Foam mattresses used in hospitals - compliance with MDR requirements?
RA_QA_Expert
Hi all,
must foam mattresses (without any clinical benefit, no prevention of bedsores (dekubitus) declared) used in hospitals meet MDR requirements?
Is it accessory for a hosptal beds? This type of mattresses
- is not being itself a medical device,
- is intended by its manufacturer to be used together with hospital beds
- supports the medical functionality of the hospital beds in terms of their intended purpose - to support patient body
Could manufacturers say, that that type of mattresses is neither ‘medical devices‘, nor ‘accessory of medical device‘?
The standard hospital requirements are hygiene and comfort "only".
Thank you in advance for your opinion.
Ronen E
Problem Solver
Moderator
IMO it is a Medical Device because an intention to mitigate/prevent many conditions is implied from the use.
As an example, a "hygiene requirement" implies prevention.
dgrainger
How can a hospital bed not have a medical purpose?
Location of a product does not define use, otherwise everything in a hospital would be a device. (An easier definition to implement though!!)
If it is a device, is the bed the device or is the mattress?
I would have thought that the mattress is the device and the bed the accessory (it just supports the mattress)
Under MDR, accessories have to be mentioned in the IFU and described in the technical documentation of the device.
Ronen E
Problem Solver
Moderator
Not location per se, but in this case the location goes hand in hand with a certain use which includes a medical purpose (in contrast with an ordinary bed at home). If we examine a proper hospital bed/mattress (not just any bed in a hospital) against the medical device definition, I think its intended use falls in at least one of the qualifying categories.
Whether the bed and the mattress (or maybe they are one product in some cases?) are medical devices or accessories thereto is an interesting question - it might be possible to argue both ways and the final result probably depends on the specifics (IFU contents, product specifications etc.). I didn't think it would matter too much though (not nil too, I agree), because accessories are essentially subject to the same requirements under the MDR as devices.
dgrainger
Sorry, went off question! - "must foam mattresses (without any clinical benefit, no prevention of bedsores (dekubitus) declared) used in hospitals meet MDR requirements? "
Under UK law - "Provision and Use of Work Equipment Regulations 1998 (PUWER)" requires that employers USE suitable equipment:
Safe use of work equipment. Provision and Use of Work Equipment Regulations 1998. Approved Code of Practice and guidance - L22
"53 Equipment must be suitable, by design, construction or adaptation, for the actual work it is provided to do. This means that when you provide work equipment you have to make sure it is suitable for the work being done and is used in accordance with the manufacturer’s specifications and instructions. If work equipment is adapted it must still be suitable for its intended purpose. "​
"138 Employers providing work equipment for use in the workplace should ensure that it has been made to the requirements of the legislation implementing any product Directive that is relevant to the equipment. This means that in addition to specifying that work equipment should comply with current health and safety legislation, you should also specify that it should comply with the legislation implementing any relevant EC Directive. You can check to see that the equipment bears a CE marking and is accompanied by the relevant certificates or declarations (ask for a copy of the EC Declaration of Conformity), as required by relevant product Directives"​
So, if it is intended for a medical use - yes the employer has to use CE marked mattresses.
If no medical use (guest accommodation?) then no. But the employer has to perform a risk assessment before choosing what to use.
PUWER implements Directive 2009/104/EC – use of work equipment
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
I ESD - Dissipative foam on a seat for where the people sit at benches Manufacturing and Related Processes 6
C Proper Thickness Gauge for Foam/Felt and Soft Materials General Measurement Device and Calibration Topics 5
D Requirements & Responsibility regarding Fire Foam in an Office Miscellaneous Environmental Standards and EMS Related Discussions 5
D Flammability EN 1021 - Polyurethane Foam that meets EN 1021-1 & 2 Other ISO and International Standards and European Regulations 3
S Do we need to submit our memory foam oxygen mask gasket for FDA approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How can I die cut foam - I'm thinking of a simple hand machine? Manufacturing and Related Processes 15
A X-Ray for Dimensional Inspection and Scanning for Defects within Polyurethane Foam Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M Polyurethane Foam Testing and Controlling the Foaming Process Manufacturing and Related Processes 6
B MSA for Application Test Results - Supplying liquid raw materials to foam producers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
A Shuttle Foam Question - Alternatives? Coffee Break and Water Cooler Discussions 13
Jim Wynne NASA's competence in question again - Crack found in external fuel tank foam Coffee Break and Water Cooler Discussions 6
M Are Polyurethane Foam Rolls Bulk Material? QS-9000 - American Automotive Manufacturers Standard 3
D Best Practices for Safe Handling of Rented Hospital Mattresses Hospitals, Clinics & other Health Care Providers 4
John Broomfield Informational Terms used in quality management Misc. Quality Assurance and Business Systems Related Topics 5
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
DuncanGibbons Looking for example aerospace part CAD files to be used for a case study Career and Occupation Discussions 2
I Custom software services to be used by medical software ISO 13485:2016 - Medical Device Quality Management Systems 1
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
R PMCF - centers/countries used CE Marking (Conformité Européene) / CB Scheme 0
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
G Can calibrated device values be used instead of manufacturers spec? General Measurement Device and Calibration Topics 2
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
I Recommendation about h and k values when CUSUM charts are used Statistical Analysis Tools, Techniques and SPC 4
R Please share your method used for PEMS Validation IEC 62304 - Medical Device Software Life Cycle Processes 5
M Can Brazil approval be used for other countries in Latin America? Other Medical Device Regulations World-Wide 2
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
O Validation approach for a Photostability Chamber (used for fluid therapy and injectable drug products) Qualification and Validation (including 21 CFR Part 11) 1
K Verifying gas tight glass syringe used for making standards General Measurement Device and Calibration Topics 4
J Regs for non-medical product to be used in hospitals - 61326 CE Marking (Conformité Européene) / CB Scheme 1
J Is Design Validation required for fixtures or test systems used to manufacture a product? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
M Informational US FDA final guidance Characterization of Ultrahigh Molecular Weight Polyethylene (UHMWPE) Used in Orthopedic Devices Medical Device and FDA Regulations and Standards News 0
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q ISO 3310 Clarification Help - Aperture sizes for sieves used for particle sorting Other ISO and International Standards and European Regulations 2
N What subcommands can be used with "Stop" in Minitab 18? Using Minitab Software 8
G Is the calibration due date of equipment used to be on calibration certificate ISO 17025 related Discussions 38
W Literature used in the clinical evaluation ISO 13485:2016 - Medical Device Quality Management Systems 4
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
W IEC 60601-1-2 Susceptibility/Immunity for device intended to be used in patient body IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Ninja Favorite (oft used) sayings... Coffee Break and Water Cooler Discussions 21
Q Calibration laboratory scope - Include software such as Gagetrak or Mini tab used? General Measurement Device and Calibration Topics 3
