FMEA Severity Scores Between Two Sister divisions?
Hello to all the Elmar Covers
I wonder if you guys can leand me your expertise, I recently moved to medical device company after working several years in Aerospace industry. My question is, is it a common practice in medical device industry for sister divisions to duplicate FMEA since both have the same identical process and product produced? Is it common to keep the severity the same for both companies while the rest of the fmea numbers updated?
I never seen such scenario before while working in Aerospace.
Omengramirez
IF the product is the same and the process is the ‘same’ then the severity of any failure modes should be the same. I can see that different locations could very well have different probabilities of occurence and different MSA effectiveness (detection) as most processes and measurement systems are never exactly the same.
Why does this bother you? Other than the fact that you’ve never seen it. Can you give us some concrete examples that you question?
John C. Abnet
Teacher, sensei, kennari
...in addition to the counsel/questions provided by @Bev D , remember, that SEVERITY (assuming it was stated / ranked correctly ) can only be changed if...
- design changes
- application changes
Bolt is used to hold on wheel....severity may be quite high.
Bolt (same bolt) is used to hold in radio....severity is quite low.
Hope this helps.
Be well.
@Bev D. Thanks for the input.It doesn’t bother me,it is more of a question of curiosity. Since I have not seen such practice. My understanding of FMEA scoring for Severity, Occurance and Detection is that, It is going to be subjective to the level of expertise of the group who performed the FMEA. So seeing Severity having exact same numbers is unusual for me since the group of expert on one division will not be the same group of expert from another division.
John C. Abnet
If the product is used in the identical application, then there is no reason the severity would not be identical at both locations since severity is defined as the EFFECT for a given failure mode (as perceived by the customer).
Hope this helps.
Be well.
Hope this helps.
Be well.
Thanks for the input. I forgot to mentioned on my previous post that It just a Process FMEA and not the risk management standard ISO14971. Thanks again.
@Bev D. My understanding of FMEA scoring for Severity, Occurance and Detection is that, It is going to be subjective to the level of expertise of the group who performed the FMEA. So seeing Severity having exact same numbers is unusual for me since the group of expert on one division will not be the same group of expert from another division.
Even if you assemble the most senior people into a group it does not make them experts. If there are sister divisions using the same processes there should be sharing and collaboration. The laws of physics do not have any geographical or ‘cultural’ uniqueness.
Severity should not be a subjective decision at all. It is a matter of physics and understanding the effects of any given failure mode.
Occurence and Detection should also not be subjective although I know that some engineers and managers want it to be so that they can manipulate the results - or not do the work necessary. Occurrence should come from the development/validation process experiments. Detection should come from the actual MSA studies. (It’s OK that initial subjective ratings may be used - although I prefer no rating at all to use as a place holder - but the final numbers are supposed to come from actual testing)
Most modern FMEA in both automotive and medical devices and other industries have removed detection from the “RPN” Calculation and only use it as a mitigation / control.
C FMEA Severity Rating for aggravating failures IATF 16949 - Automotive Quality Systems Standard 6
X Customer Service FMEA - Specifically Customer Care / Severity Rankings Service Industry Specific Topics 3
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
S What should the FMEA Severity for SC & CC Characteristics be? FMEA and Control Plans 5
N AIAG 4th ed. FMEA Manual "Fit" Changed to "Appearance" - Fit severity? FMEA and Control Plans 2
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
S FMEA's - Severity and Classification of Print Characteristics FMEA and Control Plans 1
C FMEA DOGMA about Severity - Am I right or Wrong? FMEA and Control Plans 2
K 4th Edition AIAG FMEA Occurrence, Severity and Detection Criteria for Plastics FMEA and Control Plans 1
M Severity Reduction in a Design FMEA (DFMEA) FMEA and Control Plans 26
P Chemical Purity Testing - FMEA Severity Scale FMEA and Control Plans 2
T FMEA Severity 9 &10 - Example of "with warning?" FMEA and Control Plans 6
A AIAG Design FMEA Severity Rankings - Noncompliance Government Regulation? FMEA and Control Plans 9
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
L FMEA Occurrence, Severity and Detection Criteria FMEA and Control Plans 3
I Ford FMEA requirements for Severity and Occurrence Rankings Customer and Company Specific Requirements 1
G FMEA Severity Ranking for an Automotive Audio System FMEA and Control Plans 9
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
kedarg6500 FMEA Severity Scale - Higher for Failure at Customer's or End-Customer's place? FMEA and Control Plans 19
M FMEA Severity Ratings for Health Care Information System FMEA and Control Plans 10
Y Severity, Occurrence and Detection FMEA Ranking Tables - Guidelines? FMEA and Control Plans 8
L FMEA - Should a severity of 9 or 10 be always followed by recommended actions? FMEA and Control Plans 2
S FMEA Severity of 9 or 10 - Shower does not operate FMEA and Control Plans 13
M FMEA: Which Severity, Occurrance, Detection scale in healthcare? FMEA and Control Plans 3
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
S FMEA Severity Rating - Will a Process Design Change also Change the Severity Rating? FMEA and Control Plans 21
B Automotive Severity 10 - Supplier Response - FMEA for an electronic product FMEA and Control Plans 8
R FMEA for Process Planning - Travelers - Severity, Occurrance, Detection FMEA and Control Plans 10
E FMEA Severity, Occurrence, and Detection Rating - I am in need of some examples FMEA and Control Plans 19
T Process FMEA (Failure Modes Effects Analysis) Severity Rating and RPN IATF 16949 - Automotive Quality Systems Standard 17
Y FMEA Ranking and Prioritization - Failure Modes with higher severity first? FMEA and Control Plans 21
Kevin Mader FMEA Severity Index - Leading contributor to the RPN value FMEA and Control Plans 9
J FMEA IATF 16949 - Automotive Quality Systems Standard 3
D FMEA FMEA and Control Plans 20
L General FMEA Question FMEA and Control Plans 2
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
O FMEA rankings vs Hazard Analysis Rankings ISO 14971 - Medical Device Risk Management 16
Y Stellantis FMEA Report IATF 16949 - Automotive Quality Systems Standard 10
Sidney Vianna IATF 16949 News AIAG/VDA harmonized approach to FMEA IATF 16949 - Automotive Quality Systems Standard 0
S AIAG-VDA FMEA tutorial and completely filled FMEA FMEA and Control Plans 1
W Reconciling FMEA RPN ratings with Risk Acceptability ISO 14971 - Medical Device Risk Management 22
Q VDA Standard - VDA FMEA VDA Standards - Germany's Automotive Standards 11
Y Foundation FMEA FMEA and Control Plans 4
C FMEA Software Report View FMEA and Control Plans 1
G FMEA versus control plan IATF 16949 - Automotive Quality Systems Standard 6
M BMW requirements for FMEA IATF 16949 - Automotive Quality Systems Standard 9
Anerol C FMEA workshop training South of Texas FMEA and Control Plans 0
Anerol C FMEA Training for South Texas Service Industry Specific Topics 0
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
