Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield)
Radlerka
Hi coleagues,
Have somebody met the formula for calculating money value which is equivalent to 1% FPY based on quantity of manufactured products? Just got this task from Business Director and have no idea how to deel with that.
Thank you in advance.
DrM2u
Re: Money value which is equivalent to 1% FPY
This can be a tricky calculation depending on how many parts you are dealing with and how your organization attributes value to each part at each process step. Once you can attribute a money figure to each part or to the parts in average then the rest is easy. I suggest that you ask you Business Director to give you the money figure per part or you can calculate/estimate and give him/her the number of parts equivalent to 1% FPY and let him calculate the rest of the value.
AmitK Sharma
FPY also refers to the First Time Quality (FTQ), & looking to your business directors question, this can be very well calculated at each stage of process. This is also called FTQ PPM.
Once this is calculated, you have to see CoQ to % of Sales, which is = CoGR/CoGS i.s. CoGR = Cost of Goods Rejected / Cost of Goods Sold.
In CoGR, you need to refer to the FTQ PPM data which is = rejection + rework + field/customer line rejects.
JuneFoo
This FTQ - is applicable for the new product only or every new lot of production run?
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
C Formula for Calculating Confidence Interval at 90% Confidence Level Reliability Analysis - Predictions, Testing and Standards 3
R What is the correct formula for calculating part variation (PV)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Comparative Test - The right formula for calculating the number of samples needed? Document Control Systems, Procedures, Forms and Templates 3
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
D True Position Formula? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
R Question: Cg/Cgk formula Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Cost per test tool/formula Oil and Gas Industry Standards and Regulations 1
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
I Formula in the Annex of IEC 61000-4-3 - How is k=7 determined? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
L Signal-to-Noise (S/N) Ratio formula check Design and Development of Products and Processes 2
S Scrap % Calculation Formula Manufacturing and Related Processes 10
P IF formula - Excel 2003 Excel .xls Spreadsheet Templates and Tools 4
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
M Should I use binomial or Poisson distribution formula? Statistical Analysis Tools, Techniques and SPC 6
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
M Formula for Bell Shape in Excel Using Minitab Software 1
M What is the formula to create a bell curve? Excel .xls Spreadsheet Templates and Tools 8
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
B Attrition Rate and the formula to calculate Attrition Rate Quality Manager and Management Related Issues 1
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
D Route Delivery Efficiency Formula - Miles driven, number of deliveries, and time(hrs) Benchmarking 3
S Formula used in Minitab 16 - "Pooled Standard Deviation" Statistical Analysis Tools, Techniques and SPC 2
X Microsoft Excel 2003 Formula Restrictions Excel .xls Spreadsheet Templates and Tools 9
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
