For Reference Only or Calibration/Verification - Tape Measures for cutting bar stock
#11
Re: For Reference Only or Calibration/Verification
I agree totally. That's my point, people use the "for reference only" as a crutch not to calibrate.
In this specific case (original post), the organization may want to do a mini-FMEA, a risk analysis and then make a decision based upon that result. As an auditor, where The Standard states "where necessary" or "where applicable", if an organization states "not necessary", if they showed me their risk analysis that they signed off on, then I'd have to accept it because if they state that, my follow-up question is "what was the thought process behind that determination?"
Yes. That's why I said that the rationale for excluding devices or applications should be documented.
samsung
#12
This is the only post where I don't see a 'Thanks' button. Peculiar characteristic. Forum moderator may fix it.
Now I see it. No problem.
#13
Re: For Reference Only or Calibration/Verification - Tape Measures for cutting bar st
Why does it have to be expensive at all? Buy a $10 tape measure, verify it once (against a calibrated 36" master steel rule) before use to make sure it is correct. Then, periodically determine the condition is still good. I agree this is not NASA and does not have to be complicated. But, it can be done so easily... And the same principles can be applied to many other gages...THAT is the value that an auditor can "bring to the audit process..."
AND if the auditor checks with the operators and they know they are to check their tapes agains the master rule every day/week month;
AND if there are no rejections that can be traced to a defective tape measure then it would appear you have proven the following:
1) You have a system in place to control the tape measures
2) Employees using tape measures are trained and know how and where to check their tape measures (and what to do if one is found bad)
3) The system is adequate since there have been no rejects as a result of a bad tape measure
Peace
James
John Martinez
#14
I saw that. I was trying to give an example of a specific type of documentation, as well as insight from a third party auditor perspective.
All that said, I think we agree. :agree:
DrM2u
#15
Setting asside the suggested (and not so cheap) calibrated or 'master' 36" rule, you are not saying anything different from what I did. To my point, the rule is not cheap to buy or to re-certify. For that matter, you can buy enough measuring tapes for the money to last you a while. The first-time 'verification' can take the form of a certificate from the OEM, unless you do not trust that the likes of Starrett can make a reliable product. Besides that, why not entrust the user to evaluate the condition of the tape daily or before use? It shows empowerment of and trust in the work force.
As far as the value brought by the auditor, a good auditor presents more than one example in order to avoid being construded as consulting. These examples are gathered based on percieved 'best practices' observed during audits. It is up to the client to evaluate if there is any value in implementing any of the examples or a deviation of.
DrM2u
#16
... or just to check the condition of the tape, depending how the system is defined. All the other following AND and THEN can remain unchanged. After all, there is more than one way to skin the cat.
dtr18c
#17
Thanks to everyone for your helpful responses!
To clear things up about what will be affected if the length is bad:
  • If the length is too long then the automatic bar feeder won't be able to load it (travel issue)
  • If the length is too short then we get less pieces.
JaneB
#18
This quite clearly indicates the need to have accurate measurements.
It isn't solely about the effect on 'final product characteristics'. Think more broadly (and use common sense):
If your automatic bar feeder can't load stuff, then presumably that slows down work? Which costs, yeah?
And if you get fewer pieces if the lengths are too short, then that's wasting material. All of these things are important in managing quality too.
But as Helmut says, a 'calibration' system can be cheapo and practical, doesn't have be expensive.
dtr18c
#19
From previous posts in this thread I got the impression that we could justify not having calibration with a risk analysis. Your response better explained explained what i was getting hung up with. :applause:
determine acceptance of the product" for movement to the next function area
So now I'm a little confused, I see risk analysis as a reasonable method to justify not calibrating since the likelyhood that a tape measure would be able to hold our 0.5" tolerance with end play and any sort or warping.
But, I also am thinking about:
It isn't solely about the effect on 'final product characteristics.
Can anyone shed some light on this situation?
Thanks!
#20
But if it's been rationally determined that the probability of gage error is acceptably low, calibration would be wasteful. That's why the standard calls for calibration "when necessary to ensure valid results." If calibration/verification isn't necessary to ensure valid results, it shouldn't be done.
It's not practical, regardless of what it costs, if it's not necessary.
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
N Client Request for Reference Equipment Calibration Certificate General Measurement Device and Calibration Topics 3
A Calibration Service Suppliers refuse NIST reference numbers on C of C General Measurement Device and Calibration Topics 21
N Uncertainty of Calibration Master Reference Measurement Uncertainty (MU) 1
F Calibration Reference Standard for Mass Weight Calibration General Measurement Device and Calibration Topics 2
S Using Prepared In-House Reference Materials (RM) for Equipment Calibration & Verifica General Measurement Device and Calibration Topics 3
howste Determining Calibration Uncertainty with Unknown Reference Standard Uncertainty Measurement Uncertainty (MU) 8
E Calibration Frequency of Reference Magnets for Gauss Meter Calibration General Measurement Device and Calibration Topics 5
F Moisture Analyzer Calibration Reference Standard General Measurement Device and Calibration Topics 7
T Reference Spectrum Generator for In-House Calibration General Measurement Device and Calibration Topics 2
S Reference to original Calibration Certificate - ISO 17025 Section 5.10.9 ISO 17025 related Discussions 4
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
S ISO 17025 Validation Requirements - "calibration using reference standards or..." ISO 17025 related Discussions 5
N Digital Temperature Indicator Calibration (Thermocouple) - Using a reference junction General Measurement Device and Calibration Topics 1
M Reference Thermocouple Probe (TRP) Calibration General Measurement Device and Calibration Topics 5
R Use of Reference standard in Calibration of measuring Tools General Measurement Device and Calibration Topics 1
R Reference Standard for the Calibration of Dimensional Measuring Tools General Measurement Device and Calibration Topics 2
H Hygrometer Calibration - Best way to verify accuracy of a 'reference' Hygrometer? General Measurement Device and Calibration Topics 11
B Product Testing/Calibration with reference to TS16949 requirements General Measurement Device and Calibration Topics 0
B Looking for Calibration / Reference Standards tracable to NIST General Measurement Device and Calibration Topics 15
A Reference for Calibration Procedure of Electronic Balance General Measurement Device and Calibration Topics 1
J Source for calibration stickers - Narrow "For Reference Use Only" wrap-a-round General Measurement Device and Calibration Topics 4
Q Calibration of spectrometer - Master sample as reference General Measurement Device and Calibration Topics 19
R Calibration of Tape Measures used for reference General Measurement Device and Calibration Topics 13
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q How to efficiently and compliantly reference external standards/regulations Other Medical Device Related Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
