Formula for Prioritizing Engineering Change Requests (ECR)?
milspecrob
Does anyone have a formula (or ever heard of) a formula for prioritizing Engineering Change Requests?
K
keres
Re: Formula for ECR
The simplest formula is priority=impact x urgency. You must predefined the assessment of impact and urgency levels. Then you can prioritize the Engineering Change Requests by priority.
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
I Formula in the Annex of IEC 61000-4-3 - How is k=7 determined? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
L Signal-to-Noise (S/N) Ratio formula check Design and Development of Products and Processes 2
S Scrap % Calculation Formula Manufacturing and Related Processes 10
P IF formula - Excel 2003 Excel .xls Spreadsheet Templates and Tools 4
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
M Should I use binomial or Poisson distribution formula? Statistical Analysis Tools, Techniques and SPC 6
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
M Formula for Bell Shape in Excel Using Minitab Software 1
M What is the formula to create a bell curve? Excel .xls Spreadsheet Templates and Tools 8
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
B Attrition Rate and the formula to calculate Attrition Rate Quality Manager and Management Related Issues 1
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
D Route Delivery Efficiency Formula - Miles driven, number of deliveries, and time(hrs) Benchmarking 3
S Formula used in Minitab 16 - "Pooled Standard Deviation" Statistical Analysis Tools, Techniques and SPC 2
X Microsoft Excel 2003 Formula Restrictions Excel .xls Spreadsheet Templates and Tools 9
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
Q Accuracy: Is there a specific formula to compute Measurement Device Accuracy? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Rameshwar25 Manual Formula for p-value Calculation for MSA Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D Ring Gauges P.D Formula using "Ball Rounded Teeth" General Measurement Device and Calibration Topics 13
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
N Usability Formula to Predict Use Error Reduction IEC 62366 - Medical Device Usability Engineering 6
S Linearity Calculation Worksheet (including formula) General Measurement Device and Calibration Topics 1
S Stability calculation with formula in excel sheet & acceptance criteria Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
somashekar Formula 1 Racing and Safety World News 5
