For screening a design, can we live with the low/poor predicted R-Sq.?
v9991
during analysis of the results, Design Expert provides three Regression coefficient for a model,
R-Squared
Adj R-Squared
Pred R-Squared
A. the query is, can we ignore/live-with poor or low Pred R-Sq.
1) during screening designs(Res-II or Placket Burman Design),
2) there is an analysis of DOE through option for historical data ,
in both cases, we are essentially looking for not a model, but JUST co-efficient and their magnitude (apart from the main effects)
B. for exploratory work, can we do work with p-value on marginally higher side (approx 0.06-0.1 vs 0.05 )
A screening design is just that, a means of filtering a few significant factors from the many non-significant factors. It is not used for building a mathematical model. At such low resolution, it would miss all interactions anyway.
Since it is used for filtering only, I often recommend using an alpha of 0.1. The assumption is that once you have narrowed the field to the few factors of interest, you will follow up with a series of modeling or optimization experiments at a lower alpha that would confirm or dispel these borderline factors.
v9991
Since it is used for filtering only, I often recommend using an alpha of 0.1. The assumption is that once you have narrowed the filed to the few factors of interest, you will follow up with a series of modeling or optimization experiments at a lower alpha that would confirm or dispel these borderline factors.
yes, that is the intent,
in the resulting model, we are trying to draw some inference from the co-efficients of the factors.
+ can you also pl comment on the predicted R-Sq.!
I would not use the results of a screening design for anything more than determining the significance of a factor and directionality (i.e., +/-). To interpret coefficients, you must have a mathematical model. To have a mathematical model, you must include any significant interactions (which you cannot test with a low resolution screening design). Omitting these interactions will change the coefficients of the factors.
BTW. Please be precise on your meaning behind coefficients. The most common meaning is Bx where Y = B0 + B1X1 + B2X2... Bx is a coefficient. R^2 is also less commonly called the coefficient of determination. I have been responding based on the assumption that you meant Bx when you asked about coefficients, but am no longer certain.
Regarding R^2:
  • R^2 explains the percentage of variation explained by the mathematical model, but has one serious drawback. If you continue to add terms to the model, even if they are non-significant, R^2 will continue to increase.
  • R^2 adjusted compensates for the flaws of R^2 by penalizing you for every term in the model. If the term adds value to the model, R^2 adjusted will increase, but if the term adds no value, R^2 adjusted will decrease. The ideal model will have similar R^2 and R^2 adjusted values.
  • R^2 predicted goes even further by sequentially removing one observation from the data set, calculating the regression coefficients and predicting the missing datum. If you have over fit the model, R^2 predicted will drop. If you try to fit a linear model to a nonlinear data set, or are missing interaction, R^2 predicted will also drop.
J Selecting factors for screening DoE design Statistical Analysis Tools, Techniques and SPC 8
W Definitive screening design in Minitab 17 Manufacturing and Related Processes 1
F Resolution III Factorial Design for a Screening Experiment Six Sigma 2
T Screening DOE (Design of Experiments) with qualitative response Quality Tools, Improvement and Analysis 23
B Classification of screening system EU Medical Device Regulations 14
T PMCF Planning : Only Literature screening qualify? EU Medical Device Regulations 5
Judy Abbott ISO 10993-18: 2020 extractables screening Other ISO and International Standards and European Regulations 2
V Screening DOE with 7 Input factors and 4 responses - Significant factors Using Minitab Software 1
S Rapid screening methods for antibiotic residues in Chicken Meat Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M ITAR Requirements and Visitor Screening AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
P Screening DOE: A coming up headache story Quality Tools, Improvement and Analysis 4
S Screening and Screening Rational Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Environmental Stress Screening (ESS) - Difference between MIL-HDBK-344 & 2164A Reliability Analysis - Predictions, Testing and Standards 4
I Screening: Blackett Burman versus Fraction Factorial Quality Tools, Improvement and Analysis 2
Stijloor U.S. Intensifies Screening for Travelers From 14 Nations Travel - Hotels, Motels, Planes and Trains 1
E Environmental Screening of PCBAs in High Volume Electronics Contract Manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Safety audit violations - bloodborne pathogens, LOTO & drug screening Occupational Health & Safety Management Standards 12
A 510(k) Screening Checklist that the RA has filled out - Is that sheet for FDA use? ISO 13485:2016 - Medical Device Quality Management Systems 2
G Health Insurance - Annual health screening Career and Occupation Discussions 10
A Augmenting full factorial design to CCF Using Minitab Software 8
T Design and Development training AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Nawal Design Review Requirments Manufacturing and Related Processes 6
R ANOVA MSA GR&R in ATE replacing operators (Error Design is not balanced) Using Minitab Software 7
G What is Design&Development and what is product in a Research company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
adztesla Design change and Process change Class 3 medical device Medical Device and FDA Regulations and Standards News 2
R ISO 13485:2016 DESIGN TRANSFER Forum News and General Information 0
adztesla Adding new supplier/ Medical device design change ISO 13485:2016 - Medical Device Quality Management Systems 2
T Clinical Study Design for IVD Self-Test (lay user) Products UK Medical Device Regulations 0
T Design of Experiment - Test for Curvature Quality Tools, Improvement and Analysis 4
I Design Verification Testing on Non-Validated Equipment ISO 13485:2016 - Medical Device Quality Management Systems 2
Z Design verification test sample size under the scope of first in human study submission in Europe Medical Device and FDA Regulations and Standards News 3
T Mandatory requirements for design verification sample 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
T Class B IEC 62304 - 5.4 Software Detailed Design IEC 62304 - Medical Device Software Life Cycle Processes 4
L Design Transfer Concept of cloud SaMD US Medical Device Regulations 2
M IVD Device Design Change Medical Device and FDA Regulations and Standards News 2
S Design and Development document ISO 13485:2016 - Medical Device Quality Management Systems 2
M Risk-based approach to Test Method Validation for Design Verification? US Medical Device Regulations 5
S Is design and development clause 8.3 applicable for laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Design: Verification Vs Validation And Validation Vs Transfer ISO 13485:2016 - Medical Device Quality Management Systems 19
L To control the essential design outputs Medical Device and FDA Regulations and Standards News 4
C MD Design and development procedure ISO 13485:2016 - Medical Device Quality Management Systems 1
B Validation of design for valve api 6d 25 edition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
B Hi , everyone i need a procedure for validation of design prototype api 6d (valve manufacturing) Oil and Gas Industry Standards and Regulations 1
K Exclusion of 8.3 Design and Development for Design Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Recognised/reputable courses for ISO 13485 Section 7.3 (Design & Development)? ISO 13485:2016 - Medical Device Quality Management Systems 1
J Design/Development. Oil and Gas Industry Standards and Regulations 6
O Regarding design and development requirements for a medical device EU Medical Device Regulations 6
W Rights of Supplier in Design & Build WP Manufacturing and Related Processes 0
K ISO 13485 Design Requirement with respect to "component" manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 11
rob3027 ISO 13485 justification for design and development exclusion for medical packaging ISO 13485:2016 - Medical Device Quality Management Systems 18
