FMEA Severity of 9 or 10 - Shower does not operate
Stanley P
Bare with me as some of this FMEA is somewhat new to me. There may be an obvious answer to this.
I am unsure as to how to score the severity on a chemical decontamination shower. For a failure where the shower does not operate, would this be considered a severity of 9 or 10. The primary function is to rinse potentially harmful chemicals in a possible emergency situation. My dilema is whether the shower not functioing causes bodily harm. The shower itself is not causing any harm, it just lost it's ability to serve it's primary function. (An 8 then?)
I have already been lectured from someone in the company that if we identify any products as a 9 or 10 we are opening the company up to liability if we don't take appropriate action. I'm feeling ethical pressure to call as I see it. Am I looking at this incorrectly?
If a 9 or 10 is appropriate, then are many safety products like these a 9 or 10 if they lose primary function.
Any advice is appreciated.
G
grismosw7
Severity is what it is, you are just as liable I would think if you made it an 8 when it should be a 9.
Occurance and Detection are the areas you should focus on to reduce your RPN. Your opening the company up to liability if you do not take action to reduce Occurance and improve Detection.
Anytime I have a supplier PFMEA with 9 or 10 for Severity I shoot for action to be taken to reduce Occurance and improve Detection regardless of RPN unless both are already at 1 or 2. I don't require it, unless it fails to meet the RPN threshold.
D.Scott
Welcome to the Cove Stanley.
I think you are right to class failure as a 9 or a 10. If you were making engines for a plane and the engine failed, the engine itself wouldn't cause any harm but the sudden stop when hitting the ground certainly would.
You have to realistically evaluate the effect of failures in all three areas of an FMEA. Remember, you can not normally reduce the Severity with quality tools. Reduction there usually requires a design change. If your customer has design responsibility, their attention needs to be directed to that failure mode. If the design responsibility rests with your company, it won't matter if you define the failure mode as a 1 or a 10. Your company will still be legally responsible if it fails. It is better to identify a problem and fix it now.
Having said that, don't "invent" failure modes that have already been engineered out. For example - if the shower doesn't function "as it should" but still provides a rinse, does the failure still result in burns? When organizing an FMEA, be sure the failures you define can reasonably occur.
Dave
Kales Veggie
People: The Vital Few
welcome to the cove.
You might already have thought of this.
What can be done, so that the shower is not needed, what prevention methods can be implemented so that chemicals are not spilled and can not get in contact with human skin.
The shower is needed, because a step in the process failed.
(OSHA or similar might still require that you have a shower).
G
Geoff Withnell
I am very glad you are feeling ethical pressure to call it as I see it. My suggested response to the lecturer would be that we have a positive ethical/moral obligation to protect our staff and others in the area of the hazardous material, and if we do that properly, a liability issue will not arise. As an added response, it is quite proper to add the liability to the "effects" caused by the failure.
Geoff Withnell
Randy
The need for the shower is an OSHA requirement and is only "required" when a corrosive is involved. It's considered a best practice for showers to be available for all chemicals
(29 CFR1910.151(c)
Where the eyes or body of any person may be exposed to injurious corrosive materials, suitable facilities for quick drenching or flushing of the eyes and body shall be provided within the work area for immediate emergency use.
You have liability no matter what you do and how well you do it.
It would depend upon the material, but probably yes. How are 9 and 10 defined? Do the numbers mean anything? What's the difference?
My undergrad degree is in Occupational Safety and Health and I've managed safety programs. This is safety/regulatory and not a quality issue
reigelser
Hi and welcome to the cove!
After reading the posts there were many good points. To clarify it would be interesting to know: are you the user of that shower or do you manufacture the shower?
Joachim
D.Scott
Stanley,
Just for clarification, is this a shower in your plant or does your company make and sell the shower?
Thanks,
Dave
Randy
Good questions do you make or use the shower?
Here's you answer guys. It doesn't matter because you have to consider worst case scenario when personal safety is involved. Ask any safety professional...wait a minute I am a safety professional!
skuziej
Role: Our company will be the producer of the shower.
Thanks to all for the insightful comments.
It's reinforcing my stand for 9's or 10's.
I also appreciate the comment on whether the thought of failure modes are possible. I'm not the expert on the product so I'll will pose this question to the appropriate parties.
Some other comments that have been brought up are:
Customers are required by OSHA to test the shower on a weekly basis. Does this reduce our severity score at all? From failure without warning (10) to failure with (9)?
What about our warnings in the product instructions about testing the unit for operation at installation and communicating the OSHA requirements of testing once per week.
I appreciate the help as this is one of the 1st uses of FMEA for our company.
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
S What should the FMEA Severity for SC & CC Characteristics be? FMEA and Control Plans 4
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
C FMEA DOGMA about Severity - Am I right or Wrong? FMEA and Control Plans 2
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 25
P Chemical Purity Testing - FMEA Severity Scale FMEA and Control Plans 2
T FMEA Severity 9 &10 - Example of "with warning?" FMEA and Control Plans 6
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
I Ford FMEA requirements for Severity and Occurrence Rankings Customer and Company Specific Requirements 1
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
kedarg6500 FMEA Severity Scale - Higher for Failure at Customer's or End-Customer's place? FMEA and Control Plans 19
M FMEA Severity Ratings for Health Care Information System FMEA and Control Plans 10
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
M FMEA: Which Severity, Occurrance, Detection scale in healthcare? FMEA and Control Plans 3
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
S FMEA Severity Rating - Will a Process Design Change also Change the Severity Rating? FMEA and Control Plans 21
B Automotive Severity 10 - Supplier Response - FMEA for an electronic product FMEA and Control Plans 8
R FMEA for Process Planning - Travelers - Severity, Occurrance, Detection FMEA and Control Plans 10
E FMEA Severity, Occurrence, and Detection Rating - I am in need of some examples FMEA and Control Plans 19
T Process FMEA (Failure Modes Effects Analysis) Severity Rating and RPN IATF 16949 - Automotive Quality Systems Standard 17
Y FMEA Ranking and Prioritization - Failure Modes with higher severity first? FMEA and Control Plans 21
Kevin Mader FMEA Severity Index - Leading contributor to the RPN value FMEA and Control Plans 9
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
