Form for Managing Coating Process Parameter Changes during Production
QAengineer13
Dear all,
Any advise on how to go about managing any process parameter change during the coating production process ( because of raw material issue, Environmental) with proper approval from Engineering / process Engineering team.
Although the process was validated and the machine extreme was tested and the tolerance was defined , due to some random raw material issue ( offcourse NCR can be created on the suppler) but in a situation you need to continue production and the process engineer is confident that by changing the machine parameter , the product performance is not compromised.
In this situation , what FORM can I out in place and how to control it?
Thanks.:thanx:
W
Wilderness Woody
If you are changing a parameter of the processing equipment not previously identified in the validation or are changing the settings outside of established (validated) range, then you probably need to re-validate to ensure (prove) that performance is not compromised.
You should be able to validate a process to cover certain variables such as condition or properties of inputs (raw material). Many processes are capable of manual or automatic adjustment during setup and run to ensure output meets specifications.
Without more detail about the coating and specific parameters and your validation scope, I can't offer much more insight.
John Broomfield
Dear all,
Thanks.:thanx:
QAengineer,
Your form for controlling nonconforming product should be used when it is possible that the product is nonconforming.
This time it is because someone chose to use raw materials that changed the validated process.
The change in raw materials should have invoked re-validation of the process.
You may want to clarify the scope of your NCR form.
John
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
L Form-dependent position prevention control FMEA and Control Plans 1
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 1
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 14
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
Ajit Basrur Informational Merger of PAC and APLAC to form the Asia Pacific Accreditation Cooperation (APAC) General Measurement Device and Calibration Topics 0
JoshuaFroud FDA Form MDSAP AU F0029.1.004 - Help with Completion US Food and Drug Administration (FDA) 0
L AS9102 Form 1 Section 13 Detail or Assembly Question AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
supadrai Informational Japan Minor Change Notification Application Form - Found it? Japan Medical Device Regulations 0
S Adding Value prior to signing EASA Form 1 EASA and JAA Aviation Standards and Requirements 5
M Revision of a Form which is a Procedure Attachment Document Control Systems, Procedures, Forms and Templates 1
S FAA Form 8130-3 Signed in 2 places Federal Aviation Administration (FAA) Standards and Requirements 1
D FAI. Form 2, process or functional test? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
H Conveying Form Fit and Function Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I Certification CISS by AAMI - I want to form a study group Professional Certifications and Degrees 5
J Simple supplier evaluation qualification process form that includes Risk Assessment Document Control Systems, Procedures, Forms and Templates 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
G Auto electronic signature on Calibration Form ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
