FMEA - Preventive vs Detection Control
Jimmy123
I have always a discussion when I have write a test into the detection or prevention control. Example I do a leakage test with different parameters. The intention is to prevent a weakness of my design. Why should I write this as a detection? Any definition what’s the characteristic of the measure?
Is this for a DFMEA or PFMEA? I am guessing you meant DFMEA.
It would be difficult for a leakage test to prevent a design weakness. By the time you get to the point of testing, the design is nearly finalized, so this would be detection. An example of a preventative design control would be a finite element analysis of a design concept. This would allow you to revise the concept before the first prototype was built thus preventing the design weakness.
Jimmy123
But, we discussed, if the leackage test is done the effidence of the design is proved, that means related to occurrence.
Cephissus
If you make multiple leak tests by changing various dimensions each time, you are using the leak tests to define your components dimensions, it qualifies as such as a Prevention Action.
If you have already determined the dimensions of your components and which to see whether your design is robust by leak testing, then it is a detection action.
What do you think?
John Predmore
In a DFMEA, which is the failure analysis of a design process, a low Detection score indicates confidence that the Design activity is likely to uncover a design shortcoming (such as a tolerance stackup) which was otherwise overlooked in the design. If there is a potential failure of the design output, for example a seal not being robust under all conditions and the failure effect is severe, one way to improve the RPN score is greater validation activity. That could mean longer test runs, larger sample size, inner/outer array type DoE, HALT, intentionally building worst-case tolerance stack-up combinations, testing artificially aged parts. In one sense, you are preventing a failure which has not yet occurred, but through detection in the design engineering process.
P Are regular reviews and updates of FMEA's Preventive Actions? IATF 16949 - Automotive Quality Systems Standard 4
C FMEA as corrective tools or preventive tool? FMEA and Control Plans 11
Raffy Preventive Action - Does generating an FMEA help future containment? Preventive Action and Continuous Improvement 2
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
G FMEA financial benefits APQP and PPAP 2
M Foundation FMEA: what is it? FMEA and Control Plans 15
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering Catching up on the new FMEA book! Funny Stuff - Jokes and Humour 2
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
J New FMEA aproach - formular Manufacturing and Related Processes 2
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
Jimmy123 ISO 31000 vs FMEA FMEA and Control Plans 1
Jimmy123 What is a Reverse FMEA? FMEA and Control Plans 6
I What does "Class" mean in an FMEA? FMEA and Control Plans 16
M FMEA/DCP Structure and Quantity - Similar Parts and Processes FMEA and Control Plans 7
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
C VDA Vol.4 - Evaluation of an FMEA FMEA and Control Plans 0
D Do you need requirements for a Design FMEA FMEA and Control Plans 1
