"For Reference Only" - Internal and External Documents
N
noboost4you
I'm sure this question has been asked before and as I did find some information via searching, nothing was 100% clear to me.
Our Engineering department has a cabinet, which cannot be locked, marked as "Reference Only" on the outside. The inside contains thousands of hard copy drawings which contain all the essentials (Rev, Drawing Number, Date, Title, Appvd By, Checked By, Issued By, etc) but NONE of them have "For Reference Only" stamped or printed on them. We have this cabinet so Customer Service can "reference" the drawings at their leisure when customers have questions instead of asking an Engineer to print off another copy. Do we need to stamp each hardcopy? I'm thinking yes, because even though they are in a cabinet marked "Reference Only" that cabinet is not locked and once a drawing is removed from the cabinet, who's to say what it is?
As for External documents, we get/have hundreds of supplier catalogs and other outside information "floating" around. The majority of them are in a centralized location, but they are not documented. Once they come in, they go straight to the shelf. Do we need to document each catalog/external document that comes in electronically? Ex: Supplier A catalog comes in the mail today. Before placing it on the shelf, should I document that Supplier A catalog arrived 3/5/2007 and is located on Shelf AB? OR Could I just stamp each catalog "For Reference Only" and put them wherever?
This is a really foggy issue for me and I hope it can be cleared up.
Thanks,
Bryan
SteelMaiden
Don't make document control any harder than it needs to be. think "outside the filing cabinet" if you will. Do you have a list of each of those drawings? Does it give the latest rev level? Have you stated within your system that the printed drawings are for reference only and are not considered to be current unless the rev. level is checked against the list? (one solution) (I no longer own a "for reference only" stamp)
As for catalogs...I've never heard of anyone trying to control those. Please don't take this the wrong way, but who would care? There is usually some sort of date on a catalog "Summer 2007", so if it is 2010, I am thinking I'd call the supplier to see if they still have the "widget" and what its current price is.
If you have operators manuals for equipment, usually those are handled within the department that is using the equipment, or possibly maintenance, depending on the size of the organization.
Make your system work for you. There is no profit in over documenting or documenting yourself into a corner.
W
warrior
I agree with the last post. I think the best method is the KISS method!
(KISS = Keep It Simple, Stupid)
[no flames please...]
:agree1:
N
noboost4you
Yes, we do have an electronic list that contains Drawing Number, Part Number, Description, Rev, Date, and Product. However, I don't believe we have anywhere that printed copies are for reference only except on the cabinet itself.
Ok, so catalogs don't need to be touched. But User Manuals for machines need to be controlled/documented. What else would be considered an External document?
SteelMaiden
No, I did not mean that you need to document which operator's manuals you have and control them, sorry, my bad. I just meant that they are usually (and I know that there will be some proponents on the other side) just kept wherever they are most handily stored. It is up to you to decide if they are so important to you that you need to documdnt their existence/control.
These kinds of documents are not going to be updated by the supplier, so why bother with controlling them? If you ever lose one, you could probably get another from the supplier. The only thing that I personally would "control" from the documents that you refer to, would be the original, (it sounds like) computer drawing file. i.e. printed drawings are considered to be uncontrolled documents and their validity can be ascertained by verifying the rev level with the "Engineering Drawing List" which is a living document showing all rev levels.
N
noboost4you
Would those hardcopies then be a part of the Master List of Obsolete Documents if they are for only reference use?
And yes, the most current Revision level of any drawing is on the computer. However, like I mentioned above, no printed copy of any drawing states "Printed copies are uncontrolled," "For Reference Only," or "Obsolete." What if someone were to pull a drawing out of the cabinet (which anyone who is in the building can have access too) and misplaces it/doesn't return it. Who's to say what that printed copy is if there is no stamp/watermark on it?
CarolX
I would also suggest you scroll down to the bottom of this page for links to similar threads. Read through some of those, might give you a different perspective.
N
noboost4you
As I've been waiting for responses to this thread I have been reading the Similar Threads at the bottom :)
N
noboost4you
I'm going off on a tangent, please bear with me
I guess the concept that I'm having trouble figuring out is to what extent are documents "controlled"? Will having a Master List containing the File Name, Rev, and Date be sufficient? Or do I need to know where it is, who has it, etc. at all times? Define "controlled"
In one of the Similar Threads below, this is posted:
"Product defect samples are displayed in a lighted glass cabinet in the visual inspection area. The samples illustrate the limits of various defects that can be considered acceptable to customers, and they're used when inspectors aren't certain of the criteria. Currently, the display cabinet is labeled "for reference only." Despite this declaration, the samples should be controlled because they define customer requirements" How?
I apologize for my random thoughts.
Craig H.
Because they are what the product is compared to when maiking the decision concerning whether or not to send the product to the customer.
V Reference Number required in Internal Audit Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Internal Thread Inspection reference - Actual data vs. Thread Gage Various Other Specifications, Standards, and related Requirements 1
CarolX Cross Reference Matrix - ISO 9001 Requirements to Internal Procedures (Tier I and II) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
B When to use "For Reference Use Only" on documentation Document Control Systems, Procedures, Forms and Templates 4
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Use of Certified Reference Materials for Quality Assurance General Measurement Device and Calibration Topics 6
A Reference Source for Polarity Symbol Other ISO and International Standards and European Regulations 1
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
E Reference Only on Gage or Visual Aid Calibration Frequency (Interval) 4
F Quality Objective Reference Chart Customer Complaints 4
V Good Documentation Practices - FDA Reference US Food and Drug Administration (FDA) 9
M Good reference sites or material to help me brush up quickly on Gage R&R Reliability Analysis - Predictions, Testing and Standards 7
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W Do "Reference Only" documents have to be physically marked/labeled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S ISO 9001 Clauses which reference the 8 Principles of Quality Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Where could I get reference to an OQA Sampling Plan of 1 per 1000 ? Quality Manager and Management Related Issues 4
