Form vs. Tool? Is Control Necessary?
AmandaMusser
I hope that somebody can help me out with a Form vs. Tool debate.
I had an Engineer put in a request for a new document that he is calling a form. This document, "PDCA Problem Solving Form" reflects the Plan, Do, Check Act process, along with the 4M's Fishbone Diagram, and will be used as a problem solving tool. Once all information is filled in and the solution is implemented, the form will be discarded.
Years ago an ISO auditor told me that if you put the word "Tool" in the title of your document, the document did not need to be controlled. I do not know if this is true or not.
My question is this, "Since the document is not retained at all, does it need to be titled "form", and does it need to be controlled?" :frust:
Thanks in advance!
Re: Form vs. Tool?
Thanks in advance!
First, there is nothing to the idea that documents that include the word "tool" in the title do not need to be controlled. If that were true, you could just call all of your documents "Tool" and not have to control any of them. The need for control is determined by content and utility.
Retention, or lack thereof, is also sometimes irrelevant with respect to control. You might want to control the form itself in order to control what information it contains when it's filled out, even if it is discarded later. You should decide for yourself whether or not control is necessary.
Stijloor
Re: Form vs. Tool?
Thanks in advance!
Hello Amanda,
It all depends.... If this document is considered a part of your corrective action process, you must retain this document as a record. Whether you call it tool, form, or whatever is not important. When you use this document as an information collection device and later entered in the computer system, you can discard it. Now the electronic version becomes your record.
I am sure other Covers will respond.
Hope this helps.
Stijloor.
Randy
Re: Form vs. Tool?
You can call it a dogbone, frisbee, eggplant or anything you want...it doesn't matter.
What does matter is what the item is used for. If it is relevant to the system and the need to meet requirements and achieve customer satisfaction, and it is essential to planning, and it is documented, it has to be controlled.
AmandaMusser
Re: Form vs. Tool?
Thank you all for your quick responses! It looks as though the team will be using the information collected to implement "permanent countermeasures" on the production line. I will have to get with the Engineer again to determine if this would be used as a direct result of a corrective action. Either way I believe it should be controlled.
Helmut Jilling
Auditor / Consultant
Re: Form vs. Tool?
...Either way I believe it should be controlled.
yes. please review 4.2.3, first sentence:
4.2.3 Control of documents
Documents required by the quality management system shall be controlled....
The solution is not to leave them out of doc control. The secret is to make doc control very simple and easy.
M Greenaway
Yeah this sounds like a record of corrective and/or preventive action so document control is required in terms of retention of this record, but only keep it if it is useful !
As to the blank form, if it just shows the PDCA cycle and a bare Fishbone diagram then I dont know what 'control' you might need other than something that assures that this form we want to use gets used for this purpose.
W
Willem
I would say to avoid unecssary questions from auditors or from customers that audit you rather make it a controlled form as it can become part of corrective/preventive action. A question that comes up on a regular basis in audits is wht proof do you have that preventive action is done.
M Greenaway
I can audit whether or not a preventive action was done by go viewing the claimed action in the real word, rather than being satisfied that it is written on a form.
E CQI-7T Form - AIAG Process Identification Tool 95-2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
K Tool Qualification/Verification Form ISO 13485:2016 - Medical Device Quality Management Systems 5
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
S Transitional Adolescent A and B - "CDRH PREMARKET REVIEW SUBMISSION COVER SHEET FORM FDA 3514" Medical Device and FDA Regulations and Standards News 1
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
K Generic preventive maintenance form wanted Document Control Systems, Procedures, Forms and Templates 2
M Is it Necessary to Use Health Canada Form when Reporting? Canada Medical Device Regulations 1
S Supplier Management ISO 13485: 2016- Which supplier needs to fill in a self assessment form? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Form templates for software (iso9001) Document Control Systems, Procedures, Forms and Templates 0
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
D Question regarding ECO process, specifically for Life Science products and defining form fit and function ISO 13485:2016 - Medical Device Quality Management Systems 1
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
gunnyshore Form FDA 3500A MedWatch eSubmitter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A AS9102B - 3.6 Design Characteristics and form 3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C AS9145 Appendix D PPAP Approval Form APQP and PPAP 2
L Form-dependent position prevention control FMEA and Control Plans 1
Y Blank Fields on CAPA Form Document Control Systems, Procedures, Forms and Templates 21
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Informational EU – MDCG 2019-12 Designating authority’s final assessment form: Key Information Medical Device and FDA Regulations and Standards News 0
Ed Panek Relevant questions on Substantial Change Form CE Marking (Conformité Européene) / CB Scheme 3
B Documenting hardware on Form 2 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
Sidney Vianna Interesting Discussion Interesting article form the UNIDO Magazine - CSR: a wolf in sheep’s clothing? Sustainability, Green Initiatives and Ecology 16
R Process Specification - What is the name of this PPAP form? APQP and PPAP 15
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G I-chart form for GM GP-12 Customer and Company Specific Requirements 2
M Informational US FDA – Ethicon Recalls Circular Staplers for Insufficient Firing and Failure to Completely Form Staples Medical Device and FDA Regulations and Standards News 0
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
S C of C release with accompanying EASA Form 1 for EASA Part 145 EASA and JAA Aviation Standards and Requirements 0
S Where did FDA 510(K) form 3654 go? Other US Medical Device Regulations 4
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
Ron Rompen Source needed for Spline Form gauge (GO and NOGO members) General Measurement Device and Calibration Topics 3
T NAFTA request for form with no part numbers showing Supply Chain Security Management Systems 0
C Do we need to make a new OFI (Opportunity for Improvement) for each document/form we update? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
R SaMD - Software as a Medical Device - Software change control form ISO 13485:2016 - Medical Device Quality Management Systems 3
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
J Medical Device Vigilance decision tree FORM - Please share yours EU Medical Device Regulations 15
O Localized clean room dust extraction system coupled in HVAC - Manufacturing solid dosage form Manufacturing and Related Processes 9
Ajit Basrur Informational Merger of PAC and APLAC to form the Asia Pacific Accreditation Cooperation (APAC) General Measurement Device and Calibration Topics 0
