Form Identification Numbers - I do not really understand the benefit of a form number
Bpoole
I have recently changed companies and my new company has a 6 digit form number on "most" of their forms in addition to a date. I do not understand the reason behind the form number. I have ask several here why and was told and it must be becasue ISO requires it. I know we have to control our forms, etc, but I do not really understand the benfit of a form number. I have always used the title and revision date. This is a very small company.
comments please
Thank You,
Barbara
:thanx:
comments please
Thank You,
Barbara
:thanx:
There is no ISO requirement for numbering, only control (of certain types of documents) as you suggest. There are all sorts of numbering and control schemes, and my advice is to do whatever is the simplest that serves the purpose. If your documents are not numbered but you can still control them adequately, then numbers aren't necessary.
Marc
I know companies which identify forms by the form title and they identify procedures the same way - By title. No benefit to numbers in a small company.
Totally agree.....
that there's little necessity for numbering (forms are generally unique in their design and are, therefore, easily identifiable).
It's good to see a 'ray of common sense sunshine' about this kind of thing:lol:
Andy
K
Kevin H
I've got to agree that there is no ISO 9001 requirement for form numbers, you just need to control them. I initially started with just form name and revision date for document control. I found that adding a form number for the company wide forms controlled by QA made it easier for me to track and control them. You might have inherited a system that developed similarly. No ISO 9001 requirement to keep it that way, but you might want to check and see if there is an underlying reason for the form numbers.
RoxaneB
So the consensus is that there is no need to number the documents, but is there a benefit to changing that aspect of their process? Especially having just started there? Change is difficult but I'll admit I'd raise an eyebrow at a new person coming in and seeing one of her first actions to remove all the numbers from the forms. How's the rest of their document control process?
Numbers do no harm either (unless they're too complicated), so there might not be much point in removing them if they're not hurting anything.
Wes Bucey
Let me suggest:
Having seen literally dozens of situations like this, I have a hunch I understand what happened:
  1. At some point in the dim past, the company bought (or copied) a package of forms from a consultant for ISO
  2. The consultant had a "one size fits all" method
  3. Result is company has document system for much larger operation (GE, GM, etc.)
  4. Consultant liked the "mystique" (and the money) from keeping details and simplicity of ISO from company folk.
Current situation:
  1. newbie comes in and sees "emperor without clothes" in overkill on documentation
  2. newbie can bide time to introduce changes gradually BECAUSE there is no urgency - the content of the document is most important, not the numbering or titling system.
I have a hunch many of the documents themselves are overkill and probably can be "retired" without negative effect - just not until newbie gets self established as "good guy.".
ralphsulser
I implemented and use numbers along with revision numbers and dates on all the check sheets I initiated.
Why you might ask- this was a brand new American/Japanese company starting up and many changes were in the wind to not only correct but improve. I try to correlate the revision numbers with the detailed Specification instructions posted at every operation in each process. It has helped many times when we find someone is not using the latest revision, or they come and say "hey, these don't match", and I say why are you still using the old revision. I know they have it because I personally take them a master and 5 copies each time there is a revision. I also look for old copies and dispose of them. But sometimes someone has an old copy squirreled away in a drawer. But we do audit for these conditions.
So numbers and dates work for us. I agree they are not required but sometimes it makes our life easier with all the new people we have hired in the last 2 years.
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Requirement for Form Numbering (Document Identification) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
L Form-dependent position prevention control FMEA and Control Plans 1
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 15
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
Ajit Basrur Informational Merger of PAC and APLAC to form the Asia Pacific Accreditation Cooperation (APAC) General Measurement Device and Calibration Topics 0
