FMEA Severity 9 &10 - Example of "with warning?"
Tazstina
Hello to all! So much great advice here in this forum and I am still very new here and just a couple of years of work experience.
I am trying to explain FMEA to a few colleages and I can not describe the difference between 9 and 10 as described with warning and without warning respectively. These definitions are all over the Cove and the Web but I can not find an example of "with warning" that does not include a control measure. Control measures are later in the detection and i do not believe they should be included in the definition of severity. Am I wrong? Can someone give me a couple of examples of a 9 "with warning"?
Thanks for any help you can give!! Would really appreciate it!
Re: FMEA Severity 9&10 - example of with warning?
You can see some simple examples every time you start your car and all of those warning lights briefly turn on.
Tazstina
Thank you very much for your response and example but I still don't understand.
Aren't those lights methods of detection for a failure mode and not a way to define severity?
Stijloor
Think about oil in your engine for a moment.
Part of the car servicing process is to put xxx quarts of oil in the engine.
Think about possible failure modes associated with this process step.
  1. No oil
  2. Too much oil
  3. Insufficient oil
  4. Incorrect oil
Let's now take "No oil" as an example.
What would be the possible effects of this failure mode?
"Major engine damage."
If you did not have any oil lights on your dashboard display, you would have no way of knowing and the engine damage could possibly be beyond repair. (Without Warning) Severity 10.
If you have oil lights on your dashboard display, you would be able to immediately shut off the engine and limit the engine damage. (With Warning) Severity 9.
Simple non-high tech example. :agree1:
Hope it helps.
Stijloor.
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
S What should the FMEA Severity for SC & CC Characteristics be? FMEA and Control Plans 4
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
C FMEA DOGMA about Severity - Am I right or Wrong? FMEA and Control Plans 2
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
P Chemical Purity Testing - FMEA Severity Scale FMEA and Control Plans 2
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
I Ford FMEA requirements for Severity and Occurrence Rankings Customer and Company Specific Requirements 1
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
kedarg6500 FMEA Severity Scale - Higher for Failure at Customer's or End-Customer's place? FMEA and Control Plans 19
M FMEA Severity Ratings for Health Care Information System FMEA and Control Plans 10
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
S FMEA Severity of 9 or 10 - Shower does not operate FMEA and Control Plans 13
M FMEA: Which Severity, Occurrance, Detection scale in healthcare? FMEA and Control Plans 3
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
S FMEA Severity Rating - Will a Process Design Change also Change the Severity Rating? FMEA and Control Plans 21
B Automotive Severity 10 - Supplier Response - FMEA for an electronic product FMEA and Control Plans 8
R FMEA for Process Planning - Travelers - Severity, Occurrance, Detection FMEA and Control Plans 10
E FMEA Severity, Occurrence, and Detection Rating - I am in need of some examples FMEA and Control Plans 19
T Process FMEA (Failure Modes Effects Analysis) Severity Rating and RPN IATF 16949 - Automotive Quality Systems Standard 17
Y FMEA Ranking and Prioritization - Failure Modes with higher severity first? FMEA and Control Plans 21
Kevin Mader FMEA Severity Index - Leading contributor to the RPN value FMEA and Control Plans 9
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
