FMEA vs. Kepner Tregoe Struggle - Management doesn't want to use FMEA
Q
qualityboi
Currently we have some internal turmoil going on regarding KT analysis vs. FMEA. Management wants to be ISO/TS certified but has just spent all kinds of money using KT as a problem solving and risk analysis tool. They don't want to use FMEA. My argument (and I really suck at on the spot debate and selling ideas) was that in order to get into the automotive market you need to be ISO/TS certified and use FMEA as the accepted risk management tool. This argument is not working. So how can I convince management to use FMEA (design and process) so they can execute their own strategic plan of selling into the automotive market? :bonk:
Does anyone have any arguments on how FMEA can compliment the KT analysis (Potential Problem Analysis) and be used as a valuable tool, not something that is just done to achieve conformance to the TS standard? I realize its implicity as a valuable tool ...but they don't...:argue:
Re: FMEA vs Kepner Tregoe Struggle
If your potential customers require AIAG/SAE-style FMEA, that's what you have to do. That doesn't mean that you can't do whatever else you want to do wrt quality improvement. Many companies, for example, do Six Sigma in addition to using the automotive "core tools." Your management can complain all they want, but if they want to go to Rome, they're going to have do like the Romans do.
Q
qualityboi
I agree and made that argument. They have used lean terminolgy in describing it as waste (none value added) since they are already doing PPA (potential problem analysis. I really don't know what other reason to give.:(
Do they understand what "requirement" means? There might be a few customers here and there who will listen to reason in the automotive world, but believe me, there aren't many. "Negotiations" in automotive work usually go something like this:
Automotive Customer: Here are the requirements. Follow them to the letter.
Supplier: But it makes no sense for my company. What if I do x instead?
Automotive Customer: We aren't allowed to make decisions that favor suppliers, ever. Here are the requirements. Follow them to the letter.
Wes Bucey
Sometimes, just sometimes, "a rose by any other name" is the argument to make here.
The point of ANY modern Quality Management System is to engage in a style of pre-planning which identifies and avoids potential pitfalls in meeting the requirements of customers.
Many of the so-called "CSR" (Customer Specific Requirements) in the automotive world are an outgrowth of that pre-planning wherein automotive OEMS have identified potential pitfalls and set forth requirements to reduce or eliminate such pitfalls BEFORE they happen.
One of the hallmarks of automotive FMEA is the concept of "weighting" the potential pitfalls according to frequency of probable occurrence and severity of "failure" if it does happen. Regardless of what you call the process of "pre-problem solving," that's going to be necessary to mollify customers in the automotive supply chain. If you are NOT dealing with automotive CSR, you, personally, just worry about the results of the process, not what it is called. If you and your organization ARE dealing with automotive CSR, the bosses need to ignore their fascination with a specific name for the pre-planning and call it FMEA, making sure to include the "weighting" aspect.
It also helps to know the lower you are in the automotive supply chain, the less stress the link above you will put on what you call FMEA, as long as you show results.
Added in edit. The very fact you are aiming for ISO9001:000 versus TS16949 implies all the automotive talk is moot and you probably can get along with any terminology the bosses choose as long as it works, since ISO9001 does not address FMEA by name.
David DeLong
I took KT training in the late 70's and it was great stuff. I was also a Quality Manager in an automotive supplier and used Process FMEAs. I now train in FMEAs (both Process and Design) and will state that they are absolutely great at preventing nonconformities.
Is your company heading towards TS certification? If they are, tell them that FMEAs are mandatory and it is the way to go. If not, forget it. Don't argue too much or it might be said that you have an attitude.
If top Management is onside, here is what I would do:
Get a bit of training in Process FMEA and then have a pilot project on a new project as long as top Management will allot the time and approve it using a small team of about 3 - 4 knowledgeable individuals.
Once you have completed the project, reflect it here since there are a great many people here who can help critique it and give some advise.
FMEAs are the absolutely the best way of preventing nonconformities.
Good luck!!!!
One other thing to consider is the linkage from the 'potential problem tool' to the Control Plan down stream and from the process flow diagram up stream. Are your management familiar that you don't simply 'do' FMEAs, they are part of the overall APQP requirements, to meet most automotive customers' requirements. The other posters are correct (well put Jim!) but maybe your management don't see the bigger picture of APQP and how KT fits.........
Duke Okes
It's a simple formula: You want automotive business? If yes, do the customers you want require TS? If yes, you must do FMEAs. If not, they will not be a customer. End of discussion.
Y
Yew Jin
I believed by using both FMEA and KY method objective is same - end in mind we will have risk analysis and contigency plan.
I also believed that your company vision should be bright such as to be world class manufacturing company. So, do the right thing at the first time will shorten the time to meet the vision.
Sometime we can list down the advantage and disadvantage for the both method which included benefit and cost to emphasis that we want to use the FMEA instead KT method.
I am sure if they do not want use FMEA must have their reasons. Find out what is the reason behind and work proactively to propose the alternative by using FMEA.
Some benchmark to change the management mind in below case......
Boss: Why you must go for training?
A: Training can improve our knowledge and skill
Boss: How if you leave after the training?
A: How if I stay and without any training?
Boss: ...............
Sometimes, I believed we can provide more evidence and data to show why FMEA is the most suitable in this case to them for justification. Perhaps they will buy the idea.
Good luck!;)
Good luck!;)
Yew Jin - the OP doesn't have the option to engage his management with philosophical discussions. If his company want automotive orders, they must use automotive recognized tools.........
Q FMEA and Risk assessment in MS ACCESS FMEA and Control Plans 2
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
J FMEA Handbook 2019 IATF 16949 - Automotive Quality Systems Standard 3
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
P Design FMEA - Detection Rating criteria ISO 14971 - Medical Device Risk Management 3
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
I Does anybody use Detection in medical device Design FMEA? ISO 14971 - Medical Device Risk Management 18
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
P Design FMEA for Industrial Machinery FMEA and Control Plans 3
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
R What are the changes in 5th Edition of FMEA manual? FMEA and Control Plans 6
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
Jimmy123 FMEA - Preventive vs Detection Control FMEA and Control Plans 7
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
L Which one is more important for FMEA CC or SC, FMEA and Control Plans 6
G FMEA financial benefits APQP and PPAP 2
M Foundation FMEA: what is it? FMEA and Control Plans 15
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
bobdoering Catching up on the new FMEA book! Funny Stuff - Jokes and Humour 2
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
J New FMEA aproach - formular Manufacturing and Related Processes 2
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
Z Using FMEA for Knowledge Management FMEA and Control Plans 6
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
R The difference b/w FMEA & Risk analysis as per iso 14971 ISO 14971 - Medical Device Risk Management 8
Jimmy123 ISO 31000 vs FMEA FMEA and Control Plans 1
Jimmy123 What is a Reverse FMEA? FMEA and Control Plans 6
I What does "Class" mean in an FMEA? FMEA and Control Plans 16
M FMEA/DCP Structure and Quantity - Similar Parts and Processes FMEA and Control Plans 7
Marc Definition DFMEA (Design FMEA) - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
J Looking for FMEA plastic injection molding FMEA and Control Plans 8
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
C VDA Vol.4 - Evaluation of an FMEA FMEA and Control Plans 0
D Do you need requirements for a Design FMEA FMEA and Control Plans 1
D System Level FMEA example wanted FMEA and Control Plans 2
G Can anyone tell me about Tooling FMEA FMEA and Control Plans 3
