FMEA/DCP Structure and Quantity - Similar Parts and Processes
Mr.Blue
Hey,
My boss wants to create a DCP/FMEA for each part we manufacture. That would be over 150 parts, all of which run through the same machines following almost identical process.
Should we create 150 documents which are practically identical or one high level document which follows the broad strokes and has caveats for unique steps?
I'm worried about when a change may come to the process causing a requirement for sweeping updates to all 150 documents.
Jane_S
I think you have answered your own question here. If the parts essentially are not different from one another (in terms of use/safety/general production process steps etc.) one document should suffice. You can also consider splitting the devices into several 'families' of devices.
Mr.Blue
Moving away from automated identical process. Say you have 3 manual assembly lines that handle 70 products. Each line is configured differently to handle a grouping of products with similar processes. Each product though still has slightly different components and assembly operations.
Does each product need its own FMEA/DCP?
I have the same worry as above, managing each document during a sweeping change to the assembly lines. Also, many of the product operations, such as screwing in components, would have identical failure modes.
Ninja
Looking for Reality
Note that "Suffice" and "Should" and "My Boss Wants" are three very different things.
I agree with Jane S. on the "Suffice" part.
Your common sense can guide you on the "Should" part.
And "save as" can help you with the "My Boss Wants" part if you can't talk your way around it.
If "Suffice" and "should" are already met...explain that, as well as the added expense of managing the document copies for similar products...but at the end of the day...the word "Boss" is there for a reason...don't lose sight of it.
GRP
If you are in the automotive industry and you want to align with SAE J1739, then:
A process family FMEA is a PFMEA covering a series of operations that produce multiple products or part numbers. Processes producing many similar products do not need unique FMEA’s for each product. The family PFMEA is dictated by the manufacturing process that is used to make the product, not by the product’s functional requirements or application. When the manufacturing process is the same as other parts in the family then a family PFMEA is appropriate.
In this way you can justify having, say, 3 family PFMEAs for each 70 product assembly line. Make sure you maintain an updated reference to the drawings, and make sure you do not compromise on the pfmea outputs. I would definitely raise the issue to the boss with an argument backed up by standards and regulations.
A further note on this line: The family PFMEA is dictated by the manufacturing process that is used to make the product, not by the product’s functional requirements or application
I would tread with caution the statement that the intended application of the product is beyond the scope of the PFMEA. As I have argued in this thread PFMEA severity score different applications, the application of the product IS important for the effects and severity table.
Mr.Blue
Thanks, this discussion so far has been very helpful.
I was recently at a conference where I was able to discuss this topic with some other QE's. They all agreed that a family PFMEA was the right choice although they added that to capture the unique aspects of certain products, you may still need smaller product PFMEAs. The content of these product PFMEA would only cover unique attributes such as special steps, materials or quality incidents among other things. For all generic steps on the product PFMEA, the line would state the step and reference the family PFMEA for scoring and actions.
This makes sense to me if we are trying to capture all potential risk. That being said. Including the generic steps that reference the family PFMEA would require that all documents potentially need updating when a big change roles through. Without the steps on the product PFMEA, a user trying to understand the logical progression will have difficulty.
The line, The family PFMEA is dictated by the manufacturing process that is used to make the product, not by the product’s functional requirements or application, sounds like it's trying to address this potential overlap. If you don't factor in the application of the products then it reduces the number of unique factors across the products.
What are the thoughts on this approach? Is best practice only to perform the family PFMEA? Or does a breakdown between family and product PFMEA make sense? Is there another option?
GRP
I can't backup this up with standards, but I would stick to the family PFMEA and make a handful of product PFMEA with the differences. I would not try to "fill the gaps" with generic content. If for any reason your organization decides to go with "filling the gaps", and supposing you use MS Excel, just unleash the power of Visual Basic.
As for people struggling to make sense of the progression, they can find their way with the flowchart.
Besides, I can imagine there are some out there who would root for not being too straightforward with documentation in times of audit :notangel:
northbranch
If I remember correctly, my old company used family PFMEA's for processes, such as stamping, wash, weld, etc... The part PFMEA would then reference the process PFMEA and then with only what was specific with that part (wash temp, hardness info, etc).
OpExPro AIAG VDA FMEA Rating Tables FMEA and Control Plans 5
OpExPro The note at the bottom of DFMEA occurrence tables in AIAG VDA FMEA FMEA and Control Plans 0
Q FMEA and Risk assessment in Microsoft Access FMEA and Control Plans 6
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
G FMEA financial benefits APQP and PPAP 2
M Foundation FMEA: what is it? FMEA and Control Plans 15
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering Catching up on the new FMEA book! Funny Stuff - Jokes and Humour 2
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
J New FMEA aproach - formular Manufacturing and Related Processes 2
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
Jimmy123 ISO 31000 vs FMEA FMEA and Control Plans 1
Jimmy123 What is a Reverse FMEA? FMEA and Control Plans 6
I What does "Class" mean in an FMEA? FMEA and Control Plans 16
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
C VDA Vol.4 - Evaluation of an FMEA FMEA and Control Plans 0
D Do you need requirements for a Design FMEA FMEA and Control Plans 1
D System Level FMEA example wanted FMEA and Control Plans 2
