1.2 - Over adjustment should be understood throughout the organization IATF 16949 - Automotive Quality Systems Standard 11
L Difference between Calibration, Verification and Adjust (Adjustment) General Measurement Device and Calibration Topics 6
S Gas Spectrometers - Calibration vs. Zero Adjustment General Measurement Device and Calibration Topics 4
Jerry Eldred Adjustment of Calibration Intervals (Calibration Frequency) Calibration Frequency (Interval) 13
J In-house calibration - Resource for calibration, adjustment of calipers, indicators General Measurement Device and Calibration Topics 2
A Calibration Interval (Frequency) Adjustment using Hilliard type 2 algorithm Calibration Frequency (Interval) 11
F Definition Process Capacity and Over Adjustment - Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
D Pre-Control Chart to guide in-process inspection / adjustment decisions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 43
Marc Customer Audit of Guide 25 Calibration - Full pre and post adjustment data? General Measurement Device and Calibration Topics 1
