Forms that need to be used in the audit process for ISO TS 16949
jrubio
#11
The "Checklist to ISO/TS 16949:2002" is obsolete
This is the statement I have seen in IAOB site:
---O---
SI 2 04 Use of the Checklist to ISO/TS 16949:2002 (Revised, adopted May 2004)
The "Checklist to ISO/TS 16949:2002" is obsolete as an IATF document, effective 1 June 2004. It is no longer available.
According to this statement can I use the checklist internally?
jrubio
#12
---O---
Obviously the porpuse of using this checklist is to obtain an appoach of Auditing internally ISO TS systems.
I can imagine that an Auditor with more expirience that me, do not need it.
jrubio
#13
Forms exists and are used by CBs
Howard,
You are right, I was asking for the forms used by CBs which cover all the steps of a process audit.
I used the checklist in the suitable step, just for proofing that I made the audit in cnformance with TS 16949, as stated before the AIAG now do not recommend this checklist but couriously they isssued a check list book (In my oppinion a fantastic book) in 2002 now obsolet.
Howard Atkins
Forum Administrator
#14
The check-list is not in use as it caused auditors to be fixed on the clause approach.
The check-list is another way of writing the standard and as such for internal uses it helps to make sure that you have covered all aspects.
There is no problem in using the checklist internally
The strange thing is that the standard requires a check-list for internal audits but does not for external.
#15
Howard..........
you are correct. My focus has been helping Javier from an internal audit prespective, since his other posts indicated (to me) that focus.
Javier, did I miss understand? Are you putting an internal audit system toether? If so, my comments still stand. The 'QSA' checklists should be avoided if that's all you are going to use. This kind of checklist may be a simple tool, but they don't help to get an effective audit done, if used alone.
Andy
Helmut Jilling
Auditor / Consultant
#16
The checklist is marginally adequate for a "gap-analysis" but not for internal auditing. IATF/IAOB have cancelled the document. It is now obsolete.
The note referencing "checklists" should not be taken too literally. Since that was written, there has been a pretty adamant shift toward a process approach at all Accrediting Bodies.
But, I still have a lot of clients using checklists and flowcharts (and even turtles). I actually believe they help partime internal auditors follow a process approach if they are well designed. But the checklists cannot be a limiter which holds people to a clause based approach.
Helmut Jilling
#17
---O---
I suppose you can use the checklist as a gap analysis, but not for the internal audit cycle. Those must be performed follow your processes. If it helps, you may develop a checklist to remind you of the appropriate links and things to look for in a process audit.
Helmut Jilling
#18
Howard Atkins said:
As far as I see Andy you are the only one talking about internal audits.
If the audit is external there is a form for organising the processes whicjh I have seen. The checklist is no longer used.
Each CB has its own forms
Most CBs now use a simple checklist template. More of a form than a checklist. We are required to audit your processes as you define them. I usually request the client's flowcharts or turtles, and follow them.
Helmut Jilling
#19
ralphsulser said:
There were several posted here on the "Cove". Try a seach and you should be able to see several TS16949 audit sheck sheet examples
Be careful, most of them are no longer applicable.
The best is for a company to take their processes, process maps, procedures, and metrics, and wring them out. Look for whatever is not functioning as it should. Those items may be valid findings.
jrubio
#20
Andy.
You correctly forsee that I currently conduct an internal Audit but I was trying to imitate a formal external audit one even with the formats like:
Planning Audit form
Result of audit form that I saw a one CB used
In my modest oppinion I think that the checklist is a good start for beginners, I am now passing a checklist and I am panic I discovered many non conformances that Auditors did not raise.
I think the use of checklist is a way to have a standarded proof of Auditing, of course that an expirienced Auditor do ot need it.
Thanks to all for your fantactic support and quick response.
H Do we need all three AS9102 forms if we manufacture only Piece Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
V Control of Forms - Do the blank forms need to be Password Protected? Document Control Systems, Procedures, Forms and Templates 19
T Control of Forms - Do forms need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 64
M APQP application examples - I need APQP forms and guide how to fill the forms APQP and PPAP 3
W Controlled vs. For Reference Only - Forms which don't need control? Document Control Systems, Procedures, Forms and Templates 6
G Need level 3 PPAP Forms APQP and PPAP 6
I Need to reference forms and ensuing records? Records and Data - Quality, Legal and Other Evidence 6
Gman2 Training Forms - Do training forms need to be numbered? Document Control Systems, Procedures, Forms and Templates 10
F Controlled Forms - To what extent do forms need to be controlled? Document Control Systems, Procedures, Forms and Templates 41
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Rules for Paper Forms outside of an eQMS - 3 Questions (ISO 13485) Document Control Systems, Procedures, Forms and Templates 9
M Forms review Manufacturing and Related Processes 5
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Serialization and Reconciliation of Forms Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 7
I When do FORMs and Log Files become Records? Document Control Systems, Procedures, Forms and Templates 9
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Forms Master List versus Record Matrix ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M What to do about Non Conformance forms that are deleted or missing? Nonconformance and Corrective Action 4
R Purchase order forms - who keeps them? ISO 13485:2016 - Medical Device Quality Management Systems 3
GreatNate Various Audit Templates - Canned forms and templates Document Control Systems, Procedures, Forms and Templates 9
W Informational MDSAP Substantial change / Change of notice forms Document Control Systems, Procedures, Forms and Templates 2
D Internal audit forms or checklists for a medical/veterinary laboratory General Auditing Discussions 5
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
S Supplier Audit Assessment / Evaluation Forms IATF 16949 - Automotive Quality Systems Standard 1
K Do Forms and Templates ALWAYS become Records? Records and Data - Quality, Legal and Other Evidence 4
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
S Medical Device Servicing - Forms and Signature ISO 13485:2016 - Medical Device Quality Management Systems 1
S Control of Forms Document Control Systems, Procedures, Forms and Templates 4
M AS9100D Process Map Requirements - PEAR Forms AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
Q Controlling Multi-Tab Microsoft Excel Forms Excel .xls Spreadsheet Templates and Tools 5
R Standards Data Forms (form 3654) - American Academy of Sleep Medicine (AASM) US Food and Drug Administration (FDA) 0
H Manufacturer vs. Supplier - Which is which on PPAP Forms APQP and PPAP 3
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P FDA has just released the forms for "Small Business Qualification and Certification" Other US Medical Device Regulations 6
W Form Approval - Blank forms Document Control Systems, Procedures, Forms and Templates 9
W Unattached (stand-alone) Forms acceptable for AS9100C? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
J Training SOP and Forms Training - Internal, External, Online and Distance Learning 3
M Some ISO 9001:2015 Forms and Templates Document Control Systems, Procedures, Forms and Templates 5
P Customer Forms as external documents Document Control Systems, Procedures, Forms and Templates 4
H Incomplete forms and records missing date or a name Records and Data - Quality, Legal and Other Evidence 6
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Document Numbers (Identification) on Forms (AS9100) Document Control Systems, Procedures, Forms and Templates 15
S Clinical Trial Informed Consent Forms ("retro-signing") US Food and Drug Administration (FDA) 2
A How to Verify Supplier I-9 Forms for ITAR Requirements Other ISO and International Standards and European Regulations 2
Gman2 Control of Documents and (FORMS) on a Computer Network ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
MichaelDRoach Where in ISO 9001 is White Out on Forms and Records Prohibited? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
