Definition Form vs. Record - What is the Difference between a Form and a Record
Patricia Ravanello
#21
Re: What is the Difference between a Form and a Record
After confusing intended output of a process with byproducts, the concept of revision controlled records is not that far fetched...:mg:.
:confused:OK, I'm confused, :confused:
Your message is a bit cryptic...Are you suggesting that Records aren't "revised"...or that the Revision of records is just a concept???
Patricia
Stijloor
#22
Patricia
Allow me to chime in here. It depends on the definition of document and record. What some folks call "records", are actually documents (instructive) and subject to review and possible revision. I view records as evidence of completion, are filed and not revised anymore.
Stijloor.
remsqa
#23
hai
it is very clear,Form can be controlled with rev no and can be changed.
But the record is a filled form ,which can't be corrected or revised, if so it is offence.
Regards
R.L.Satthish Kumar
:bonk::agree1:
Patricia Ravanello
#24
Stijloor.
Your right...it's a matter of definition. I've never seen the term "instructive" as a distinguishing or required attribute/characteristic of a document...(but that's germane to this discussion...).
Call them what you will, but assuming the following, fairly typical System Documentation Hierarchy, where do the "Controlled Records" which I identified above, fit??
Level 1 - System Manual
Level 2 - Procedures
Level 3 - Work Instructions
Level 4 - Forms
Level 5 - Records (controlled & uncontrolled) and References (controlled and uncontrolled)​
...or explain/show where they fit in your system documentation hierarchy.
Patricia Ravanello
Stijloor
#25
Level 4 - Forms
Patricia Ravanello
Patricia,
Using your 5-level hierarchy, my "definition" of records (for what it's worth) would fit in level 5. I do not get hung up on "levels of documents." I look at them in the context of the system and its processes they support and the need for objective evidence to be provided. My clients can call them John, Dick and Harry if they wish. Ultimately, it's the effectiveness and continual improvement that counts.
Stijloor.
michellemmm
Quest For Quality
#26
Stijloor.
I agree:yes:
I am concerned about the perception that increase in the number of level/tiers of documents assures improvement and control. ISO does not specify if a company should have three, four, or ten tier of documents. Organizations have to determine the shortest distance between point A to point B.
Patricia Ravanello
#27
Patricia,
Stijloor.
Hi Stijloor,
I'm not caught up in the level of documents...I just want to clarify what records are...and I can see by your response, that we are in agreement regarding the "Controlled Records" which I listed earlier.
I think it wise to concur on terminology. Isn't that the whole point of "Standardization", thereby enhancing effectiveness and efficiency?? Everyone should be speaking the same language when it comes to terminology. It's not that complex, but this discussion is likely to confuse more than to enlighten.
Back to Randy's point, which was, that Records can change...and per the "Controlled Records" identifed above (and which you have agreed, are in fact records), I submit to you, once again, that "Records can change".
Regards,
Patricia
PS. I would discourage my customers from referring to "records" as Tom or Harry Dick (and I'd be reluctant to ask to see them!!) :notangel:
#28
Randy is correct.
There are two types of records:
1) Controlled Records (those subject to review and revision, and usually have a Revision Level on them)
Examples:
Purchase Orders
Organizational Chart
Business Plan
Communication Plan
Training Plan
Business Operating System Model
Engineering Drawings
Engineering Standards
Material Specifications
Bill of Materials
Policy Statement
Sorry Randy...I'm not trying to answer for you...just supporting your perspective.
Patricia​
This is a new one to me, so I'm going to need some help. I don't see what or how these record anything. Can you explain for me Patricia, you basis for this thought?
you see, I've always gone along with the practice that a record was related to some (planned) event, hopefully some data that would give evidence of that event showed conformity with a requirement (like an inspection record of variables data to show a product chracteristic meets the design drawing, for example) Just as others have posted here. Now I'm really befuddled.
A business plan, org.chart etc have, in my world at least, always fallen under the heading of a document, and never a record..........​
Patricia Ravanello
#29
Hi Andy,
I hope the attached page sheds some light on my thinking. If it doesn't answer your questions, hit me with them again...
The reason why agreement on this is important is because employees have to know clearly what's what when they implement their SOP on the Control of Documents and Records. They need to know "what is" and "how to" manage both a Controlled and Uncontrolled Document, regardless of whether it's an SOP, WI, Form, Record, Standard, Specification, or Report, and regardless of what you call it...document or record.
It doesn't matter how many documentation levels you have.​
Your SOP should distinguish the difference and the appropriate management process of the various documents, both controlled and uncontrolled (ownership, storage, retention period, review, approval, etc.)
Patricia Ravanello
Patricia Ravanello
#30
I agree:yes:
Hi Michellemmm,
The number of documentation tiers/levels is not in contention. I concur that that decision is left to the discretion of the organization.
Please see attachment in my last post for further clarification.
My point was, and is, as Randy said, "Records can Change".
Patricia Ravanello
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Form and Form/Record Numbering in an Excel Spreadsheet Excel .xls Spreadsheet Templates and Tools 2
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
x-files A form becomes a record when data is entered ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Electronic Training Record Form (Template) Document Control Systems, Procedures, Forms and Templates 6
K Form 42-2 for Document Initiation and Change Record - Template wanted Document Control Systems, Procedures, Forms and Templates 3
D Vendor (Supplier) Audit Form as a Controlled Form and as a Record Supplier Quality Assurance and other Supplier Issues 15
R Retention of records - Original Order Form vs. Computer Entry record - ISO 13485 Records and Data - Quality, Legal and Other Evidence 12
M Blank Form vs. Completed Form - A document or record? Records and Data - Quality, Legal and Other Evidence 11
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
L Form-dependent position prevention control FMEA and Control Plans 1
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
