FMEA Detection Ranking for Testing Machines
Rajendrak
How the detection ranking of the testing machine shouls be done?
e.g. in a process for 'X' product, the product is tested for leak in leak testing machine. Now as per the fourth edition of FMEA manual (page99)
: Assume the failure has occured & then access the capabilities of all "current process controls" to prevent shipment of the part having this failure mode.
Now in this leak test should we assume that leak testing machine has failed to detect the leak & we have to detect in next process before shipment?
Is this logic clear? or we should not consider failures at testing machine?
Please help!
Tore Forland
Interesting problem.
I believe that failures in your controls are not taken into account when you perform the FMEA (detection). This should already be built into the detection scale (1-10)
If the leak testing machine is of great importance you could conduct a separate FMEA on this equipment to improve it, but normally fulfilling monitoring of the measurement systems should be enough to ensure you always have "correct" readings. After all, there is a whole section on this in most standards.
I hope I understood your concern correctly, and the answer helped, but I also hope you will get some more replys on this important issue.
I agree. There is some process for which the leak tester serves as a detection control, and its probability of failure should be a part of the detection RPN value for the process or operation.
Rajendrak
failures in controls are taken into account when we performed the FMEA (detection).
But a customer complaint triggered the issue. This points to wrong detection ranking. Now should we think of reviwing detetction ranking or do fmea for this machine alongwith the FMEA of all testing machines?
Chennaiite
Never-say-die
In the first place, the fact that you ended up with Customer complaint indicates that initial estimation of detection capability of your testing process had gone wrong and was comfortable enough not to trigger any action.
I would now suggest you to first address testing process separately in FMEA. By doing this, you are basically trying to improve the detection capability of the testing process, per se. Now this shall indeed be followed by review of detection ranking at relevant process steps, understandably so.
The fact that something bad happened doesn't necessarily mean that the Detection ranking was wrong. It means that it should be reviewed. Unless the PFMEA prediction was that nothing would ever go undetected, the current issue might be consonant with the original prediction.
Chennaiite
Never-say-die
I don't think in this particular case original prediction is consistent with the current issue.
This is what the OP says-
What he said was the a customer discovered the issue, and that fact "points to wrong detection rating." If he believes his detection rating was wrong, he should fix it. All I was saying was that the fact that an escape occurred doesn't necessarily mean that the original rating was wrong. In fact, it's possible that the OP's detection controls are performing better than originally predicted.
Rajendrak
Can I say that taking the testing machines under FMEA & then try to improve or review their detection ranking will be a better solution for the future?
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
M DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted IATF 16949 - Automotive Quality Systems Standard 6
V Detection ranking in FMEA FMEA and Control Plans 4
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
A Process FMEA - Help in deciding "detection ranking" of a failure mode FMEA and Control Plans 5
A FMEA Manual - Page 53, Table 8 says Detection Ranking FMEA and Control Plans 3
B FMEA - Reduced Detection Ranking by Use of Preventative Maintenance FMEA and Control Plans 6
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
K Creating together Standard Definition for Prevention and Detection FMEA FMEA and Control Plans 1
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
G Determining the "Detection" Number Component of the FMEA RPN FMEA and Control Plans 5
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
K Design FMEA Detection Scoring - FMEA 3rd edition manual FMEA and Control Plans 7
Q FMEA: Visual Detection Rating IATF 16949 - Automotive Quality Systems Standard 25
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
I FMEA Detection Rating - What is Soft or Hard? FMEA and Control Plans 7
A DFMEA (Design FMEA) - Occurance and Detection Ratings FMEA and Control Plans 2
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
P The Origin of the FMEA Detection Rating FMEA and Control Plans 7
C FMEA - Prevention vs. Detection FMEA and Control Plans 6
M FMEA: Which Severity, Occurrance, Detection scale in healthcare? FMEA and Control Plans 3
R FMEA for Process Planning - Travelers - Severity, Occurrance, Detection FMEA and Control Plans 10
B Detection Evaluation Criteria in the FMEA book is very vague FMEA and Control Plans 14
E FMEA Severity, Occurrence, and Detection Rating - I am in need of some examples FMEA and Control Plans 19
T FMEA Detection Ratings - Multiple layers of acceptance? FMEA and Control Plans 10
J FMEA - What is the relationship between Detection and Prevention? QP Newbie question. FMEA and Control Plans 12
Q Process FMEA - Need help to clarify O (Occurrence) and D (Detection) rankings FMEA and Control Plans 26
T FMEA for Service Provider - Detection Level Criteria - Batch Heat Treater FMEA and Control Plans 2
M PFMEA Detection Evaluation Criteria - Visual Check - Page 52 of the AIAG FMEA manual FMEA and Control Plans 2
A Corrective Action vs. FMEA Occurance, Detection, Severance Nonconformance and Corrective Action 5
M Reducing both Detection and Occurance in a Design FMEA WITHOUT a Design Change FMEA and Control Plans 8
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
