FMEA Ranking and Prioritization - Failure Modes with higher severity first?
Correct me if I'm wrong, but I understand that the approach for FMEA prioritization is to go for Failure Modes with higher severity first, rather than the RPN calculation.
If I read the Detection ranking table correctly, the ranking '1' is where a mistake proof, or error proof is in place, thus it is impossible for the failure mode to happen. Thus, if we have identified a Failue Mode with a severity = 7, occurence = 5, and detection = 1, it is for sure that we are not going to do anything even though the RPN = 35, as with the detection = 1, no way the failure mode will happen again.
Am I right for the 2 occasion above ?
Geoff Cotton
YKT,
If the process has been mistake proofed and it is impossible to happen (occur), should your occurrance ranking be more like 1?
Randy Stewart
YKT,
We teach our people to look at the Severity x Occurance scores to pick out the identified problem areas. In our fixture design operations first time quality matrix you would see that the highest occurance is spelling errors (8), detection is low (8) so this part of the RPN is a 64. However when you put in the severity score (1) it should become a non-issue. IMO you need to look at both severity and occurance, you don't want to spend resources on a high severity when the occurance is 1 in a million nor for something that may happen a lot but doesn't mean much to the customer (i.e. spelling errors).
An added benefit is that it's another way to show how customer requirements and COPs are passed down through the entire operation.
Bill Ryan - 2007
I agree with Geoff. If you can't produce the nonconformance your Occurence rating should be 1. If your Occurence rating is "truly" a 5 and you are "detecting" the nonconformance, you are "good to go" with the Dectection rating of 1 (just to clarify - you are not preventing the nonconformance but have a means to sort it out so it can't be shipped).
Randy's methodology of "prioritizing" action plans is a good one but there is no "fast rule" other than at least looking at any Severitys of 9 or 10 (Safety issues), possibly even 7 or 8 (Warranty issues) and making sure they are addressed as necessary.
Bill
Randy Stewart
A low detection rating means that the "Failure Mode" happens I am just great at catching it. I can't produce the part etc. But it is after the failure occurs. The customer doesn't see it but I still have rework or sort or whatever. I just can't pass a bad part. At least that's how I read it.
This is proactive and not based on Detection. This is the prevention of occurance not detection of the occurance.
Bill said:
you are not preventing the nonconformance but have a means to sort it out so it can't be shipped.
:agree:
Al Dyer
Not being disparaging, but an occurance rating of 1 could raise a real red flag. Is any system truly controlled to a point where mistakes will never happen?
Does this go against the thought of "process variation"?
Can we really have a straight line on a variable chart showing no variation in our product or process?
Can topics on a contingency plan truely address that all possible variables to the process are covered?
A small power surge occurs which affects the reliability of a gage.
Water pressure drops and the CNC's are not replentished to the proper levels.
Someone introduces a similar, but incorrect wrong part into the process.
I guess my overall point is that a process can never be truly error-proofed and therefore in the FMEA there should never be a rating of 1.
And as was said, occurance needs to be matched with severity to get a true picture for continuous improvement activities.
MHO
Al...
Randy Stewart
Not the Intent
Al,
I think I understand the point you are trying to make. However, I don't agree with the examples given.
Both of these are outside the scope of a Process FMEA and should be addressed under different documents (#1 - MSA, #2 - Maintenance).
On pg. 31 of the FMEA book, the last sentence under 10) Potential Failure Mode reads " . . . the assumption should be made that the incoming part(s)/material(s) are correct.
So, this too, falls outside the scope of the FMEA.
When developing the PFMEA we have to be very careful that we do not get into "theoreticals" and make it so deep it is no longer a useful document.
thanks for the feedbacks.
Yes, let say the process has been mistake-proofed, so can i put the detection as '1' ?
In doing FMEA, first you identify the failure mode and then the effect to the customers, thus you assign a Severity ranking.
Then, with fishbone diagram, we come up with the causes, and assign occurence rating to each of them, and lastly see the current process control we have.
If at the last stage, we realised that the process has been mistaked proofed, do we take out the failure mode (erase it) ? or do we put Det =1.
If we still put Det=1, we may have Sev=8, Occ = 5, (based on old historical data), and Det = 1, which the RPN = 40, do we still have to take action ? Basically, no action, right, asthe process has been mistake-proofed.
Any comments ?
Al Dyer
Re: Not the Intent
Originally posted by Randy Stewart
Al,
...When developing the PFMEA we have to be very careful that we do not get into "theoreticals" and make it so deep it is no longer a useful document.
Very true, it is easy to get too theoretical and make the FMEA tool useless in real-time application.
And you are right to disagree with my examples, they should me addressed by a process that "could" feed into a possible mention on a FMEA.
My concern is stating an "Occurrance" rating of 1 in an initial FMEA leaves no room for improving the occurance rating. I can see starting with a 2 then after monitoring the process for a period of time and collecting imperical data, revising the the rating to a 1.
I believe my opinion is the result having many FMEA's rejected for occurance ratings of 1, whether or not based on actual data.:ca: :agree:
Al...
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
N Process FMEA Occurrence Ranking for New Process FMEA and Control Plans 3
K Process FMEA Ranking Table for for Landing Door of an Elevator FMEA and Control Plans 7
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
C Poka Yoke and FMEA Detection Ranking FMEA and Control Plans 3
B FMEA Ranking Rating Best Practices FMEA and Control Plans 10
G FMEA Occurrence Ranking - Based upon what? FMEA and Control Plans 6
R FMEA Detection Ranking for Testing Machines FMEA and Control Plans 8
M DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted IATF 16949 - Automotive Quality Systems Standard 6
V Detection ranking in FMEA FMEA and Control Plans 4
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
B FMEA Occurrence Ranking in Microelectronics FMEA and Control Plans 24
A Process FMEA - Help in deciding "detection ranking" of a failure mode FMEA and Control Plans 5
S VDA vs. AIAG - FMEA Ranking FMEA and Control Plans 4
A FMEA Manual - Page 53, Table 8 says Detection Ranking FMEA and Control Plans 3
J FMEA - Method of Determining the Occurrence Ranking FMEA and Control Plans 4
B FMEA - Reduced Detection Ranking by Use of Preventative Maintenance FMEA and Control Plans 6
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
G FMEA financial benefits APQP and PPAP 2
M Foundation FMEA: what is it? FMEA and Control Plans 15
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering Catching up on the new FMEA book! Funny Stuff - Jokes and Humour 2
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
J New FMEA aproach - formular Manufacturing and Related Processes 2
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
